It is currently Thu Aug 21, 2025 8:31 pm
 Post subject: Stainless steel frets
PostPosted: Fri Feb 18, 2011 12:37 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
I have a friend that destroys frets quicker than anyone I have ever seen in my life. I am recommending SS frets, but I have zero experience with them. What is the best (most durable) tool to use for installing them?
PostPosted: Fri Feb 18, 2011 12:52 pm
I've been using them for over a year now. I use the same method and tools as any fretwire with the exception of cutting them. I use a cutoff wheel on a Dremel to cut them to size. They take a bit longer to file but they smooth up quite nicely. I, as well as my player clients and friends love the feel and can't get them to show wear. [:Y:] [:Y:] [:Y:]
PostPosted: Fri Feb 18, 2011 1:36 pm
First name: Joey
Last Name: Holliday
City: Palmetto
I don't have a dremel but I have been eyeing one recently. I suppose this would provide the excuse to get one. Thanks.
In regards to my player friend, I have never seen a guitar take a beating like this over a period of three years. The thing was trashed, nearly beyond repair but I did what I could to make it playable. He sold it shortly after and bought a new one, but it is surely going to need steel frets within the year.
PostPosted: Fri Feb 18, 2011 1:57 pm
I have been using stainless steel frets for a few years now. I use all the standard fretting tools. The only thing that ever gave me trouble was keeping the ends down on a bound board when hammering frets in. Not a problem since I started pressing frets.
Chuck
PostPosted: Fri Feb 18, 2011 2:27 pm
Chuck...what are you using to cut the frets. I'd love to find a simpler hand tool that works.
PostPosted: Fri Feb 18, 2011 3:19 pm
First name: Jonny
Last Name: D
I purchased the larges set of end nippers I could find and they work great.
They're prolly a foot long....
I simply could not get er done with anything smaller.... stainless is bloody hard....
PostPosted: Fri Feb 18, 2011 3:48 pm
My tools and techniques have not changed with using stainless steel frets, I have no problem keeping the ends down.
I use standard fret nippers, and the same stew-mac tang nipper, I trim 1 mm of tang off at a time though.
Dressing and polishing takes longer than with regular frets, but they last forever. Musicians who I know play 2 or 3 hours 5 nights a week have had me refret their guitars with stainless steel frets, some several years ago, and they still show no wear.
The stuff's super dureable.
I've done partial refrets with stainless, and there's been no discernable difference to any of my client's ears going across the stainless and nickel silver border, I don't think they affect the tone noticeably, at least not on the guitars I've done.
Old growth, shmold growth!
PostPosted: Fri Feb 18, 2011 4:07 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
I don't know if it's just me but Dremel cut off wheels are about the slowest cutting method ever. I always end up being frustrated and just using a hacksaw or whatever else I can find, even after getting diamond ones (for cutting off bolt heads and such). Maybe it's different with stainless steel.
PostPosted: Fri Feb 18, 2011 6:44 pm
It takes me about 3-5 seconds to make a cut
PostPosted: Fri Feb 18, 2011 7:46 pm
JJ, I cut SS frets with standard diagonals from the local Sears, the flush nippers are also from Sears, I just ground them flush. Just the plain companion brand.
Guitarwisperer, are you able to hammer SS frets in a bound board without the ends lifting?
Chuck
PostPosted: Sun Feb 20, 2011 1:16 am
Yup.
I use the same technique to hammer SS in as NS.
PostPosted: Mon Feb 21, 2011 8:38 pm
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
I had serious problem with cutting stainless frets, and I can see why Warmoth won't install them in a bound fretboard (and I won't either...)
When using an abrasive wheel, how do I keep the fret cool enough so that the heat from the cutting won't char the wood? this has been a major problem for me when using any short of powered abrasive on SS frets.
Typhoon Guitars
PostPosted: Mon Feb 21, 2011 8:54 pm
I guess I just have gorilla hands, I have no problem cutting even jumbo stainless steel frets with regular stew-mac end nippers.
If any aof y'all need a a bound fretboard done in steel, just send it to me!
PostPosted: Tue Feb 22, 2011 8:13 am
I don tknow where you could get them now, but a couple years back Allied had carbide tipped flush cutting nippers for sale .. they are without a doubt the best side cutters I have ever seen or used. As they were sold as trial runs, they needed a touchup on the mounting surface of one of the carbide inserts to get the tips to touch properly, but after about 2 minutes with a file, they are golden.
PostPosted: Tue Feb 22, 2011 11:20 am
Seems to me that Jescar could provide a great service by having heavy duty and/or carbon tipped nippers available for sale. Having the right tool sure makes a difference.
Also...I've installed SS frets on bound fretboards (hammered) with no change in technique from standard wire. I use a small amount of FG in the slots which seems to help. While the fret nipper works, it definitely requires much greater hand force.
Users browsing this forum: Darrel Friesen and 21 guests
