It is currently Tue Aug 19, 2025 12:56 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Tue Oct 12, 2010 12:02 am
First name: Neil
Last Name: Kwak
State: PA
Rob Warren wrote:
Production at last! Got rolling this week on a Sitka and Sapele 12 string SJ. Actually got started last week, but after snapping both sides bending on my pipe, I spent the last week building a fox bender with cutaway ram. Works sweet!
Got the sides bent and blocks in, profiled the back and got the kerfed lining in.
Got the top and back joined, cut all the brace stock to size, and did this rosette(Thanks for the lesson at the open house John Hall)
Now gotta research how to get some black stains out of the sides. Seems even with craft paper wrapping my sides, the couple spots of rust bleed on my slats bled through. I sure the tap water I used didn't help..... idunno
Man, do I wish I were where you are on my OLF MJ build. I see we had similar ideas in mind with regards to doing a semi-solid mold:
Bear with me since I'm still very new at this. I feel like I'm learning a lot but the going's slow as I don't have access to many tools or time to devote on a consistent basis. I'm still working on the bending form. I'm just using a hand drill with a spindle and a square, which is also doubling as a scraper. I think it's close though:
...just a couple of uneven spots in the cross-section.
...but I figure that if it fits within the curve of the outside mold then I'm getting there:
I'm mostly worried about the fit at the waist:
Not much actual work being done on the guitar itself. Most of my tone woods are over at YJ John's place where he has all the proper tools. My top and back are joined and sanded to thickness but I still have to run them through the drum sander just a couple more times with a lower grit roll to smooth out the marks from the 80 grit roll. The sides are waiting to be trimmed to the outline on the plans.
Last week he and I dremeled out a 5" radius x .1" thick rosewood ring from some scrap to be used as the central ring of my rosette. It took 6 tries but now I have a full set of 6 rosewood coasters! :lol:
In the meantime, I'm mostly just doing prep work. You know - lurking here and bending peoples' ears about what the best way to do the next step and all. All I can really do here at home is think about what I want to do and try and come up with a plan. Being a graphic artist does have its benefits. While it's not truly a CAD program, Adobe Illustrator does have its uses:
The numbers are simplistic and likely to be off, but essentially I intend to route out the trenches for the two outer purfling strips at equal distances from the central ring which will also be bound by purfling. The central trench will be a bout .22" and I'm going to try to glue the purfling in the central ring before dropping in the rosewood. I'm still trying to figure out the best way to do that though. Speaking of which, the rosewood ring is cut at .1" thick give or take. I have a little tear-out that needs to be smoothed out but it's usable.
It doesn't look I'll get much more done this week but I'm going to finish up sanding the acrylic template for the sides. I still have some extra material that needs to be carefully removed with the hand drill spindle:
I'm hoping once this is all done I can get the inlay done and move on to splitting billets and using my band saw here to cut them to rough shape. I'm really looking forward to voicing the top and bending sides for the first time though. Those look to be a few weeks off though.
PostPosted: Tue Oct 12, 2010 12:19 am
Bent my first set of sides. Yellow cedar on a homemade iron. :D
-Jake.
PostPosted: Tue Oct 12, 2010 5:21 am
Thanks Todd. 1.25 oz. is a fairly substantial weight savings... I have an OM that justs feels a little heavy at the headstock,, might be a good way to bring it in better balance. Now how that willl affect the tone....
Thanks, Chuck
PostPosted: Tue Oct 12, 2010 7:13 am
Last Name: Thiessen
City: Lexington Park
No picture, but I picked up a Grizzly 18" Drum sander off of craigslist yesterday for $600. I have been watching cragslist/classifieds for 8 months trying to find a good deal on any decent drum sander. Finally paid off. It is only 6 months old and the guy I bought it from built an enclosed shelf on the stand, and a frame with casters for the stand to sit on. I'm pretty stoked!
John Thiessen
http://www.iszacguitars.com
PostPosted: Tue Oct 12, 2010 9:32 am
Well, up here in Canada it was Thanksgiving weekend, so we had a 3 day weekend. Spent some time with family and friends but managed also to get some work done.
I got a Monkey Pod all sanded up and ready to finish.
And also got one put together.
Black Walnut/Spalted Maple with Engleman top.
It's a 12 fret small body. Sounds pretty good already.
Here's some pictures...
Neil
PostPosted: Tue Oct 12, 2010 10:47 am
First name: Darrin
Last Name: Oilar
City: Cottonwood
Zip/Postal Code: 96022
That is a beeeeautiful guitar Neil. Love the wood combination of the three piece back. Very nice.
Darrin
PostPosted: Tue Oct 12, 2010 1:24 pm
Finally got this beast done. It's the third I've built for Dan Mahar. (http://www.youtube.com/user/danmaharoff ... i-HeV20TMA) He's taking it to a tour of Ireland and Norway in a couple weeks. It's basically Dan's concept that I tried to make happen and has a Fishman Nashville pizeo on the spider and a fretboard end humbucker with dual outputs.
In the hands of a good slide player it sounds awesome.
PostPosted: Tue Oct 12, 2010 8:32 pm
First name: ron
Last Name: atkins
City: ottawa
State: il
Zip/Postal Code: 61350
This is really sweet. So many details working together like the sister curves on the top of the heatstock and the end of the fretboard and the spalted line that matches the back and end graft.
Nice work.
Neil
rono
PostPosted: Tue Oct 12, 2010 9:31 pm
Processing some sproose.
