It is currently Fri Aug 22, 2025 3:10 am
PostPosted: Sat Apr 09, 2011 9:51 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I have an Ibex bender and have only used it 5 times. When it is not in use I have it in it's box and take good care of it, but for some reason it gets hot and then immediately cools down a lot. What is wrong with this thing?
PostPosted: Sat Apr 09, 2011 11:01 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
I know nothing about circuitry... Thanks for the help though.
PostPosted: Sat Apr 09, 2011 11:11 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
might be time to send it back.
PostPosted: Sun Apr 10, 2011 4:59 am
Sounds more like a thermostat problem. These things are simple heater/thermostat circuits. I'd be tempted to contact Ibex (or the retailer), even if the warranty period has lapsed. Seems to be extremely premature for things to be failing.
If that proves to be expensive, try and find someone who is familiar with fairly basic electrics/electronics. The Ibex is about as complex as a household clothes iron.
PostPosted: Sun Apr 10, 2011 12:05 pm
The thermostats in those are crap. Mine has to be set to High (which disengages the thermostat) in order to get hot and stay there. If I put it one number down (6 I think) it keeps turning on and off every 20 seconds or so, which is too annoying to listen to, and not hot enough. I've been meaning to open it up and mess around with it (usually these are strips of bimetal and can be bent around for "calibration"). But it heats so slowly with its underpowered element that leaving it on High has worked OK and I haven't bothered yet.
One other thing: it's a good idea to put these on a timer for the inevitable day when you leave it on. I've been meaning to do that, too.
PostPosted: Sun Apr 10, 2011 12:26 pm
Last Name: Kincheloe
I can't believe those things are so expensive, when all I've ever heard about them is that they burn up as soon as you use them.
I much prefer my charcoal lighter setup. $10 for the lighter, $10 for a dimmer switch, and a free scrap of exhaust pipe from Midas. Couple bucks for brackets and bolts to attach it to a wood scrap, and it works like a charm. Pipe is too large for tight cutaways or violins, but I may go out and look for a thinner walled large pipe that I can crunch into an oval shape, or just build another with a smaller pipe. I've also bent tight binding curves directly against the charcoal starter element :mrgreen: But I might not have the guts to try that if it wasn't jammed into the pipe to regulate its temperature. Need to try it on violin ribs sometime.
Anyway, I agree with those who have said to send the ibex back for repairs or refund.
PostPosted: Sun Apr 10, 2011 4:49 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
It works when I use it at high, but I'm just worried the thing will completely crap out.
PostPosted: Sun Apr 10, 2011 6:31 pm
I just took mine apart, and ordered a new heater cartridge and control from Grainger's. I doubled the wattage from 200 to 400. I see that LMI has the insulation gaskets--my old one fell apart, and the wood under it was charred. Probably sheetrock or cement board would do at least as well.
I'll report back on how successful my attempt at hotrodding the thing is.
PostPosted: Mon Apr 11, 2011 2:05 am
I had this cast many years ago. Does anything from a Cello to a Violin and pretty much all in between. it was my intention to fit a timer/thermostat but in practice there is no real need. Being made of solid aluminium means it holds the heat long enough to bend a set of sides. I simply pull the plug when the temperature is reached.
PostPosted: Mon Apr 11, 2011 5:50 am
Country: Romania
Hmm, I am pretty much satisfied with mine. I set it at 5.5 for rosewood and 6 for ebony. Doesn't seem to go on and off too often.
Build log
PostPosted: Mon Apr 11, 2011 10:25 am
+1 for running it on high. Haven't had any problems with mine.
