It is currently Wed Aug 20, 2025 8:00 pm
Post new topic Reply to topic  [ 91 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Sat Jan 22, 2011 9:13 am
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Ed Haney wrote:
Arnt Rian wrote:
For many players, if the high E too close to the edge of the fretboard, or the frets rounded over with a too large radius, its going slide off the fret when they bend the string or do "sideways" vibratos. Its very annoying. For someone with a playing style that does not include these techniques, it might not be such a big problem.
A few notes:
- "if the high E is close to the edge of fretboard" - then a mistake has been made by the builder.
- Custom builders should know their customers (players) and take into consideration their specific customer's playing style to determine edge spacing needed. My guess is that this is seldom done. The factories solve this by "idiot proofing" the edge space so they get zero string-roll-off complaints by putting more space there than is needed not only for "many players", but more space than is needed for almost all players in this player's opinion. After all, the factories want zero complaints. Many factories use 1/8" from the center line of the string to the edge of the nut. This is more space than is needed for almost all players. It is an "idiot proofed" amount of space. Many custom builders carry on this same 1/8" tradition when it is a waste of real estate in this writers opinion.
- if 0.030" or 0.040" or so can be shaved off each edge (usually, but not always doable), then a total (2 edges totaled) of 0.60" to 0.80" can be put back between the strings. This is significant and will prevent some muted string mistakes or alternately allow a player to use a smaller nut width if he so desires. I seem to be alone in thinking that this is significant. Yet this space named above is often greater than the change from a 1 11/16" nut to a 1 3/4" nut which people do seen to get excited about.
This may have been discussed previously on the forum, but I have not seen it. If builders reading this are using 1/8" spacing from the string center line to the nut edge, I am wondering: 1. Have you thought this through? 2. Exactly why have you settled on this spacing number?
Ed
Post of the year, so far.
PostPosted: Sun Jan 23, 2011 12:24 pm
Ed Haney wrote:
A few notes:
Ed
In my experience when I go to 7/64" many players will find the high E too close to the edge. At 3/32" or less as you suggest, most players will. What is so great about having more room between the strings but less room at the outside, or about having steeper fret ends? If a player asks for it, she can have it; most don't like it.
When you find yourself alone in thinking something is significant, you may be the lone person who has it figured out correctly, but you have good reason to think again.
PostPosted: Sun Jan 23, 2011 1:59 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Howard, would it not be reasonable to assume that when you go to 7/64" or less, the reason why your clients don't like it is because you are using a conventional 30 degree bevel on the fret ends ? This would of course increase the likelihood of string slippage off of the fret ends.
But maybe, just maybe, if it were possible to gain the extra few thou which Ed is talking about and still have the frets feeling good, and maybe, if the fretboard taper were to be increased slightly to allow for extra width further down the board, then there could be a bright new dawn in playability ?
As we say in Scotland, "the proof of the pudding is the preeing o't" so as I was intending to refret one of my guitars next week anyway, I will incorporate a new nut, Ed Haney style, do the frets in semi-hemispherical fashion, and see what the end result plays like.
btw,
.....Ouch ....
PostPosted: Sun Jan 23, 2011 2:47 pm
City: Fort Meade
Zip/Postal Code: 20755
Todd Stock wrote:
Hemisphere and semisphere both name a half sphere; however, semi- has more recently picked up an additional contemp usage as 'partial' or 'less than', so rather than 'quarter-spherical frets', perhaps the intent with 'semi-hemi' is 'not quite a hemisphere'
Or maybe it's like parabolic bracing...more evidence that we did not pay close enough attention in math class.
I would like to point out that when viewed from the top (instead of profile view), it is indeed semi/hemi spherical [headinwall] Just saying...
PostPosted: Sun Jan 23, 2011 3:21 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
Uuhh, not really.
When viewed from the top, the fret end can be described as semicircular, but definitely not semi/hemi spherical ...
PostPosted: Sun Jan 23, 2011 9:54 pm
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
Howard,
Your experience is different than mine. The factory maker, Taylor, makes about 40,000 or 50,000 guitars per year and they use 3/32" (.094") spacing from center of high e string to the edge of the nut. I would expect their owners to be complaining on the Internet if most players found this too close. I recognize that that does not negate your experience.
When fretting a note, especially bass notes, if one looks at the clearance between the fretting finger and the adjacent string, very little space is left. If one adds 10, 12 or even 15 thousands to this clearance space the percentage increase is significant, allowing for a reduction of muted sting mistakes, especially for large-fingered people. This is what is so great to me. I get this without having to increase my nut width. Some players like the feel of a 1 3/4" nut but do not like 1 13/16". I can get a 1 13/16" string spacing on a 1 3/4" nut if wanted.
