It is currently Tue Aug 19, 2025 12:09 pm
PostPosted: Sat Oct 16, 2010 10:24 am
First name: Bobby
Last Name: Masten
City: The Woodlands
Zip/Postal Code: 77380
I'll get the bad out of the way on my first post as the good is still drying in the go-bar deck. After installing 2 new braces on the back I removed earlier this week, I made a pile of shavings from scalloping those and the rest of my tops braces. Time to clean up. Got out the shop-vac and proceeded to do a thorough cleaning of my work areas. While cleaning out behind my rolling workbench the hose snagged on a corner of the bench and flipped my sides off the bench. Result:
aarrggghhh!
Bobby Masten
PostPosted: Sat Oct 16, 2010 1:20 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I tried a sunburst for the first time this week. Looks pretty good to my eye (for a first attempt)
This is a 1967 Hagstromm 12 string I re-topped after the original (badly designed) top collapsed. The owner really wanted to reproduce the sunburst, so (with no guarantee about the outcome) told him I'd give it a try.
When practising, I had a hard time getting an even spray pattern, so I built a lazy susan, using an old radius dish I don't use any more. I found by spraying inwards from the edge & varying the angle of the gun as I turned the guitar on the lazy susan, I could control it quite easily.
With the lacquer thinned about 30%, it flashed off so fast, I was able to keep going round & round, concentrating closer to the edge with each rotation.
Here is the result...
I started by spraying an amber tinted base coat over the entire top.
The colour was aniline dye (color FX) I borrowed from Danny V. (Thanks Danny!) It took three colours to approximate the original mahogany sunburst colour... Amber, burnt sienna & black. I just kept adding colour 'till it looked right on the stir stick.
Surprisingly, it looks like I sprayed at least two different colours. Weird, but I like the effect.
PostPosted: Sat Oct 16, 2010 1:26 pm
Country: Romania
Sorry to see that but it's not as bad as it looks. Work in some hide or fish glue, add in a couple side braces and forget about it. After finishing you won't even know where it was.
Build log
PostPosted: Sat Oct 16, 2010 1:41 pm
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
Wow Daniel - that is an amazing sunburst!
I tried a similar burst with aliline dye and em6000, didn't go so well....your work is inspiration!
I just installed the side markers on my current build. This is my first attempt at a bound fretboard and backstrap....so far so good!
PostPosted: Sat Oct 16, 2010 1:46 pm
Last Name: Beaver
City: Lake Forest
Yeah, split sides are a bummer but the usually mend ok.
Daniel: Great looking burst!
Joe Beaver
Maker of Sawdust
PostPosted: Sat Oct 16, 2010 2:17 pm
First name: Keith
Last Name: Lally
City: Brookhaven
State: New York
I put three coats of zpoxy and two coats of shellac on my #2 build. I was going for an older amber type look and am happy with the results. Many coats of EM6000 are going on next.
This has a spruce top, mahogany back, sides, and neck.
Keith Lally
http://krl-guitar-building.blogspot.com/
PostPosted: Sat Oct 16, 2010 2:23 pm
Bobby – that’s a bummer about the split side! Hopefully some CA and some side struts will make it good as new.
Daniel – that burst is gorgeous!!! eek [clap] I hope my first turns out half as nice.
PostPosted: Sat Oct 16, 2010 4:39 pm
First name: Bobby
Last Name: Masten
City: The Woodlands
I'm leaning towards using CA instead of hide glue. My thought is it will weather the warmer SC heat better and not soften up. Now for the good. Replaced the top two braces on my back and finished bracing the top. Time for football, beers and some steak.
Bobby Masten
PostPosted: Sat Oct 16, 2010 7:56 pm
First name: Darryl
Last Name: Young
State: AR
Nothing........deer hunting with my muzzleloader.
PostPosted: Sat Oct 16, 2010 8:35 pm
First name: David
Last Name: LaPlante
Working up and installing a rosette.................
PostPosted: Sat Oct 16, 2010 11:21 pm
First name: George
City: Seattle
Closed up the box on one earlier this week and started bracing another this weekend. Should get this one closed tomorrow. I'm trying to build my chops by doing two at a time. Seems to be helping, but only time will tell. Either way, I'm having a lot of fun.
George :-)
PostPosted: Sun Oct 17, 2010 7:43 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I joined tops for my 2 current projects, photos of these can be seen on my Facebook "FE Tellier guitars" page. I also cut and glued the woods for a laminated neck for a future project, Mahogany with EIR and curly maple EIR in the center. The curly maple was also my 1st attempt to resaw and it came out quite good.
Fred
Fred Tellier
PostPosted: Sun Oct 17, 2010 8:41 am
Been in the shop building 5 laminated necks for the 5 boxes i batch built and resawing some new sets for near future builds.
