It is currently Tue Aug 19, 2025 11:27 am
PostPosted: Fri Oct 15, 2010 9:39 am
First name: Damon
Last Name: Wack
State: FL
I'm interested in finding some good sources for wooden rosettes, specifically the larger (4.75" or so ID) diameter for steel strings.
thanks,
Damon
Damon Wack
https://www.facebook.com/LindamonGuitars
PostPosted: Fri Oct 15, 2010 1:01 pm
City: Keene
I've been making my own for years.... Anything specific you are looking for?
PostPosted: Fri Oct 15, 2010 1:15 pm
First name: Ellison
City: Whitman
State: MA
RC Tonewoods and LMI both sell blank squares for rosettes.
PostPosted: Fri Oct 15, 2010 1:37 pm
First name: Damon
Last Name: Wack
State: FL
Blank square stock - what an idea! duh
For some reason I was envisioning the gluing together of many pieces of wood and cutting small pieces off, re-gluing them in patterns.... and at this point in my building career I just didn't want to spend the time doing that. Cutting circles out of blanks and adding decorative strips around them sounds perfect!
thanks,
Damon
Damon Wack
PostPosted: Fri Oct 15, 2010 5:08 pm
Or, you could use pieces cut from the back to make tiles. 12 tiles at 15 degrees per side will give you a nice radial rosette. It doesn't take that much more time or effort, and the rosette can match the guitar perfectly. My miter saw has a stop at 15 deg. I cut my blank pieces about 1.25 inches high and then I made a stop on the saw where the bottom (narrow) part of the tile was around 1 inch.
PostPosted: Fri Oct 15, 2010 5:20 pm
I use to buy them too, but I found if I use the 2 off cuts from the waist area, I get a rosette blank that perfectly matches the back. A single minature joint and a circle cutter will do the trick.
PostPosted: Fri Oct 15, 2010 6:03 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
try
www.dukeluthier.com
Mike Collins
PostPosted: Fri Oct 15, 2010 6:21 pm
First name: Damon
Last Name: Wack
State: FL
Wow, great stuff, thanks!
I love this forum! bliss
Damon Wack
PostPosted: Fri Oct 15, 2010 10:30 pm
First name: ron
Last Name: atkins
City: ottawa
State: il
Zip/Postal Code: 61350
I'm doing a huge wooden rosette on my first. I ordered a bunch of walnut rosette blanks from RC Tonewoods. Many of the pieces were book-matched. I jointed a set and cut out the circles. I like the way the figure is matched. I'm going to use a piece of the center cut out for the heal cap that will also have a bit the book-matched figure.
rono
PostPosted: Sat Oct 16, 2010 7:10 pm
I forgot to mention that I bought most of mine from Blue Mountain Acoustics (www.bluemtnacoustics.com) - many to pick from and Kevin will cut to your size if you wish.....
PostPosted: Sat Oct 16, 2010 9:37 pm
Alain - I really like how your rosette looks installed. How do you glue all the wedges together and hold them in place while the glue dries? What glue do you use?
