It is currently Wed Aug 20, 2025 12:51 am
 Post subject: Cutting wood binding
PostPosted: Thu Nov 11, 2010 8:39 pm
Last Name: Sterling
City: Ulster Park
State: New York
Zip/Postal Code: 12487
I have a couple guitars going that I want to put wood binding on. I would like to cut my own binding as I have alot of scrap figured wood. What is the process to get clean sides for the binding? I would like to here what others process is and the pros and cons. Thanks :mrgreen:
Mistakes are mandatory-learning from them is optional. http://www.opensourceluthiersupply.com
 Post subject: Re: Cutting wood binding
PostPosted: Thu Nov 11, 2010 8:41 pm
I use my fretsltting blade, a zero clearance insert, and a featherboard on the topside.
PostPosted: Thu Nov 11, 2010 8:51 pm
I use a Freud 7 1/4 blade on my table saw. Works great.
Wisdom is justified by her children
PostPosted: Thu Nov 11, 2010 8:54 pm
First name: Donald
Last Name: Kahny
City: guilford
State: iN
Zip/Postal Code: 47022
I cut on the table saw, then smooth with a thickness sander.
Don
PostPosted: Thu Nov 11, 2010 9:35 pm
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I cut to a little over 1/4 inch, Then drum sand to desired height, then rip strips a little over desired thickness then drum sand to desired thickness. I find I can pur 5 or 6 thru the sander at a time.
http://goatrockukulele.com
PostPosted: Fri Nov 12, 2010 3:14 am
Country: Romania
There was an informative and long topic about this not too long ago, worth a search.
Build log
