It is currently Wed Aug 20, 2025 8:07 pm
PostPosted: Sun Jan 30, 2011 9:15 am
First name: Sean
Hey all,
Per directions to using KTM9, after my first day of spraying I drop filled with gel ca glue some gaps. After sanding with 600, I have white blush marks from the ca glue. Alcohol will not remove it. Can I use acetone? I know it will remove it, but will it affect the water based finish of ktm 9?
Sean
change isn't synonymous with improvement
instagram.com/bucketguitars/
PostPosted: Sun Jan 30, 2011 10:55 am
What CA brand did you use? Sometimes the drop fill will look different than the finish because of the different way the sandpaper scratches the finish and the fill. You could wipe as much of the blush as possible and then put a little finish over a small section to see if it goes away. But it might just be the brand of CA you used. It's always good to have pictures to help solve your problem.
Ken Franklin
clumsy yet persistent
Users browsing this forum: Bing [Bot] and 18 guests
