It is currently Tue Aug 19, 2025 10:48 am
 Post subject: Rattle woes
PostPosted: Fri Oct 08, 2010 1:02 pm
Last Name: Ensor
City: Springfield
State: Missouri
I just finished carving the neck on my most recent build. While everything seemed to be in order, I noticed that if you tap on the neck you can hear some rattle in the truss rod. It can only be heard when tapped, not shaken (or stirred). Any advice as to how to cure the rattles? Once I tighten the truss rod a little, will the rattle go away? ( I should probably just try that second one.....)
http://elevatelutherie.com
http://ensorguitars.com
 Post subject: Re: Rattle woes
PostPosted: Fri Oct 08, 2010 1:28 pm
Hi Chris,
If you are using the LMI of Allied Lutherie dual-action rod then you really should install a filler strip on top of the rod. I have given a great deal of thought to building a strong neck. In the end, I think the best solution is Allied Lutherie's dual action rod (it features micro-adjustability) and a couple carbon fiber beams.
Best of Luck,
Simon
PostPosted: Fri Oct 08, 2010 1:32 pm
Once it's strung up, deflection from string tension might take care of it. If not, crank on the truss rod it a bit, but not enough to get your neck relief out of range.
PostPosted: Fri Oct 08, 2010 1:49 pm
Last Name: Ensor
City: Springfield
State: Missouri
Thanks guys. I guess I should clarify that I am using the SM hotrod truss rod.
PostPosted: Fri Oct 08, 2010 2:39 pm
First name: duh
Last Name: Padma
Truss rod rattle eh.
Well me heard of this dude who had a rattle in his truss rod.
Tried every thing.
Finally he popped the inlay at the 7th, drilled a small hole down to the rod and
poured in some hot liquid honey. Then stuck it in the freezer for an hour or so for the honey to solidify.
Me hear tell it stopped the rattle real good and him ended up with the sweetest neck you could ever imagine. laughing6-hehe
blessings
duh Padma
PostPosted: Fri Oct 08, 2010 5:50 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
LOL Padma....that's good stuff...and would probably work...
It's probably obvious...but if the TR doesn't seem to be working correctly, then you'll need to replace it.
http://www.PeakeGuitars.com
PostPosted: Fri Oct 08, 2010 6:36 pm
I'd wait till it's strung up and if snugging up the rod does not fix it, doing what the Padma says will work. I've used rubber cement but I don't see why honey wouldn't be similar. Somewhere floating around the web is mark Blanchard's shim technique which will nip the problem in the bud during neck construction.
PostPosted: Fri Oct 08, 2010 9:51 pm
Hi Chris,
That happens to me all the time. Just tighten the rod very slightly and you will be all set.
Alain Moisan
(Now building just for fun!)
PostPosted: Sat Oct 09, 2010 5:14 pm
Last Name: Ensor
City: Springfield
State: Missouri
Thanks for all the help.
Padma, I think I am more inclined to use molasses. But maybe that's just my pallet. laughing6-hehe
PostPosted: Sat Oct 09, 2010 5:27 pm
First name: duh
Last Name: Padma
Molasses are good. Me use it to make me rye bread with.
But it just don't get nice and hard and hold that truss rod from rattlen like cold honey.
blessings
PostPosted: Sat Oct 09, 2010 6:56 pm
I actually had one early one that had the LMI TRSD that continued to rattle intermittently and snugging it up did not completely cure it. It'd be better for a while and then come back. That's the one I injected with rubber cement and that worked. I went from caulk to wax from a toilet sealing ring to the wedge technique Mark Blanchard described. They all worked.
PostPosted: Sat Oct 09, 2010 7:36 pm
First name: duh
Last Name: Padma
There you go Chris,
A whole bunch of techniques and they all work.
Bottom line in building is
"If it gets the pig clean ~ use it!"
blessings
duh Padma
PostPosted: Sun Oct 10, 2010 8:22 am
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I had one guitar with a truss rod rattle. It was my first 2 way adjustable rod. The rattle went away when strung up under tension, but would sometimes come back, either when using dropped tunings, or when the humidity was too low. I finally removed a dot marker and injected it with rubber cement. I considered going back to a compression rod, but I've used a filler strip since then(per SimonF) with no rattles. I strongly recommend not letting the guitar "out" with the potential of a rattle.
Users browsing this forum: Bing [Bot] and 21 guests
