It is currently Sun Sep 14, 2025 11:28 pm
PostPosted: Sat Jan 15, 2011 2:06 pm
First name: Eric
Last Name: Slayton
City: Huntington
State: WV
Zip/Postal Code: 25704
I'm putting all-new electronics in an old Kay I found almost literally laying on the ground. Idk if it was of any value initially or not, but either way, its not now haha.
I need pickups that will fit the pickup cavity which i measured at a massive 3.75x1.6in. So if anybody has any knowledge of Kay guitars or of pickups and DIY-ing that could help, please share. I'm ok if it looks a little homemade (e.g. pickup is too small but we rig it up somehow). I'm concerned about fitting the pickups, the pole-pieces at the right width, setting the archtop bridge, among other things...
Thanks!
PostPosted: Sat Jan 15, 2011 9:26 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Pics?
PostPosted: Sat Jan 15, 2011 11:18 pm
First name: Eric
Last Name: Slayton
City: Huntington
State: WV
I have solved my pickup problem...(apparently there was just an error in measurement all along...lol). But that leaves me with the bridge. How do you go about fastening it? Is it just glued on?
PostPosted: Sun Jan 16, 2011 12:43 pm
It should just be a floating bridge Eric with only string pressure holding it down. No need to glue.
PostPosted: Sun Jan 16, 2011 4:31 pm
First name: Eric
Last Name: Slayton
City: Huntington
State: WV
Oh ok I see.. that makes senese because the tailpiece will keep the strings alligned anyways, right? Which should make the bridge line up after every string change... ? Or am I wrong
PostPosted: Sun Jan 16, 2011 7:57 pm
That's right Eric, assuming your neck and tailpiece are true to the guitar centerline. The bridge will follow this centerline. Most people change strings one at a time so that the bridge doesn't have to be measured and set for scale and intonation every time you change strings. Do you have the original bridge or Will you be making or buying one?
PostPosted: Mon Jan 17, 2011 2:13 am
First name: Eric
Last Name: Slayton
City: Huntington
State: WV
I have both the original and a new one.. the original is all wood, and the new one is modern. It would be cool to examine the differences in tone with both bridges don't you think?
Oh, and I'm going with a p90 in the neck and a jazzmaster in the bridge... should be awesome!
