It is currently Wed Aug 20, 2025 12:07 am
PostPosted: Sat Oct 30, 2010 8:57 am
Last Name: Thiessen
City: Lexington Park
Hi all,
I am slowly building up my tool collection to make the jump from electric guitars to acoustic and the next thing on the list is something to bend the sides. I really like the side bending machines, but they are fairly expensive, but then again a nice bending pipe from stew mac is almost half the price of a bending machine from blues creek. (it only costs 100% more to go first class) I know I can build these things to save money, but I have limited time to work in my shop and like to spend the time actually working on a guitar instead of on tools and jigs, so I prefer to buy. I had almost bought an iron for bending binding for my electrics so I still kind of want one for that reason, but bending sides for acoustic seems much easier and quicker on a machine. So, my question is do I need both an iron and a bending machine, or just one or the other. And if just one, which one? If both, which one first?
thanks,
John Thiessen
http://www.iszacguitars.com
PostPosted: Sat Oct 30, 2010 9:54 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I actually use both, the Ibex bender like what Stewmac and others sell and a home built Fox style bender with a blanket and slats from Blues Creek. I bent my 1st 3 guitar sides on the hot pipe style bender and still use it for touch ups and bending rosettes and some binding. If I only could have 1 it would be the Fox style bender, but eventually you will find a need for both. Bending by hand helped me understand the bending process a lot better and I am glad I started with it.
Fred
Fred Tellier
PostPosted: Sat Oct 30, 2010 11:17 am
I know I definately need both. I probably use the iron more than the bending machine, for touch ups, backstrap veneers, bindings, mando sides, experimental models, cutaways... So, I would recommend you get an iron first, and start with some cooperative wood, like EIR, to learn the ropes so to speak. Build a machine later, don't let the need for elaborate jigs, tools and whatnot keep you from building guitars. [:Y:]
PostPosted: Sat Oct 30, 2010 11:42 am
First name: Hugh
City: Lake Oswego
State: oregon
I like the pipe for a reason completely unrelated to luthierie: it feels more like I'm fooling mother nature than any other process. Everything else is just a piece of wood as it grew, I just cut something off of it.
Hugh
PostPosted: Sat Oct 30, 2010 12:28 pm
First name: duh
Last Name: Padma
Well umm
my bender cost $10. its a BBQ starter shoved into a tailpipe. Simple eh.
Some dudes got the $...had a Stew Mack Attack and bought at least one of everything in the catalog.
Do you need a bending machine to build a guitar...NO! You don't.
Are they nice to own...well ya, I guess...sorta like an oliephant...nice to look at , but me woulden't wanna own one.
Ya, is true, me liked getting bent out a shape using pot...thats right, me bent for years and years using an old stove pot and a propane torch. Me has bent over old black stove pipe. Me bent over hot coals, Me has even bent backwards on occasion... but then me just bent anyways...so the thing here is....hand bending using heat is a skill to be mastered...but not a difficult one. Is rather easy to master, deeply rewarding inwardly and cheap like borscht. Besides, its been a luthiers tradition for centuries.
So how you bend is really a personal choice , " if it gets the pig clean ~ use it. "
blessings
duh Padma
PostPosted: Sat Oct 30, 2010 12:53 pm
Last Name: Thiessen
I hadn't seen the BBQ starter bending pipes until now. That might be a good option and save money for the machine. I am not really interested in using propane. I am heading to lowes in a bit and might check into the bbq starter.
John Thiessen
PostPosted: Sat Oct 30, 2010 1:14 pm
I use both also, my bending pipe is just an aluminum tube with a vented cap at the end and a propane torch.
PostPosted: Sat Oct 30, 2010 1:19 pm
Last Name: Abercrombie
And the storage problem is similar!
If you build a bunch of different shaped guitars, the bending machine parts can pile up.
Using a press screw bending machine without having some 'hand bending' experience (either an iron or just hand bending with a blanket) is a recipe for breaking sides - the 'feel' is removed from the process. I've bent sides and binding a number of ways, and I've gotten rid of my Fox-style machines.
PostPosted: Sat Oct 30, 2010 2:24 pm
I use both. My pipe is just a chunk of pipe with a blowtorch. When I finally got a blanket bender from Blues Creek after doing forty or so guitars with other methods it was nothing short of a revalation. If you plan on building for a long time just bite the bullet and buy/build a blanket bender and save countless hours of production time.
PostPosted: Sat Oct 30, 2010 2:34 pm
At my pace of building 5 or so a year I still haven't felt the need to build/invest in a bending jig. If I was doing 10+ then maybe I would but then again maybe not. It doesn't take that long to bend sides by hand. I have a propane torch setup that I used for a while and an electric setup (I think it is worth it to purchase the little extension for the end, I use that smaller radius a lot). The propane setup is easier to use for me, it heats up faster. It is more bulky also, though, and feels more dangerous. You do know when it is on though. I worry sometimes about leaving the electric iron on.
Burton
Brookline, MA.
