It is currently Tue Aug 19, 2025 9:36 am
PostPosted: Tue Sep 28, 2010 5:33 am
Last Name: Charnock
Country: UK
Ok this may sound like a stupid question but I need to get my head around the best approach to routing a mortise and tenon neck joint. The recommended router bits as sold by Stewmac have bearing guides on a 12.7mm dia router bit. This informs me that I need to make both the tenon and mortise cut in one pass - not recommended in my view. Can this activity be achieved with a copy ring such as
http://www.bobon.co.uk/details.asp?prod ... evel_id=89
so I can plunge it in increments
If so .........
The next question is what size bit and copy ring is recommended ?
PostPosted: Tue Sep 28, 2010 6:50 am
Sure you can .. it all depends on the delta between the bit and the guide collar, or copy ring as they call it. You will need to take this into account when making the templates.
I like to use 5/8 guide and a 1/2 inch bit whneever possible - all the templates then require an 1/8 inch offset when making them.
So in your case, using the bit/collar mentioned above, the tenon template needs to be 1/8 inch narrower that the tenon size you want, and the mortise template needs to be 1/8 inch wider ...
PostPosted: Tue Sep 28, 2010 7:04 am
Last Name: Charnock
Country: UK
Assuming I have the stewmac templates which are 6/8 I would end up with a 7/8 tenon and corresponding mortise - is that acceptable ?
PostPosted: Tue Sep 28, 2010 8:34 am
I use the StewMac system and make my first cuts in about 1/8" increments with the "copy ring" using a 5/8 guide and 1/2" bit. then I go back and finish up with the bearing guided bit for final thickness. The StewMac system gives you a tenon that is a little smaller than the mortise. I think they are assuming a bolt-on neck
PostPosted: Tue Sep 28, 2010 9:02 am
Last Name: Charnock
Country: UK
Yep - I noticed the tenon template was slightly smaller than the mortise template
PostPosted: Wed Sep 29, 2010 2:17 am
Last Name: Charnock
Country: UK
Todd Stock wrote:
The whole reason why you rout after the body is assembled is to get a a perfectly centered mortise...I see no reason to allow a bunch of slop in the joint, so remade my templates for a friction fit.
I may try a piece of tape on the tenon template to tighten it up a bit.
PostPosted: Wed Sep 29, 2010 8:14 am
John,
The general idea is to remove most of the waste to full depth in incremental cuts, then you clean up the last 1/16th or so neatly with the template and bit.
PostPosted: Sun Oct 03, 2010 10:57 am
Last Name: Charnock
Country: UK
Terrence - do use a copy ring for both the tenon and the mortise with the Stewmac jig ?
PostPosted: Sun Oct 03, 2010 11:26 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
What I do now is I don't bother putting a neck on.
I just run the sides all the way to the nut! bliss
PostPosted: Sun Oct 03, 2010 1:08 pm
Yes I do for the initial cuts so I can take smaller increments. if you use the bearing guided router bit you have to take a pretty healthy first bite to allow the bearings to contact the template. I switch to the bearing guided bit for the final cut to get the proper size.
PostPosted: Sun Oct 03, 2010 1:11 pm
Last Name: Charnock
Country: UK
Thanks - Due to the limited size of the Stew Mac mortise template do you use different size copy rings and bits ?
PostPosted: Sun Oct 03, 2010 7:26 pm
I use a 5/8" "copy ring" with a 1/2" bit for the initial cuts followed by the 1/2' StewMac flush cutting template bit with the top bearing for final cuts.
PostPosted: Mon Oct 04, 2010 1:14 am
Last Name: Charnock
Country: UK
Thanks, I'll need to take a measure to my mortise template - from memory it doesn't look wide enough for a 5/8 ring.
Users browsing this forum: ballbanjos, Bing [Bot] and 28 guests
