It is currently Wed Aug 20, 2025 4:53 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
PostPosted: Sun Dec 05, 2010 8:13 pm
I don't think so Murray. I was assuming at first that Paul meant the style you show, but following the thread believe he's talking about cam clamps.
PostPosted: Sun Dec 05, 2010 9:06 pm
First name: Mark
City: Concord
If the pins are too soft get some O1 tool steel drill rod the same diameter as the pins from an industrial supply house (MSC, Enco, McMaster-Carr, Wholesale Tool, etc). Cut the rod to the length you need, heat them with a torch to the point a magnet will not attract them, quench in old motor oil and replace the pins. A 36" section of 1/8" rod costs less than $3.00.
PostPosted: Sun Dec 05, 2010 11:47 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Maybe I used the wrong term.
I'm talking about a wood cam clamp like this
P A U L B U R N E R
Burner Guitars
PostPosted: Mon Dec 06, 2010 6:44 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
or, to be totally accurate, like these ?
PostPosted: Tue Dec 07, 2010 5:10 pm
Last Name: Ellis
City: Manteca
Zip/Postal Code: 95337
I have the shop fox cam clamps and out of all the ones I bought I only have one that has a "too tight" cam (i.e. the cam won't engage), but with a bit of flossing with sand paper, I'm sure it would be fine.
I do like the idea of adding a little extra - groves in the bar - to make them more grippy. Mine grip fine, but I like the term "grippy".
PostPosted: Tue Dec 07, 2010 5:16 pm
Last Name: Ellis
City: Manteca
So I just ran a quick experiment. I took my dremel with a cutting wheel and just spent 3 minutes putting small groves in the bar. The performance of the clamp improved considerably. With a bit of extra time and putting the groves at closer intervals (i.e. 1/8), I could have clamps that function as well as the more expensive cam clamps with just a bit of time.
Try it for your self and see if you don't see the improvement.
PostPosted: Tue Dec 07, 2010 5:25 pm
Last Name: Burner
City: Lincoln
State: Nebraska
Thanks Steve - I'll give it a try.
P A U L B U R N E R
Burner Guitars