PostPosted: Sun Oct 17, 2010 10:10 am
First name: Bert
City: Gainesville
State: GA
Zip/Postal Code: 30506
I leveled and crowned the frets on an "A" style Gibson mandolin including a set up and installed a Barcus Berry pick up.
Installed an EMG on a solid body Epiphone mandolin that looks like a Gibson Firebird and a set up. (Half size)
Installed new plastic buttons on a Vintage Gibson lap steel and cleaned the potentiometers.
Reglued the back binding on a D-28 Martin from the waist to the neck both sides. Also fixed the tail-pin input jack. Also replaced the nine volt battery. While replacing the battery a plastic tab broke on the battery holder. Called EMG and they are shooting out a new one free. Since I broke it I was expecting to pay. EMG is a good company to do business with.
Off topic: I made a 12 volt to 7 volt regulator for my '75 Honda Goldwing temperature and fuel gauge. With less than $10.00 worth of parts from Radio Shack vrs $40.00 for a new one aftermarket. Lord only knows how much that puppy is from Honda.
"Try to be the person your dog thinks you are."
http://sites.google.com/site/bertsguitarshop/
PostPosted: Sun Oct 17, 2010 10:35 am
Leveling and fretting a replacement neck on a 12-string electric. Not getting much time in the shop due to lot's of construction/maintenance projects around the place.
PostPosted: Sun Oct 17, 2010 10:45 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Reclaimed some shop real estate by amalgamating a workbench, worktable, tablesaw, router table, room air filter, humidifer, and storage shelves. This is better than running all three separately and frees up precious work space.
Made some progress on my DIY thickness sander. Awhile back I acquired an old RAS, well beyond its best before date as I got it from the local dump. I had already reconditioned an old RAS so I didn't need another, but I thought that it could be pressed into other service. I have the motor set up and a table now. I thought about a feed system but felt that it was going to me more complicated than I have time for now, so I will use a sled. I still have to level the drum, make dust collection, and fit the abrasives on the drum.
I built a new solara for a new classical guitar build. This one has a 5mm dome, my other one is only 2.5mm and has a different neck angle.
I am making progress on the Viola da Gamba. I bought some Spruce staves from Shane and am getting them laid out for bending and joining into the arch shape.
Spent a good many hours researching and preparing quotes and talking to a client about a big project. It appears fruitful, so it was worth the investment.
Finally, I am resurrecting this big old freighter canoe that was REALLY beat up! This one is used for racing and has already earned its restoration fees in prize money.
http://redrivercanoe.ca/
PostPosted: Sun Oct 17, 2010 11:29 am
Country: Romania
5mm? Wow. Would not that result in a too low bridge even with a perfectly flat neck?
Build log
PostPosted: Sun Oct 17, 2010 11:44 am
Country: Romania
Myself I am still at binding my 9th, now the back using a little divide et impera - I glue the top purfling before the rest just to reduce the mental stress :)
Build log
PostPosted: Sun Oct 17, 2010 12:35 pm
First name: David
Last Name: LaPlante
Lovely Alex....looks very Granada school.
PostPosted: Sun Oct 17, 2010 1:41 pm
Country: Romania
Thanks! Your meander is lovely too. Is it for your 100th? I need to find the courage and try it too for a head+back+end strip.
Speaking of Granada and the end strip, John Ray said they inlay it after doing the binding. That might very well be easier but I preferred to stick to what worked before (this is my 3rd with miters everywhere).
Build log
PostPosted: Sun Oct 17, 2010 1:49 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
Shouldn't.
I drew it all out when I did my FE17 exploration and it worked out just right with a flat neck angle. This time I'll be working on a FE19 plantilla. I have it on good authority, from Jason Wolverton who had opportunity to measure FE17 in person, that its dome is 5mm. That, and evidence from photos which support my thoughts, I am working with 5mm for the dome.
Last edited by douglas ingram on Sun Oct 17, 2010 1:57 pm, edited 1 time in total.
PostPosted: Sun Oct 17, 2010 1:53 pm
First name: David
Last Name: LaPlante
No, it's a special request for my #96 guitar which was concepted some time back and lay unfinished till a client recently commisioned me to complete it albeit with Birds eye Bosnian maple rather than the cypress I planned on initially.
Meanwhile, others came along and got a place in the sequnce before it.
I just need a client for my 100th to get going on it though!
PostPosted: Sun Oct 17, 2010 2:50 pm
Cleaned the shop for the next go-round and mowed the leaves...
PostPosted: Sun Oct 17, 2010 5:16 pm
Worked some on the peghead of the "rockabilly archtop"...
...and started messing with colors. wow7-eyes
PostPosted: Sun Oct 17, 2010 5:28 pm
First name: Stuart
Last Name: Gort
This week I finished these truss rod covers and started on this bridge.
Those truss rod covers have a .006" maple keyline around a toasted maple core fit into a bloodwood base.
I also got the first few coats of Tru-Oil on all the peripheral pieces.
StuMusic
Users browsing this forum: DennisK and 13 guests
