It is currently Thu Aug 21, 2025 4:54 pm
 Post subject: sound board bracing
PostPosted: Mon Mar 28, 2011 5:48 am
First name: David
Last Name: Wolfe
City: Fort Lauderdale
State: FL
Zip/Postal Code: 33316
My plans call for all the sound board braces to run through the lining and side,but in the DVD that came with the kit the builder only runs the x-braces through the linings and sides. Any advice?
 Post subject: Re: sound board bracing
PostPosted: Mon Mar 28, 2011 6:56 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
On the 2 guitars I've built, only the X-braces and upper transverse brace get tucked into the linings.
Many builders only tuck under the linings & not all the way through the sides. I think in a factory environment with dedicated tooling, it's faster to run them all the way through the sides.
Kevin Looker
I'm not a luthier.
PostPosted: Mon Mar 28, 2011 7:04 am
In my (limited) understanding, only the upper transverse brace and and x-braces are normally run through the linings.
I like to leave them just a little short of the sides (although some people like to leave them slightly short of the linings at the bottom of the x-braces)
I don't like to run them through the sides as well because then the ends of the braces are trimmed when routing the ledges, and touch the bindings, then with movement due to humidity changes (more across the grain than along it) they could put stress on the binding glue joint and possibly "push" the bindings off.
Maybe just paranoia on my part, but I would hate to have that happen.
Which kit are you using?
PostPosted: Mon Mar 28, 2011 7:27 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Colin North wrote:
...I don't like to run them through the sides as well because then the ends of the braces are trimmed when routing the ledges, and touch the bindings, then with movement due to humidity changes (more across the grain than along it) they could put stress on the binding glue joint and possibly "push" the bindings off...
On no. 2 I ran them all the way through & this almost happened. I had the body in a very dry environment while waiting for the lacquer to cure and the binding bulged at the 2 spots on the lower bout where the braces made contact.
Kevin Looker
I'm not a luthier.
PostPosted: Mon Mar 28, 2011 9:02 am
First name: Tom
Last Name: West
State: Nova Scotia
David: I tuck the X brace and upper transverse brace ends. Just into the linings and not through the sides. I fit them so they act as registration points so I don't have to worry about slippage during gluing.
Tom
PostPosted: Mon Mar 28, 2011 7:27 pm
First name: David
Last Name: Wolfe
State: FL
Thanks again everybody!! The kit I am building is one from Luthiers Mercantile Int.Inc.with a redwood top, sapele sides,back and neck. I just took a closer look at the plans and all the braces run under the linings but not through the sides.
Users browsing this forum: doncaparker and 12 guests
