It is currently Thu Aug 21, 2025 4:53 pm
PostPosted: Thu Mar 24, 2011 6:57 am
Is it better to rout the neck block before fitting it or after? If after, then should I wait until the top and back are attached or do it after the kerfing is done?
PostPosted: Thu Mar 24, 2011 11:15 am
First name: Gene
Last Name: Zierdt
City: Sebastopol
Zip/Postal Code: 95472
+1 for Todd's answer. There are a lot of chances for mis-alignment if you route the
raw block. I've never had a problem routing after the box is closed. If you look at
Robbie O'brian's toot on YouTube you'll get a good idea how easy it's done.
Luthier Tips du Jour - Bolt on Mortise and Tenon Neck Joint
http://www.youtube.com/watch?v=yzlZvDyKnPI
Gene
Users browsing this forum: doncaparker and 14 guests
