It is currently Wed Aug 20, 2025 1:33 am
PostPosted: Sun Dec 12, 2010 2:22 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
I'm going to add a second heating blanket to my bender, so that I can go to a
blanket/slat/wood/slat/blanket stack to get more uniform heating of the wood.
I use a PID controller with a thermocouple and relay to drive the single blanket
I use now. Can I use the two blankets in series, or am I better off to add a second
relay (which will require some shoehorning to fit in my PID box).
Gene
PostPosted: Sun Dec 12, 2010 4:12 pm
don't go series use a parallel circuit .
PostPosted: Sun Dec 12, 2010 5:39 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
As long as the total amps are not greater than what the relay can safely handle, and as John says, parallel the blankets.
Fred
Fred Tellier
PostPosted: Sun Dec 12, 2010 6:49 pm
First name: Stuart
Last Name: Gort
Yeah....as long as the combined amperage of the blankets doesn't exceed the amp rating of the relay you can run as many blankets on one relay as you want.
Do you know the amp draw of your blanket(s)? You may find markings on the blanket that says 5w or 10w....which will be watts per square inch. Take that times the square inches of the blanket and then divide by 120(volts) to get the total amp draw of the blanket.
StuMusic
PostPosted: Mon Dec 13, 2010 5:28 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
OK, Thanks!
They are both John's 6" x 34" blankets, which are 5 watts/in*2. So that should
give me 3.4 amps draw. I'll check my relay, I think it was good for at least 10 amps.
Gene
PostPosted: Mon Dec 13, 2010 5:46 pm
gozierdt wrote:
OK, Thanks!
8.5 amps?
PostPosted: Mon Dec 13, 2010 5:54 pm
I think Alan is closer if they are 5W per sq in. (6 x 34 x 5)/115 = 8.8, better check with John to make sure.
PostPosted: Tue Dec 14, 2010 12:33 am
First name: Stuart
Last Name: Gort
Yeah.....dividing by 120volts.....that's an 8.5 amp blanket.
6 x 34 = 204 sq. in.
204 x 5 = 1020 watts
1020 / 120 = 8.5 amps
StuMusic
PostPosted: Tue Dec 14, 2010 10:44 am
First name: Gene
Last Name: Zierdt
City: Sebastopol
Oops, my bad [headinwall]
You're right, 8.5 amps each, 17 total. So I'll need at
least a 20 A relay.
Thanks for the correction...
Gene
PostPosted: Tue Dec 14, 2010 12:31 pm
Look at all the Math wiz kids LOL / I want to add one thing about 2 blankets . Remember that wood is stupid and will bend when it gets hot . With 2 blankets you will have a heavy thermal mass. Watch the heat carefully so you don't scorch. Moisture will help but too much can be worse than not enough .
Wood is thermoplastic and will bend when the proper temp is reached . I bent over 200 sets this year. Lost 3 . 2 were high figure maple and one a lower end BRW . I have seen this method before and I know it will work but the pitfalls are scorching . Methodology of the bend process is equally important . Think PRESSING not bending .
Good luck and keep us posted , we all like to learn new things .
PostPosted: Tue Dec 14, 2010 5:07 pm
First name: Gene
Last Name: Zierdt
City: Sebastopol
John, et al,
I appreciate your comments. And I'm laughing at myself for the math mistake. Been too many years
since either math or electrical engineering classes. laughing6-hehe It's the pits getting old gaah
I want to try out the double blanket approach because I've had some buckling problems on several
highly figured woods. It seems to me that if I can control the heat, getting the whole wood mass
-especially both sides, up to equal temperature should help with more even bending. When bending
on a pipe, the compression side of the wood is always the hottest. I think that helps prevent buckling.
So if in machine bending I can get both sides to the same temperature it should help, since both sides
see both tension and compression. I've got the PID controller, so I should be able to control the temperature
pretty well- I'll watch it especially carefully until I get it dialed in. And I've wanted a spare blanket anyway,
in case the one I have dies on me.
Gene
PostPosted: Tue Dec 14, 2010 6:09 pm
keep us posted . I am sure there is a lot of interest on this .
Users browsing this forum: Bing [Bot] and 25 guests
