It is currently Tue Aug 19, 2025 10:41 pm
 Post subject: "Goof-Off" Remover
PostPosted: Fri Oct 29, 2010 6:59 pm
First name: David
Last Name: LaPlante
I just tried cleaning my bending iron with this stuff.
It really did a good job of removing all the old blackened and burnt rosewood resin.
A "scotch brite" pad was helpful in additionally scrubbing the aluminum heating element really clean.
 Post subject: Re: "Goof-Off" Remover
PostPosted: Fri Oct 29, 2010 10:02 pm
Good tip, David! I have some of it, but almost never use it. I try not to do any more painting than I have to! :D
PostPosted: Sat Oct 30, 2010 2:41 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Good tip David.
I have been wrapping my iron with aluminum foil & replacing it when it gets covered in tar.
PostPosted: Sat Oct 30, 2010 8:18 am
Thanks for the tip, David. My bending iron is looking pretty grungy. So I will give it a try.
Max
Max Bishop
Brighton, Michigan
PostPosted: Sun Oct 31, 2010 10:23 am
First name: Big
Last Name: Jim
Wish I woulda had "goof off remover " when the teenage sone was still at home !
PostPosted: Sun Oct 31, 2010 2:14 pm
Last Name: Ulman
City: Bellevue
State: Washington
I’ve had a small can of it that’s lasted for over 20 years now. It works great… but… I will not use it inside the house or without protective gloves due to the extremely strong organic vapors it gives off. They have a milder version of the stuff with less fumes but it doesn’t work nearly as well.
Joe
PostPosted: Mon Nov 01, 2010 7:43 am
First name: David
Last Name: LaPlante
I know what you mean Joe, I should have mentioned that I did the work outside.
I'm guessing that this is mostly mneral spirits but there are additional solvents which seem to give it more "kick".
Good ventilation is a must with this stuff.
PostPosted: Mon Nov 01, 2010 11:21 pm
First name: Jonas
Last Name: Baker
City: North Haven
State: CT
Zip/Postal Code: 06473
I used to use this stuff when I worked as a painter over the summers in college, and it definitely worked great for removing paint and residues, but I have to agree with the prior posts that you should definitely not use it indoors and without a good mask. It definitely gave me some sort of horrible buzz after using it indoors for any length of time, and I remember the health warnings written on the side of the bottles being pretty serious in terms of it's potential negative health affects. I personally stay away from it.
Users browsing this forum: Heath Blair and 27 guests
