It is currently Tue Aug 19, 2025 7:41 pm
PostPosted: Sun Oct 31, 2010 4:47 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
I know there are a lot of varibles, but is there a weight range a braced top should come at based on type of soundboard used???
I just finished bracing a Sitka top for an OM , I used forward bracing with no popsickle stick, I preshaped the braces but haven't finished shaving and finishing them yet and the top came in at 278 g. The soundboard is around .100 thick and the braces are 1/4 inch thick.
Since I am in no hurry I thought I would collect some data on this one and try doing chladni patterns , which I don't have a clue what I will be looking at, then comparing weight to pattens etc.. ??...
any insight would be greatly appreciated.
MK5acoustics.com
PostPosted: Sun Oct 31, 2010 5:41 pm
That sounds quite heavy to me. And it sounds heavy for what you're describing. Did you weigh the un-braced top? I'm wondering if you have a very dense top or very large braces. How about a photo?
There's no right answer and no magic number but I would guess that most hand builders would be between 180 - 240 grams for an OM.
http://www.chassonguitars.com
PostPosted: Sun Oct 31, 2010 5:56 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
every thing is rough shaped at this point...I didn't weigh the top before bracing, but It seemed like a very stiff top board.
MK5acoustics.com
PostPosted: Sun Oct 31, 2010 6:45 pm
First name: Evan
Last Name: McCartney-Melstad
Might be helpful if you can measure the density of the soundboard wood from an offcut if you still have them.
Evan McCartney
PostPosted: Sun Oct 31, 2010 7:13 pm
Hmm, don't know what to tell you. You may be able to lose 20 grams by profiling the braces but that is probably optimistic. If that color is correct, that could mean you have a heavy piece of sitka. The darker stuff tends to be heavier in my experience.
Are you sure your scale is correct?
PostPosted: Sun Oct 31, 2010 7:51 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
ITs my trusty harbor freight 500 g scale...it seems accurate enough. The sitka is a little dark, and it did feel stiff I thicknessed ot to .100 and a little under that .095 or so depending where it is measured.
MK5acoustics.com
PostPosted: Mon Nov 01, 2010 12:31 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
First attempt at chladni
using computer speaker
freq 221
MK5acoustics.com
PostPosted: Mon Nov 01, 2010 1:02 pm
Most of my 000/OM size tops seem to run around 220-260 gm, with one closer to 270. It's hard to remove as much as ten grams of bracing without risk, I think.
That mode at 221 could be a ring+, but it's a little hard to say. Try moving your supports around so that they're right under the node lines. I don'tusually see that mode much below 230 on a steel string.
PostPosted: Mon Nov 01, 2010 2:19 pm
I'll look at the weight of my most recent top when I get home. I don't remember specifically, but I believe it was 248 gm.
PostPosted: Mon Nov 01, 2010 3:14 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
after shaping braces weight is at 269.5 g
chladni freq 217
MK5acoustics.com
PostPosted: Mon Nov 01, 2010 5:05 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Chladni as I thined braces... weight is 263.6g tapping is definately louder...observations greatly appreciated!!! idunno
MK5acoustics.com
PostPosted: Mon Nov 01, 2010 5:07 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
the photos in the last post are reversed the first one is when I finished shaving braces.
MK5acoustics.com
PostPosted: Wed Nov 03, 2010 11:04 am
First name: Chuck
Last Name: Gilbert
It looks like you're on the right track. FWIW, my most recent Sitka top was a Dreadnought that weighed 270g after final voicing and it taps beautifully - strong and clear. Thckness was about .112".
Good Luck!
Chuck
"To live a creative life, we must lose our fear of being wrong"
- Joseph Chilton Pearce
PostPosted: Wed Nov 03, 2010 5:55 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
now if I could just figure out what those chladni patterns mean!!!!!
MK5acoustics.com
PostPosted: Wed Nov 03, 2010 7:39 pm
Weight is another variable that is controlled to give the customer what they're looking for. Some players want a faster response, while others want more sustain. The weight of the top including the bridge is a big factor in this, with lighter tops being faster of course. Most of the weight is in the top, not the braces, so choosing a top of appropriate density and then determining the proper thickness offers the most control. The bridge is then the second largest factor as far as weight is concerned.
Randy Muth
RS Muth Guitars Website
RS Muth Guitars Blog
Facebook Fan Page
PostPosted: Fri Nov 05, 2010 9:40 pm
I've been having some problems posting to this thread: happens once in a while.
welewis wrote:
"now if I could just figure out what those chladni patterns mean!!!!!"
The Eternal Question.
Basically, the patterns are readings of the distribution of mass and stiffness in the plate. The shapes tell you a lot about how smooth and 'proper' that distribution is, and the frequencies give an indication of the ratio of stiffness to mass. Things like narrow node lines and well defined frequencies give a reading on the losses in the plate. There's a lot of interpretation involved, so a bit of practice helps. OTOH, this is stuff that can be posted as pictures and recorded for future reference, so it's easier to learn over the internet than, say 'tap tones'.
From what I can see you've got good patterns there. The 'ring+' is smooth, and at a decent frequency. It's often hard to get it to 'close' wth asymetric bracing, and that doen'st seem to be as important for the tone of the guitar as how smooth the pattern is. I'd say ship it.
Users browsing this forum: No registered users and 42 guests
