It is currently Tue Aug 19, 2025 2:29 pm
PostPosted: Sun Oct 17, 2010 2:46 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
What technique do you use the level and thickness fret board blanks. I have been using my thickness sander but have difficulty getting the top and bottom straight and parallel to my liking and spend way too much time on this step before it is acceptable.
Fred
Fred Tellier
PostPosted: Sun Oct 17, 2010 2:57 pm
Fred, I normally just joint, then resaw, then use a Delta planer .... works beautifully on ebony.
Milton, ON
PostPosted: Sun Oct 17, 2010 3:03 pm
Fred, I run mine through the thickness sander too. I don't have much problem getting it trued. Maybe your sander needs a slight adjustment?
Chuck
PostPosted: Sun Oct 17, 2010 3:23 pm
Country: Romania
I use a Jack plane at York Pitch. The blank is fixed between two 5mm tall stops that are clamped to the bench. What I like about planing is that I can correct, if not all, at least a good part, twisted or humped boards. I would imagine this is a bit more difficult to do with a sander?
Build log
PostPosted: Sun Oct 17, 2010 3:43 pm
I just pass them through my planer until they reach the desired thickness.
Alain Moisan
(Now building just for fun!)
PostPosted: Sun Oct 17, 2010 4:39 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
Fred
You could spend some time on your thickness sander getting the roller perfectly parallel to the table.
Or you could send a piece of 3/4" MDF through, taking off just enough so you have sanding scratches all the
way across. The MDF will now be parallel to the drum.
Now just run your fretboards through on top of the MDF. You probably know this but it's best to make a
fence on the near end of the MDF so the rotating drum doesn't catch a fretboard and throw it back at you.
PostPosted: Sun Oct 17, 2010 5:20 pm
Now that is a cool tip Jim! [clap]
I know I've read that before as a simple fix for not quite parallel sanding drums, but I need reminding. :lol:
Joe
PostPosted: Sun Oct 17, 2010 6:04 pm
First name: Fred
Last Name: Tellier
City: Windsor
My parallel issues are not side to side but end to end. I get one side perfectly flat with the jointer but when I work the other it does not come out as flat as the 1st side. I also get a little snipe at the end at the start but use a long blank so it is not a problem. I made a flat carrier board to send it through on and it helps a little. I have resorted to putting wide masking tape under the thicker sections to flatten it out on the last passes. The boards come out fine when I am finished but it is more work than it needs to be, or maybe I am too fussy about my results. I check my work with a wide straight edge held on the board looking for light coming through from the lower areas.
Fred
Fred Tellier
First name: Fred
Last Name: Tellier
City: Windsor
Fred
Fred Tellier
PostPosted: Sun Oct 17, 2010 6:38 pm
First name: Fred
Last Name: Tellier
City: Windsor
Quote:
A straight edge ain't tellin' you jack about what your sander's up to.
It does when one side is still straight and the other is not after sanding. Like you say a little cup is ok. I think I am trying for more straightness than needed, but I am a little overboard sometimes.
Fred
Fred Tellier
PostPosted: Sun Oct 17, 2010 6:48 pm
Fred Tellier wrote:
... or maybe I am too fussy about my results. ...
From my point of view, probably. I don't think it is necessary to have a surface that perfect for a fretboard. At least not at this stage in the process.
Alain Moisan
PostPosted: Sun Oct 17, 2010 8:01 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Hey Fred,
it's good for a luthier to be a little overboard!!!!
PostPosted: Sun Oct 17, 2010 8:50 pm
Fred, I just take mine strait from the drumsander to a lapping plate( that gets it perfectly flat) just before glueing it to the neck that also is lapped on the plate.
PostPosted: Mon Oct 18, 2010 1:52 pm
I made a pusher and flatten one side on the jointer and sand the other side to proper thickness on my Performax.
Users browsing this forum: A.Hix and 21 guests
