It is currently Thu Aug 21, 2025 5:28 pm
 Post subject: Today I made a stick....
PostPosted: Mon Apr 11, 2011 3:01 pm
Last Name: Wood
City: Chester Springs
State: PA
Zip/Postal Code: 19425
I wanted some rosewood fingerboard side marker dots for the dread I'm finishing up. I was unable to find a source for small hardwood dowels or premade dot inlays, so I made this. I cut a small strip of EIR off of a thick head plate blank, whittled about 1/2" of the end pretty round, chucked it up in my drill press and went at it with various sandpaper strips and small files. Actually worked out OK, I think. It's darn close to 2mm in diameter from the blue tape to the tip, and very round. Does anybody know a source for pre-made wooden dots, or have a better process to make them than this? I'd love input.
Thanks, Chris.
PostPosted: Mon Apr 11, 2011 3:22 pm
First name: Tom
Last Name: West
State: Nova Scotia
Chris: If you want wood,I would say this is a fairly easy way to make dots.Enough here to do at least one guitar. LMI has black and white plastic side marker material,think it's about 1/16"or 3/32"diameter and about 6" long. I find it works quite well.
Tom
PostPosted: Mon Apr 11, 2011 3:49 pm
Last Name: Tulloch
State: Vermont
I often use a dowel plate. The Lie-Nielsen dowel plate goes down to 1/8", but you can make your own to smaller sizes.
michael
PostPosted: Mon Apr 11, 2011 3:55 pm
Last Name: Wood
State: PA
Thanks guys,
I've used plenty of shell and plastic from LMI and stewmac, I was just wanting wood this time.
PostPosted: Mon Apr 11, 2011 8:48 pm
Last Name: Ensor
City: Springfield
State: Missouri
That is the same way I make my wood side dots. As with most things in lutherie, if you really want it, you have to do it yourself- either because it is not available on the market, or it is so extremely expensive, you can't afford it anyway.
http://elevatelutherie.com
http://ensorguitars.com
PostPosted: Mon Apr 11, 2011 11:35 pm
First name: duh
Last Name: Padma
Pencil sharpener.
Drill hole, plug with glue.
Cut off.
Repeat for more dots.
PostPosted: Tue Apr 12, 2011 12:30 am
Last guitar, he really wanted maple dots on a rosewood fretboard. It may not matter, but I didn't want end grain. I was concerned it would be harder to keep clean while sanding and down the road while playing. I used drill bit counter sinks with the drill bit removed. I had a variety of sizes to choose from and got nice clean plugs. I also tried a cheap plug cutter. It was significantly inferior.
Mike Lindstrom
PostPosted: Tue Apr 12, 2011 2:05 am
First name: Ellison
City: Whitman
State: MA
I just posted my way of doing this in the mando forum recently! Works really well, is very fast, and you can use very small scraps to get the job done. Also it doesn't require using end grain as one of you had mentioned was a problem for you. Here's my trick:
Take a small piece (any shape) of scrap that is just slightly larger than the size of the dot you want. Now take a drill bit the size of the dot you want. With a dot of CA, glue the piece to the end of the drill bit opposite of the cutting end. Put the bit upside down in a drill press and get it spinning! Now you can take a file, or a sanding block of some sort to the edge of the spinning scrap piece. It'll come out to a perfect circle of the perfect size!
It was suggested that I do a pic tutorial, so maybe I'll get around to it sometime.
PostPosted: Tue Apr 12, 2011 6:50 am
Last Name: Wood
State: PA
Thanks for the ideas everyone. Several I had not thought of.
Chris.
PostPosted: Tue Apr 12, 2011 8:59 am
the Padma wrote:
Pencil sharpener.
Cut off.
Don't get any easier than that.
PostPosted: Tue Apr 12, 2011 9:19 am
First name: Big
Last Name: Jim
[quote="Chris Oliver"]Dots... made with a counter bore bit with the 1/8" drill bit removed... go figure!
Here is what Chris came up with when I was looking [clap] [:Y:]
BTW , A Darn fine looking stick it is too !!
PostPosted: Tue Apr 12, 2011 9:39 pm
City: Tucson
State: AZ
For the pencil sharpener method, I'd want to make a tapered hole with a dremel bit that matched that of the sharpener close enough. Just though I'd throw that out there....... beehive
PostPosted: Tue Apr 12, 2011 10:30 pm
Anyone tried this?
http://www.leevalley.com/en/wood/page.aspx?cat=1,180,42240,53317&p=32280
Reams a hole that matches a dowel sharpened in a standard sharpener.
Mike Lindstrom
PostPosted: Wed Apr 13, 2011 12:04 am
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
maybe you could use rabbit pellets. idunno
PostPosted: Wed Apr 13, 2011 1:47 pm
Last Name: Wood
State: PA
Thanks again everybody.
Chris.
PostPosted: Wed Apr 13, 2011 8:52 pm
City: winnipeg
State: manitoba
Country: canada
I use 1/8" brazing rod for a vintage look or use a paper punch on veneer strips.
Bob :ugeek:
PostPosted: Thu Apr 14, 2011 2:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Isn't one of the reasons for using plug cutters I'd to avoid "end grain" exposure? Seems making a stick would only leave end grain as an option. Yet, maybe for dense woods that is not much of an issue.
PostPosted: Thu Apr 14, 2011 4:11 pm
Last Name: Wood
State: PA
For sure the end grain issue is there. I ended up making another dowel, this one with Honduras Rosewood, which is much lighter red. Tests of the Honduras and the EIR showed the EIR dot looked almost black, where the Honduras ones looked pretty close to the right color. Worked out very well. I'll have some pics one of these days.
PostPosted: Thu Apr 14, 2011 6:53 pm
Last Name: Wood
State: PA
Hard to take a decent pic of this, but here's a pic of the Honduras Rosewood postion markers. Under finish they look just the slightest bit more red than the EIR purfling on the maple binding, but I like the look quite a bit. Under finish you can see the end grain color variations in the rosewood dots.
Chris.
cron
