It is currently Fri Aug 22, 2025 10:35 am
PostPosted: Sat Feb 05, 2011 11:17 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Hi all!
i don´t have any experience with electric tools in luthierie (as the more wise upon you, by virtue of the question above, may by now have noticed :) ) and hence, in the "there are no stupid questions, just stupid answers" vein, i´m trying to figure out what´s the main difference between a laminate trimmer and a router.
i understand that a LT seems to be smaller and thinner, but that´s it. from what i´ve gathered, i understand both have their place in guitar building, but are they, for instance, mutually exclusive ? as a 1st tool, would i be better with or or the other? or is it "horses for courses"? ok, i´ll stop here, too much questions are... leaving me... breathless....
thanks in advance for your time...
cheers,
Miguel.
PostPosted: Sat Feb 05, 2011 11:38 am
Well, they are all routers first off. A laminate trimmer is just a smaller router than most others, or it's classified as a hand held router, not a two handed router or a router that is mounted in a router table.
The second difference is that a LT is less powerful than a full size router, so you won't be spinning a 2-3" raised panel bit with it. But a full size 3-1/4hp router in a router table would get the nod for a bit like this.
The third difference is that the full size router will be able to take bits with either a 1/4" shaft or a 1/2" shaft (which generally is again used for larger bits). The LT will only take 1/4" shaft bits this is in North America, metric LT's will need metric bits or an adapter collar for the imperial sized bits.
Now, for most things (like 99.9%) in luthiery, you don't need a full size router and a LT will work just fine.
PostPosted: Sat Feb 05, 2011 11:45 am
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
A laminate trimmer is just a small router and they were originally designed to do
what they are called: trim laminate - usually on countertops. Often they come
with bearings and little fences that you won't need for guitar work.
Regarding guitar making, it's certainly nice to have both, although if I had to recommend one over the
other, I'd say get a laminate trimmer first simply because they are so much easier to handle for someone
starting out.
PostPosted: Sat Feb 05, 2011 11:46 am
First name: Hugh
City: Lake Oswego
State: oregon
+1
PostPosted: Sat Feb 05, 2011 11:50 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Horse power and weight, a router is large powerfull and heavy, needed for heavy cutting like neck joints and pattern bits in a router table and will need two hands to hold it while cutting. The Laminate trimmer is much lighter, great for binding, rosettes and light routing and can be manipulated with one hand. The laminate trimmer is probably what I would start with or own if I could only have one, most routing jobs can be done with it. An alternative might be this tool
http://www.woodcraft.com/Product/2082504/31935/PorterCable-125HP-Compact-Router.aspx
http://www.woodcraft.com/Product/2082556/33102/DeWalt-Variable-Speed-Compact-Router-with-LEDs-125-HP-Model-DWP611.aspx
these might fill most of our needs in guitar building but not as good as having a full sized router and a Laminate trimmer
Fred
Fred Tellier
PostPosted: Sat Feb 05, 2011 12:17 pm
If you don't want to buy both to start, I would start with the laminate trimmer. Most of my work is done with a laminate trimmer (binding, routing for rosette, mortise and tennon for the neck).
If you plan to build/buy a router table, get a full size router for it. A router table or shaper is great for template routing.
PostPosted: Sat Feb 05, 2011 12:35 pm
First name: Daniel
Last Name: Minard
City: Powell River
State: BC
Since I bought the new Ridgid laminate trimmer, I don't use my bigger routers for neck mortise & tenon joints. I did make a 6" round plexiglass base plate which is needed sometimes when routing out large cavities or when you want a more secure "footing".
If you use a lam trimmer for bigger jobs, go down to your final depth in stages.
If you're hogging off lots of material (ie, making radius dishes) & big router that'll take 1/2" bits
is the right tool, otherwise a good lam trimmer will do most everything you need in luthiery.
PostPosted: Sat Feb 05, 2011 1:15 pm
What's the new standard in laminate trimmers now that the PC310's discontinued?
PostPosted: Sat Feb 05, 2011 1:35 pm
Last Name: Shanklin
City: Windsor
State: ON
I think the redesigned Ridgid is. Model #2401.
Bob
PostPosted: Sat Feb 05, 2011 2:46 pm
Does anyone know if any of the new routers have the same screw/bolt pattern onthe base? I've got an old 310, with several fixtures, and need a couple of new router. I'd love to find a make/brand that fits the old 310 pattern!
