It is currently Wed Aug 20, 2025 12:01 pm
 Post subject: Rockler Spray System $99
PostPosted: Mon Nov 15, 2010 6:34 pm
I was thinking about the Rockler spray system but couldn't find much info on it. I know it's rated very well but I was worried about the max air flow pressure. It says it is 4 psi. I don't know much about these (never sprayed before)...is that low or normal? I'm def. going to be spraying lacquer (most likely water based).
http://www.rockler.com/product.cfm?page ... ilter=hvlp
Bro. Matthew A.
Oklahoma
PostPosted: Mon Nov 15, 2010 10:05 pm
Last Name: Askins
City: Jonesboro
State: AR
I have used this for spraying water based finish and shellac. It is my first sprayer so I have nothing to compare it to but, I was impressed and it seemed to spray well for me. It is also easy to set up and use.
Chris
PostPosted: Sat Nov 20, 2010 10:43 pm
In case you didn't know, the exact spray system is sold at Harbor Freight. It's on sale atm for $75. You may be able to use a 20% off coupon on it as well.
http://www.harborfreight.com/high-volum ... 44677.html
Hope this helps someone!
PostPosted: Sun Nov 21, 2010 9:36 am
Last Name: Schreiner
City: Miami
State: FL
Zip/Postal Code: 33183
I have used the Rockler sprayer for a couple of years (shellac and lacquer). Works great! Make sure you clean the filter between guitars or it will overheat and shut down. Also the extra spray jar is a useful thing to purchase with it.
Michael
Users browsing this forum: doncaparker and 25 guests
