It is currently Wed Aug 20, 2025 4:00 pm
PostPosted: Sat Jan 08, 2011 3:29 pm
Last Name: Tulloch
State: Vermont
I want to start a Gibsonesque J-45 type, and have the Michael Collins drawn J-45 working plans. It specs the side thickness at .125 which seems rather thick, having gone to .090 in the past. Thoughts on sides this thick......impact on sound. ?
I'm willing to try this if it makes any sense in any direction.
Much obliged....Michael
PostPosted: Sat Jan 08, 2011 4:07 pm
I wouldn't think much impact on sound, but .090 would bend alot easier. I keep mine at around .090 or less depending on the wood i'm bending.
PostPosted: Sat Jan 08, 2011 4:27 pm
0.125 seems way too thick ever for sides. I'm usually 0.75-0.85 depending on the body size and wood. Thats off the thickness sander, so a bit comes off to get the 80 grit mark off, then a bit for trueing up the sides before binding. But I tend to build light.
PostPosted: Sat Jan 08, 2011 5:47 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
From the early-1950's through 1969, the J-45 (and most other mahogany Gibsons) had laminated sides. They were 3-ply, with all mahogany plies.
PostPosted: Sat Jan 08, 2011 7:30 pm
Last Name: Tulloch
State: Vermont
Ah...there's the light. Thanks John.
PostPosted: Sat Jan 08, 2011 8:57 pm
First name: Hugh
City: Lake Oswego
State: oregon
I built a j45 mahogany a few months ago, sides at .80. It worked well.
PostPosted: Sun Jan 09, 2011 11:01 am
Not sure where you heard that Todd - but - some of my early guitars - 8-10 years ago - had sides that were around 100 .. but then I thinned to 90 for a bit, and now 80-85 for the last 4-5 years .. I see no reason to have sides that thick - 125 range.
PostPosted: Sun Jan 09, 2011 7:34 pm
Last Name: Cox
If you decide to do one out of plain, straight grain Maple - which is pretty common on vintage Gibsons..... 0.125" thick will likely bend just fine - and give you nice stiff sides.
If mahogany - stick with a "Standard" thickness Mahogany for side bending.... it goes much better that way.
Users browsing this forum: doncaparker and 18 guests