PostPosted: Sat Oct 30, 2010 2:58 pm
First name: Big
Last Name: Jim
Me kinda like that kinda bent to ! laughing6-hehe
I have used pipe and blowtorch successfully , I have had a friend here bend several on a bender and I was successfull there to ! laughing6-hehe
PostPosted: Sat Oct 30, 2010 4:06 pm
I've used a pipe and machine (someone else's). The pipe is more fun. I guess if I was building a bunch of guitars of the same shape, I might want the machine, but I'm not and I don't.
Walter Lay
"It's taken me so long, but now that I know
I can see. All that I do or say, is all I ever will be"
- Billy Joe Shaver
PostPosted: Mon Nov 01, 2010 12:33 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I started out using a bending machine but I've converted to pipe bending. The pipe is so much easier than I thought that I'm still kicking myself over the time and money I spent on bending forms and a heat blanket. For one-off builds a pipe makes more sense. If you plan to make many copies then a bending machine might be better.
Just a pipe with a charcoal starter, propane torch, or heat gun is all you need. Very cheap and easy and versitile
PostPosted: Mon Nov 01, 2010 1:52 pm
Somehow that doesn't surprise me :mrgreen: :mrgreen: :mrgreen:
I am using the same 4in copper pipe that I got for free in 1992 with a blow torch in the back. I am actually not very good at bending sides but it's one of my favorite things to do building guitars.
PostPosted: Mon Nov 01, 2010 6:32 pm
I'm with you Burton although I use light bulbs and a dimmer to heat my large and cutaway pipes.
PostPosted: Wed Nov 03, 2010 3:51 pm
Last Name: Thiessen
how do you build one with a light bulb? Do they take some time to heat up and do they stay hot well?
John Thiessen
PostPosted: Wed Nov 03, 2010 8:53 pm
I use a 300 watt incandescent in my large pipe (4" pipe bent into a teardrop shape) and a 300 watt halogen in a piece of 1 1/2" pipe for cut aways and smaller stuff. A regular 600 watt dimmer is used with both and maintains the temperature very well. Takes about 10 minutes to heat up. Having said that, I've never tried a Fox bender and may become a convert although bending seems to be one of the more pleasing and simpler parts of building a guitar, even with a pipe. I've only built 8 guitars so take it for what it's worth.
PostPosted: Thu Nov 04, 2010 4:14 pm
Last Name: Thiessen
Thanks, I think I might try that instead of the charcoal lighter, if it only takes 10 mins to heat up I can handle that, seems a little less rigged to me as well.
John Thiessen
PostPosted: Fri Nov 05, 2010 8:36 pm
Last Name: A
just make sure you don't drip water in the socket - the BBQ start worries me less as it is not a fragile as a bulb, and it tolerates getting wet (the element at least). A bulb would explode if cold water were dripped on it.
PostPosted: Tue Nov 09, 2010 7:13 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Here's my hot pipe....pretty sophistimacated eh? There's a 1.5" hole in the board under the pipe flange to let the hot air out
I just bent a set of koa sides for a 14fret 0size over the weekend. So satisfying bliss
PostPosted: Tue Nov 09, 2010 9:14 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I stuff this 500 watt soldering iron in the pipe,
and put a wet terry cloth towel over it,
and the temp seems perfect.
Before the towel, I used a variac to control da temp.
I like not having a lot of big jigs around.
PostPosted: Wed Nov 10, 2010 9:04 am
First name: Kenneth
Last Name: Jeffs
City: Chesterfield
Zip/Postal Code: 63017
Here is a picture of my home made pipe bender. I is heated by a 200 watt light bulb and temperature is regulated by a dimmers switch and BBQ grill thermometer
PostPosted: Wed Nov 10, 2010 10:47 am
First name: Kent
Last Name: Bailey
City: Florissant
State: Colorado
Zip/Postal Code: 80816
I have the torch in pipe DIY unit and have bent several sides....scorched a couple and broke one. I still haven't figured it out. Some woods bend like butter and others bend with a twist and others don't bend without serious work. Wood prep: Some people say say spritz...some say soak...some a say bend dry.
I'm ready to build a DIY light bulb mold bender myself see if that helps my success ratio. Thennnn... maybe progress $$$ to a slat and blanket addition.
All bending CAN be done with a pipe....but the learning process for me has been brutal.
Kent
Wood Creations by Kent A. Bailey
EXCELLENCE IN SCULPTURE, CARVING, LUTHIER, ARCHITECTURAL MILLWORK AND DESIGN
http://www.kabart.com
PostPosted: Wed Nov 10, 2010 12:00 pm
I am actually building my 2nd guitar so the bending pipe is Ok for the moment. it is heated with a 200W halogen bulb .Here are some pictures:
PostPosted: Thu Nov 11, 2010 8:23 pm
First name: duh
Last Name: Padma
Ok, there is something to say about benders that ain't been said yet...
and this is very important...
straight up or over ice is ok but stay away from that sweet sodie pop mix...it will leave you bent out a shape with a headache.
Now at a shot an hour, you can go for weeks and weeks,
a shot or two and hour...well maybe a week or so.
three or more an hour ain't no bender...is just a drunk.
thats me take on benders other than get some sort of heat happening on a steel pipe....real simple eh!
blessings
duh Padma