I am not trying to sell you. Folks that are happy with 1/8" or more edge space and think that is needed by most players is fine. [uncle]
Ed
PostPosted: Sun Jan 23, 2011 11:23 pm
First name: Josh
Last Name: Duke
City: Bonners Ferry
State: ID
Zip/Postal Code: 83805
Just wanted to point out that while 40,000-50,000 guitars a year is a lot to put out without much complaint of strings sliding off the edge of the fret, Taylor is well over the 100,000 per year mark at this point. I think Bob Taylor said that they average a guitar every 23 minutes of production time. Insane.
Finally escaped The Peoples' Republik of Massachusetts; I can smell the freedom in the air!
PostPosted: Mon Jan 24, 2011 8:54 am
City: Fort Meade
murrmac wrote:
Uuhh, not really.
Seeing as there is no official word for a quarter of a sphere, the terms "quarter sphere" and "semi sphere" have been used in the past to describe it. A semicircle is 2 dimensional, but the end of a fret is definitely 3 dimensional. laughing6-hehe
PostPosted: Mon Jan 24, 2011 8:56 am
City: Fort Meade
Don't think I'm up to explaining the difference between plane and solid geometry tonight.
You are correct, need to differentiate plane and solid geometry. So it should be "quarter sphere" or "semi sphere".
PostPosted: Mon Jan 24, 2011 9:38 am
Hemi, demi, semi, sheminy, jiminy.
Does somebody not understand what we are looking at, or is this not just argueing semantics? (uh-oh, I do hope I have used the correct word!!)
Perhaps we should start a new Nit-Pickin' section in the forum, no? beehive to include Parabolic bracing, compound radius fret boards, tantallones etc..
Is it constructive to agrue definitions or the correct usage of descriptive terms, as long as what we are talking about is understood or commonly used, even if not actually perfect?
Or am I missing something? Maybe just not so clever I suppose.
[uncle]in advance!
PostPosted: Mon Jan 24, 2011 9:58 am
City: Fort Meade
[uncle]in advance!
Right, back to the topic. It seems more aesthetics than anything else.
PostPosted: Mon Jan 24, 2011 10:39 am
Is it just me, or am I the only one more interested in whether these fret ends represent something that players will prefer over what we call them? The precise geometric vocabulary seems to have taken priority over what we should be discussing. How about a compromise...they're rounded...not tapered...let's move on!
I've concluded, based on a relatively small sampling, that most players prefer the tapered. I believe that Howard came to a similar conclusion with probably a larger player population. I'm not planning to force or convince potential clients that rounded are better but only show that I am capable of doing same should they be interested.
On the topic of the distance of the edge of the FB to the E and e strings...about half of my player sampling likes the 1/8" distance and half prefer something slightly shorter.
So what is the experience of others? Has anyone actually convinced players that rounded are better...how did you sell the benefits? Did they go through a learning curve...and how long did it take until they became enamored with the new style?
Then we'll have some real useful info IMO!
PostPosted: Mon Jan 24, 2011 11:10 am
Good discussion. I have been a member of the slavish 1/8" crowd and, to be honest, just hadn't given it any thought. Thanks to Ed for bringing it up. Another good detail to consider.
As far as the semi-hemispherical ends go, I have recently started to not fully round off the ends but leave part of it flat. It still looks and feels good after polishing but leaves a few more thou of the full fret available. Looks like I was already headed in the right direction.
PostPosted: Mon Jan 24, 2011 11:40 am
First name: Stuart
Last Name: Gort
TomDl wrote:
I was wondering if anyone cuts frets with CNC, and how well that works. I get nervous when I see that much wood needing to be removed with that small a bit.
I spent a lot of time setting up the cnc to address as much of the shaping of the frets as possible. Fret slots are cut with a cnc using a .023” end mill. They are all cut to an exact length to create a faux bound fretboard.
viewtopic.php?f=10106&t=26579
This pictures a holding fixture that is used in lieu of a fret nipper to do two things: 1. Create a very flat "nipped" surface of each fret, 2. Create a fret tang that is the exact length required for each fret slot…not to help the frets line up but rather, to maximize the amount of slot/tang area for an optimized grab
I made another similar fixture that holds the nipped frets upside down and facilitates the machining of the fret ends as well as establishing the exact length of each fret after bending to a 10” radius. This may seem very elaborate but the upside is that any shape can be programmed for the fret end….and I’ve tried many. I can shape the base of each fret end to have small rounded corners which would be very difficult to achieve another way. The downside is that when you pre-shape the fret wire, placement of each fret into the fretboard becomes critical. It is quite difficult to line them up such that looking down the fretboard doesn’t reveal even subtle imperfections in the line up. I made an edge tool that helps align the frets as they are installed. This got me 99% of the way there but using the tool requires some craftsmanship. I prefer to endow my tooling with craftsmanship so as to eliminate the need for it in my hands. This idea will need some revision but I can see it will work with more effort.
