It is currently Wed Aug 20, 2025 6:58 am
 Post subject: Fingerboard oil?
PostPosted: Fri Dec 03, 2010 3:59 pm
Last Name: Ulman
City: Bellevue
State: Washington
I’ve heard some conflicting advice on this subject and would like to get some clarification. I was planning on using linseed oil as suggested by Michael Thames on his youtube video entitled: The bridge part 4 ( polishing fingerboard and frets); but then read recently here that this is not recommended:
Quote:
Boiled linseed oil is hygroscopic. Oiling a fingerboard is not needed and not recommended. If you feel you need to do this a few drops once a year is more than enough. Your body oil from playing is all that the board needs. Martin used to use 3 in 1 oil to condition a new board but now use Ax Wax.
Wood will shrink from lose of moisture or expand from absorbing moisture in relation to the RH. Keep the instrument hydrated with a humidifier for best results. They don't cost much and can save in considerable cost for damage repair. All ebony that I saw cracked usually cracked because of neglect …
Are there other reasons besides expansion/shrinkage due to RH changes for not using linseed oil on ebony fingerboards? It seems there are sources of information that contradict hygroscopic properties of linseed oil, e.g. Wikipedia:
“Most applications of linseed oil exploit its drying properties, i.e. the initial material is liquid or at least pliable and the aged material is rigid but not brittle. The water-repelling (hydrophobic) nature of the resulting hydrocarbon-based material is advantageous”
“…and [boiled linseed oil is] used in place of epoxy to seal modern wooden surfboards.”
Am I missing something here? Are there any better alternatives to linseed oil? Thanks for any clarification.
Joe
 Post subject: Re: Fingerboard oil?
PostPosted: Fri Dec 03, 2010 4:16 pm
I have used boiled linseed oil on all my les pauls since 1970 and they are all as pristine as the day i bought them. No cracks on the ebony boards. It has worked very well for me. I coat the board real well and let sit for about 5 minutes, then wipe off as much as i can with a clean rag. I do this every 6 months. I guess others have different ways to keep there boards maintained.
PostPosted: Fri Dec 03, 2010 4:20 pm
PostPosted: Fri Dec 03, 2010 5:14 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
I suggest you go to
http://www.beafifer.com/
and scroll down (on the left hand side ) to "Fret Doctor" and read all the info there.
that should clear up any questions you may have.
PostPosted: Fri Dec 03, 2010 6:10 pm
First name: Brad
Last Name: Radtke
City: South Haven
State: Mi
Zip/Postal Code: 49090
I had a short work experience at Wechter guitars before going to Galloup School of Lutherie. At the time Wechter used linseed oil. I use it now and haven't had any problems but time will tell.
PostPosted: Sat Dec 04, 2010 9:52 pm
Last Name: Ulman
City: Bellevue
State: Washington
Thanks Mark, Zach, Murray and Brad. This is my first guitar and your feedback is very helpful.
Joe
PostPosted: Sat Dec 04, 2010 11:57 pm
First name: Francis
Last Name: Richer
City: Montréal
State: Québec
Zip/Postal Code: H4G 2Z2
I like lemon oil for the FB.
Francis
Francis Richer, Montréal
Les Guitares F&M Guitars
PostPosted: Sun Dec 05, 2010 12:50 am
First name: Mitch
Last Name: Johnson
City: Little Falls
State: Minnesota
Zip/Postal Code: 56345
I use Formby's Lemon Oil. They selll it at Ace Hardware (not sure if Ace is a nationwide chain), but I'm sure you can get it lot's of places. It works well. The guitar tech at the music store I used to work at swore by it and he was pretty darn good at his job. Also the Build up remover is good for cleaning guitars. Doesn't damage finish and doesn't have silicone. It's a little smelly but much better than Naptha. No headache or fumes either!
PostPosted: Sun Dec 05, 2010 1:07 am
First name: Heath
Last Name: Blair
City: Visalia
check this out:
viewtopic.php?f=10101&t=23523&hilit=fingerboard+oil
sweat the small stuff.
PostPosted: Sun Dec 05, 2010 1:22 am
First name: Mitch
Last Name: Johnson
City: Little Falls
State: Minnesota
I just finished loading on some mineral oil onto a cutting board (very food safe). I've used it on lots of stuff. It works well and you can still eat off your fingerboard when your done. laughing6-hehe
I have heard that walnut oil can go sour after some time..If I recall its a couple of years of sitting on the shelf.
Users browsing this forum: Chris Ide, PGrubb and 41 guests
