It is currently Tue Aug 19, 2025 12:06 pm
PostPosted: Wed Oct 20, 2010 9:51 am
First name: Sean
Anyone ever use a power miter saw to cut this 15 degree cut? Will it work accurately?
change isn't synonymous with improvement
instagram.com/bucketguitars/
PostPosted: Wed Oct 20, 2010 10:14 am
If you have the reach in the blade, I dont see why not .... but you still might have to touch it up with a plane. I just cut it close on the bandsaw, then clean up with a plane .. it takes about 4 minutes and its ready to glue ... try it, its not that hard.
PostPosted: Wed Oct 20, 2010 10:16 am
First name: Aj
Last Name: White
City: Hangtown
I just did it on my number one, made up a little 90 degree fence and it didn't go so well. I was able to plane everything flat after wards though. I think the ticket would be to make a wedge style fence so your neck blank is better supported and the saw blade would be fully adjusted left. I think I could make it work a lot better and will try it again next time.
PostPosted: Wed Oct 20, 2010 10:29 am
First name: Corky
Last Name: Long
City: Mount Kisco
That's what I do as well - except I built a simple sled, at 15 degrees, which fits into the guide slot on my bandsaw. It's still not totally accurate, and you have to feed it very slowly until the blade cuts the angle properly (bandsaw likes to deflect away from the angle of the neck blank), but it works fine after a few passes of a sharp plane.
PostPosted: Wed Oct 20, 2010 8:08 pm
First name: jon
Last Name: letts
City: leicestershire
Zip/Postal Code: le676pz
Country: uk
yes. i dont see the point of setting up fences at the best of times. bandsaw by hand and then clamp the neck and headstock (spun round) together and plane the both together. perfecto! i also go 13 degrees.
PostPosted: Thu Oct 21, 2010 12:05 am
First name: jon
Last Name: letts
Country: uk
Todd Stock wrote:
I always clean up with a hand plane, so a band saw or back saw cut is fine...a couple wire brads set outside the peghead outline can help keep things lined up.
yep, just like that!
PostPosted: Thu Oct 21, 2010 12:16 am
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
Band saw by hand and plane for me too. 16-17 degrees on my classical.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Thu Oct 21, 2010 1:27 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
This thread will save me time and forearm stress....I was taught to use a sanding block to true the 15 degree pieces. Never even thought about using a plane...duh! I'll be doing that on my next one. Have always dreaded the scarf cutting because the bandsaw isn't super accurate, even with my very clever jig, and have had to sand for a long time before getting a perfect joint. Thanks guys! Beth
PostPosted: Thu Oct 21, 2010 11:47 am
First name: Sean
Thanks for all the tips!
Users browsing this forum: DennisK and 25 guests