TIA,
Ken Mitchell
Durham, NC
PostPosted: Sat Feb 05, 2011 2:59 pm
TIA,
The PC 7310 has the same pattern as the 310 from what I understand.
PostPosted: Sat Feb 05, 2011 5:48 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
thanks a lot for the replies!! this place rocks! so, i get it now:
router : heavier, two-handed use, both bits sizes;
LT: lighter, one-handed operation, smaller router bits.
but this leaves me a problem, i was thinking on buying this bosh router: http://www.amazon.co.uk/Bosch-POF-1200- ... d_cp_diy_1 . but i´m still to find a bosh / rigid laminate trimmer on an european on-line dealer (amazon sells dewalt and makita, IIRC). anyone knows of a good european dealer ?
thanks so much,
Miguel.
PostPosted: Sat Feb 05, 2011 6:34 pm
Makita is a very good brand, don't be afraid to get a Makita [:Y:]
PostPosted: Wed May 04, 2011 12:54 am
is it possible to build a simple router table to be used with a laminate trimmer?
or this is not a good idea to do?
Has anyone done that?
Thank you.
PostPosted: Wed May 04, 2011 1:04 am
I have about 5 of these:
http://www.amazon.com/Makita-3707FC-Fix ... 792&sr=8-1
and I have three:
http://www.amazon.com/Porter-Cable-690L ... 822&sr=1-1
and two:
http://www.amazon.com/Porter-Cable-7310 ... 822&sr=1-4
and 4:
http://www.amazon.com/Bosch-1617EVS-2-1 ... 864&sr=1-3
and two:
http://www.amazon.com/Milwaukee-5616-20 ... =1-3-spell
and one really old ryobi laminate trimmer.
They are all very very nice. Except the Ryobi.. it still runs, but the height adjustment is a joke.
I like to get routers set up for one operation and leave them dedicated for that. I use the Makitas in my binding cutter. They are about 6 years old and still going strong after cutting ledges on 100 or so guitars in the past 6 years.
PostPosted: Wed May 04, 2011 1:06 am
Thank you.
You can get this:
For the cost, or cheaper, than most laminate trimmers. If you're using a router table I'd suggest using a full size router. I use a Bosch 1617EVS in my router table and it works great.
PostPosted: Wed May 04, 2011 3:11 am
Woodcraft has a special going on now if you buy a Porter Cable router you get a free laminate trimmer.
http://www.woodcraft.com/Product/200577 ... 690LR.aspx
PostPosted: Wed May 04, 2011 7:04 am
Last Name: coloccia
Country: States
Todd Stock wrote:
The PC 7310 is a very different router from the PC310...I have one that has held up for 10 years of so and three major ipe deck projects, but would not use it for luthiery due to the mount to the base...lots of room for movement. I like my Colts, and the Ridgid 2400's I have seem to be holding up in my saddle mill and rosette jig. One thing - definitely go with at least one router with a round body...much easier to mount in jigs, as all it takes is two rings with a screw closure.
The next 310 might just be the DeWalt 611, based on early reviews. Need to get one in the shop to really get a feel for whether it will do the job. At $145 for the kit from Ace Tool, it seems like a decent deal. At 1.25 hp, it will handle some of the jobs that a 690 will, although you'll need a full sized router to handle the 1/2" shank diameter bits that work well for template routing.
Exactly. Their new laminate trimmer is NOT like the old 310 at all, for all the reasons you mention. Good luck just getting it square. I have a 310, and use it for some things, but it's a frustrating experience.
If I wanted a small router, and only wanted one router, the only one I would even consider at this point is the new Dewalt or Porter Cable compact router with the additional plunge base. That's a very usable combination that will do most tasks. You're stuck with a 1/4" collet, though, but that's OK depending on what you're using it for. It's rare that a manufacturer does this, but Dewalt/PC really knocked it out of the park with this one.
PostPosted: Wed May 04, 2011 1:09 pm
It's the PC310. Now no one meets the standard.
PostPosted: Fri May 06, 2011 1:48 am
Sorry guys, I am very very new to the router world.
I have a newbie question.
What does the "additional plunge base" for Dewalt 611 do?
I understand that this base allow the base to be in contact with the work piece before turning on the router. Then after turning on the router, I can push the router down to start cutting the work piece. So...it is idea for routing the saddle slot on the bridge.
Is this correct?
Besides this function, what else can I use the plunge base for? can I use it on a router table?
sorry again for this silly question.
