It is currently Wed Aug 20, 2025 7:38 am
PostPosted: Mon Nov 29, 2010 11:04 pm
State: ON
Due to the Lacey act restrictions on shell coming into the US I've recently been experimenting with different materials for fret board markers. I've been using recon stone for a while and like it in general, although there are customers who don't like the look. I know wood markers can be an option, but over time the markers begin to look dirty. I'm also looking into different metals that might work.
Are there other materials out there that I'm not thinking of? If you've used something different or are aware of something different please let me know. I'll soon have CNC capabilities which will be useful for cutting different shapes.
Josh
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Mon Nov 29, 2010 11:51 pm
I have used both brass and silver powders that I wick CA into. I have also used dyes with epoxy. I use a dremel to drill the shape I want.
Below are dog prints with silver powder
PostPosted: Tue Nov 30, 2010 12:27 am
I don't know what you'd need to do to sand it flush and polish it, but I bet glass would be pretty cool. You could maybe back it with white or chrome to show off swirly colors.
Mike Lindstrom
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
that is too cool.
PostPosted: Tue Nov 30, 2010 12:53 am
Last Name: Kincheloe
Hmm, how about bone? I don't think I've ever seen it used as an inlay material, but I can't think of any reason not to, aside from the difficulty of getting wide flat blanks from such curved things. But for normal dots it's not a problem, and it would probably look better than plastic at least, and be plenty tough. Ought to engrave nicely too.
I've also been pondering translucent materials like jade, backed with mirror foil, white paint, or light colored wood. Might be a pretty cool effect, or might look funky when you can see the sides of the pocket and depth of the inlay.
PostPosted: Tue Nov 30, 2010 1:34 am
First name: Stuart
Last Name: Gort
You might also look into tagua nut....a beautiful ivory substitute. Very nice stuff.
StuMusic
PostPosted: Tue Nov 30, 2010 1:36 am
Last Name: Smith
City: Graton
Zip/Postal Code: 95444
I personally like to look of shell and there is plenty of oyster, mussel, and abalone shell here in the states for us small builders.
http://goatrockukulele.com
PostPosted: Tue Nov 30, 2010 3:38 am
State: ON
Those are some neat ideas! I like the metal powder idea and I'll have to give the tagua nut a try. I had forgotten about tagua nuts but I'm sure I bought some a few years back. I just never used it. Glass, gems and bone are also interesting.
Michael, I also personally like the look of shell, however due to the US governments decision to start enforcing the Lacey act I am no longer using shell on guitars that I am shipping to the US (I live in Canada).
Josh
Josh House
PostPosted: Tue Nov 30, 2010 5:18 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Josh;
If you are thinking about metal, there are non-tarnishing silver & gold substitutes available at most jewelery & lapidary supply shops.
I really like using aluminum. Welding rod can be purchased form any aluminum fabricating shop & it comes in many sizes. Aluminum sheet stock can be sliced into narrow strips (using a shear) making square or rectangular wire which inlays beautifully. My number 2 guitar has an aluminum inlay in the peghead. After nearly thirty years, it still looks fine & there is no indication of de-bonding.
Aluminum sands at the same rate as hard woods like ebony, so is no trouble to level. The dust looks horrible when you're sanding, but clears out of pores with a good wipe with naptha or mineral spirits. Epoxy seems to work very well, if you sand the aluminum with 220 to get some good scratches in it.
I haven't tried it in softwoods yet. It might be an issue if the dust was ground into top wood.
PostPosted: Tue Nov 30, 2010 5:25 am
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
P.S.
I posted this pic a couple of weeks ago, so sorry for the repeat...
The fingerboard in the pic is inlayed with aircraft aluminum (2024 T-3 "Alclad") I cut into thin strips, using a metal shear. The hard aircraft aluminum works better than the softer commercial material.
PostPosted: Wed Dec 01, 2010 8:26 am
State: ON
Thanks for the tips on the metal. I will certainly check that out.
Josh
Josh House
PostPosted: Wed Dec 01, 2010 9:36 am
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
I like them naked.
And for the record, while silver will tarnish, gold will not. Ever. Unless, maybe, its full of impurities.
http://redrivercanoe.ca/
PostPosted: Thu Dec 02, 2010 11:36 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Daniel, nice!!!
I might use alum for lap steel git frets.
I got some malachite cabashons, flattened them out and used those as fretmarkers once.
Turqoise was a thought.
Skys the limit.
Bloodwood?
Users browsing this forum: Chris Ensor and 18 guests