If one can place frets perfectly and avoid any serious sanding of the edge of the fretboard after the frets are installed, then the upside is that the fret ends can have any shape, be perfectly consistent from fret to fret, and can be fully polished prior to installation. On my last guitar I had to sand a little on the fretboard edge and that forced a little reshaping of a few fret ends. Not too bad as a concept but it can be improved.
Having done many shapes I can say that I don’t like playing a semi-spherical shape as well as a typical 30 degree bevel. With semi-spherical ends there is a pervasive "nub" feel as the hand slides past which drives me to distraction. I settled on a shape that starts with the 30 degree bevel and shaped it to have a little more edge rounding than the illustration Todd published. I play a lot of lead and like this shape best. As far as bending the string off the fret end and expecting the shape to have a profound effect on how that goes, I would respectfully suggest bending the string in the other direction. :)
StuMusic
PostPosted: Mon Jan 24, 2011 12:47 pm
I am using 1/8" from the edge of the string to the edge of the neck, not centre to centre, which means the low E string is a bit more offset. And yes I have given it some thought and settled on what feels right as my standard set-up. I have been requested to use as much as .140", and as little as .100" clearance, some players really know what they want.
Traditionally the fretboard flares out a bit more than the strings path, the 12th or 14th fret (depending on the body style) should be the same width as the bridge string spacing. Again, some (rare) players require more space there, as it is much easier to fret out in the middle of the strings' length where tension is the lowest.
I think those preferences are technique dependent. For example, some players like to use the left hand thumb to fret bass notes Jimi style (I do) and with too little clearance it is easy to fret out on the low E string, especially with light strings. A player who uses a lot of pull-offs will find it easy to fret out as well with too little clearance on the outer strings.
Finally I bevel the edges of the fretboard very slightly, following the fret bevel, so semi-hemispherical frets are a non starter for me. Same reason: if you play with the left hand thumb a lot, a sharp fretboard edge is extremely annoying.
Laurent Brondel
West Paris, Maine - USA
PostPosted: Mon Jan 24, 2011 2:50 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
It would appear to me to be totally feasible to install semi-hemispherical frets and subsequently bevel the edge of the fretboard in between the frets.
Time-consuming, perhaps, but eminently do-able.
PostPosted: Mon Jan 24, 2011 3:07 pm
It would appear to me to be totally feasible to install semi-hemispherical frets and subsequently bevel the edge of the fretboard in between the frets. Time-consuming, perhaps, but eminently do-able.
Do-able, sure. But too much real estate would be lost I would think: the semi-hesmispherical frets have to stop .010" to .020" before the edge, itself losing perhaps .020". Whereas with bevelled frets, the bevel follows the bevelled edge.
Laurent Brondel
PostPosted: Mon Jan 24, 2011 4:28 pm
Wow, what an interesting discussion this has turned into.
Hey, just wanted to let those who are interested know that I posted a tutorial in the tutorial section on my way of making rounded (semi-hemispherical) fret ends.
I think I'll ask the question of beveled fret end or rounded fret end on the Acoustic guitar forum to see what the players think?
PostPosted: Mon Jan 24, 2011 8:59 pm
Good idea, Rod. I'm actually surprised at the lack of experience or feedback with rounded fret ends here from the builder section. Could it be that this feature is a solution to a non-existent problem?
PostPosted: Mon Jan 24, 2011 9:26 pm
Right-on Rodney! Now that's a nice straight forward approach I can appreciate!
I will try this method for sure!
I love the look of these rounded fret ends. As far as having less than 1/8th goes, I don't know. Maybe for others, it's a non-issue, but for me, I like having that extra real estate less my vibrato-folly gets the best of me. On my last guitar, I bevelled and rounded the corners, as Filippo mentioned and I love the feel. My fret boards are slightly bevelled as well. I think I went the standard 5/32 for big E spacing to the Edge and I have a large string spacing (the nut being 1'' 27/32) and I have no problembs wrapping my thumb around to grab some notes on the A string...
