It is currently Mon Sep 15, 2025 4:06 pm
 Post subject: 6-String Bass Nut File
PostPosted: Wed Nov 17, 2010 5:09 pm
I've done a little looking and am having a hard time finding a nut file for a low B string on a 6-string bass (or 5-string). 0.135 For those of you who have built a 5-6 stringer, what have you used?
PostPosted: Wed Nov 17, 2010 5:44 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
One thing you can do for bass nuts, because strings are quite large... You can begin the slot with some file (I like triangle one, it's precise). File till maybe a 64th before you desired depth. Then, take 1'' or 2 from a string of the desired gauge, then glue it (CA) on a wood stick. You have a cheap file, exactly the size you need. It don't cut that much, but it's perfect to do the final slot shaping.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Wed Nov 17, 2010 9:33 pm
I use a .120 and roll it in the slot.
Old growth, shmold growth!
PostPosted: Wed Nov 17, 2010 10:58 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Or, use a round tapered jewelers file,
and stop when it's the same as the string gauge.
I like the other ideas too!
