It is currently Tue Aug 19, 2025 1:01 pm
 Post subject: Chemcraft pore filler
PostPosted: Wed Oct 27, 2010 12:27 pm
Has anyone used the Chemcraft neutral pore filler without putting any tint into it? The rep at LMI says that it's transparent under finish. At least on padauk and EI rosewood, I seem to be getting white pores.
michael propsom
www.propsomguitars.com
PostPosted: Wed Oct 27, 2010 3:12 pm
First name: Woodrow
Last Name: Brackett
City: Grover
Zip/Postal Code: 28073
I've got no experience with that actual product, but aren't most "neutral" fillers kinda spruce colored? The only way it would be transparent under finish is if the wood matched the filler. I'd recommend tinting it with some trans tint. ( I guess this works with that filler)
PostPosted: Wed Oct 27, 2010 6:05 pm
Yes, most 'neutral' fillers are an off cream color. This is actually a darker color in the can. The reason I asked is that I was assured by a sales rep that it's clear under lacquer. I don't want to tint it. I already have enough pre-tinted silex based fillers. I want a clear/transparent filler--and, given the Colortone clear water based filler's reviews, I'm not trying that.
I might end up just having to go back to Z-Poxy, unless Seagreave eventually begins reproducting the old McFadden't clear filler. That stuff was great.
Anyway, has any body out there used the Chemcraft neutral? If not, do you know of any other Non-z/poxy, non-colortone clear pore fillers? Thanks in advance.
michael propsom
PostPosted: Wed Oct 27, 2010 7:34 pm
First name: Woodrow
Last Name: Brackett
City: Grover
This stuff works great. It's waterbased, but it's nothing like the colortone stuff.
http://www.rockler.com/product.cfm?page=17353
Rosewood will take ~3 coats. It dries quickly, you can re coat in an hour. Be SURE and wear some type of mask when sanding it. It contains silica.
PostPosted: Wed Oct 27, 2010 9:19 pm
Thanks, Woody. Like the solvent based fillers, can this be used after a light coat of vinyl sealer, or should it be used directly on the bare wood?
michael propsom
PostPosted: Thu Oct 28, 2010 5:45 am
First name: Woodrow
Last Name: Brackett
City: Grover
I think it can be used either way. I put it directly on the wood. It does a decent job of sealing difficult to seal woods like Rosewood.
Users browsing this forum: Bing [Bot] and 13 guests