PostPosted: Mon Jan 24, 2011 9:43 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
In fact, string setback further up the neck is much more important to most players than at the nut. Certainly, many factories use a 12-fret fingerboard width that is equal to their string spacing at the saddle, but generally I think this is excessive for most players (someone called it "idiot proof"). You need more setback up the neck, but most don't require that much more. It was one of the first specs I changed on my own guitars, because I don't like the excessive setback on the necks of my Martins.
The different taper rates defined by different nut and saddle string spacing ratios mean that there are no good rules-of-thumb for fretboard taper -- it needs to be reverse calculated given the player's preferred setback up the neck. The calculator for fretboard taper and string setback that I just posted here http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=30835 was spawned by attempts to reduce the normally excessive setback in a calculated way and is helping me design fret board specs for players' requirements.
PostPosted: Mon Jan 24, 2011 9:53 pm
First name: duh
Last Name: Padma
Real estate, B.S., shape em so it feels good.
Remember...
"if the feelin ain't right, sooner or latter it'll drive you crazy"
~ Crosby Stills Nash and Young
Real estate.. my ask. pfft
blessings
duh Padma
PostPosted: Tue Jan 25, 2011 11:28 am
Here are my deep-seated thoughts on this, as a player...
I prefer as vertical a fret-end as possible, and a semi-hemi treatment can be a great way to do this.
I am *very* concerned with wanting all the distance I can get between the E strings and the edges of the fingerboard...more so on the high E...although I like good space on both. Addressing this with the fret edge finish is a good start. Most fret-edges do lose too much for me with anything but a very vertical (or semi-hemi) finish.
...but this is only the beginning of the conversation with me...
Rather than give you the "inset" numbers I like, however, I prefer to just give full set-up...because it also involves the overall width of the fingerboard/neck at the 12th fret.
Lay these numbers out, and I think you'll be surprised:
1) Overall nut width = 1-13/16"
2) E-to-E nut spacing, center to center = 1-1/2"
3) Bridge spacing = 2-1/4"
4) Overall width of 'board @ 12th fret = 2-5/16"
The biggest surprise may be the 12th fret width, especially vs. the bridge spacing...I like a wiiiide number there, and I have never seen any builder use a 12th fret width wider than the bridge spacing...but that's exactly what I want.
The other surprise is that the nut-spacing is about middle of the road for a narrower 1-3/4" nut. Well, these are the numbers I like, and they give a certain symmetry to the strings in relation to the edges of the fingerboard...all up and down the board.
Place the bridge (and the nut) so that the E-string centers are equidistant to the edges of the fingerboard, and with the above numbers you've got my "inset"...and that inset will get even a little deeper as one goes up the neck.
So that's one crazy-man's perspective on this....hard-won information that *I* think makes a guitar more playable (and it does, at least for me!)...greater possibilities in attacking the high E string, side-to-side vibrato, just a more comfortable overall feel....again, IMO.
I believe that the overall 12th fret width should be, at the very least, the equal of the bridge spacing. Some guitars are built this way, but not a lot of them.
...and if a few builders would take the chance on my wild concept that a wider-than-bridge-spacing overall-12th-fret-width is not only possible but *desirable,* well, then more players would get a chance to try this configuration. I predict that many, many players would love the way this feels.
Okay, hope this gives folks something to think about...
LP
LarryPattis.com
AmericanGuitarMasters.com
PostPosted: Tue Jan 25, 2011 11:34 am
Filippo Morelli wrote:
On the last couple guitars I have been beveling the frets at 30, then rounding the edges with the diamond fret file during leveling. I suspect many folks do this? Anyway it does not give the look of the semi-hemi-quarter-spherical frets, but I find the fret end smoother than when they are otherwise finished. I also round the fretboard, per Laurent's comments.
Filippo
I did exactly this on #2 and it's a dream to play.
PostPosted: Tue Jan 25, 2011 12:23 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
I do the same thing Filippo describes. My fret edge file is angled at 15 degrees, so a bit steeper initial angle than Filippo's. To make filing the rounded fret end easier & prevent scratches in the fingerboard, I filed about .040" off the edges of the SM diamond fret file & smoothed the filed surfaces out to a nice finish.
Now I can file a nicely rounded end without leaving any marks in the fingerboard... While minimizing the lost real estate issue.
As Larry Pattis mentions, the edge distance at the nut is not as important as it is further up the neck.
Users browsing this forum: J De Rocher and 26 guests
