It is currently Wed Aug 20, 2025 5:53 am
PostPosted: Mon Nov 15, 2010 9:05 pm
City: winnipeg
State: manitoba
Country: canada
I am gathering materials to build a string bass and my plans call for two layers of 1/8" plywood for the body. I feel that this is a bit thick but the first try should stick with the plans.
I would hate to put the work into crummy materials but I tend to be too tight-fisted for my own good.
Does anybody have good sources or creative ideas?
Bob :ugeek:
PostPosted: Mon Nov 15, 2010 9:09 pm
Try Noah's. They supply boat builders and marine play is typically very high quality.
http://www.noahsmarine.com/
PostPosted: Mon Nov 15, 2010 9:29 pm
Windsor Plywood has it in Canada.
PostPosted: Mon Nov 15, 2010 9:34 pm
First name: Tom
Last Name: West
State: Nova Scotia
Lee Valley has 6 ply 3mm but it is only 25 "sq. It is Finnish. May be worth a look.
Tom
PostPosted: Mon Nov 15, 2010 9:47 pm
City: winnipeg
State: manitoba
Country: canada
Thanks for the replies.
Winsor plywood has been my normal wood source so far. I will pursue this with them.
Lee Valley is a definite potential source. I am building a Baroque bass so 24" square might just fit.
I had not thought of marine plywood before but I like the idea.
Thanks guys.
Bob :ugeek:
PostPosted: Mon Nov 15, 2010 9:49 pm
Last Name: Hodge
I'd also give Aircraft Spruce a looksee!
Bill Hodge
PostPosted: Tue Nov 16, 2010 8:29 pm
First name: Kent
Last Name: Fishburn
City: Woodstock
State: Illinois
I buy plywood for resonators at Wicks Aircraft supply. The metric birch is what I buy and is very good quality.
http://www.wicksaircraft.com/catalog/pr ... index.html
PostPosted: Wed Nov 17, 2010 11:14 am
City: winnipeg
State: manitoba
Country: canada
Aircraft plywood was my first thought but for the first go-around I think that I will go with my regular wood source if they have it. If this design sounds decent, I would like to use 45 degree aircraft ply when someone else is paying the freight and the instrument has a long potential life. The best that this version can expect is that someone will accept it as a gift.
I now have a better handle on sources.
Bob :ugeek:
