It is currently Fri Aug 22, 2025 12:03 am
Post new topic Reply to topic  [ 87 posts ]  Go to page Previous  1, 2, 3, 4
PostPosted: Wed Apr 27, 2011 11:09 am
Last Name: Rogerson
City: Pembroke
State: Ga
Zip/Postal Code: 31321
My 1st build. I don't know any better, so I started by doing everything I wanted a guitar to be. I can only improve.............right?
PostPosted: Wed Apr 27, 2011 3:17 pm
City: Fort Meade
Zip/Postal Code: 20755
This is my second guitar I just finished a while back. I absolutely love playing it!
PostPosted: Wed Apr 27, 2011 9:25 pm
City: Tucson
State: AZ
This was a cool thread to bring back. Great work guys. [:Y:]
PostPosted: Thu Apr 28, 2011 3:55 am
First name: Jorge
Last Name: Manuel Valdés
City: Madrid
State: Spain
Zip/Postal Code: 28033
Country: Spain
Hi from Spain ,
This is my third ... A brassilian rosewood classical with solid peghead and fishman amplification
Best regards!!!
PostPosted: Thu Apr 28, 2011 12:18 pm
Wait till Colin sees that! A classical bordered with abalone purfling.
Never seen it done...but (predictably) I like it.
Say...isn't it nice to see Bruce Dickey's name pop up on the screen again?
PostPosted: Fri Apr 29, 2011 6:04 am
First name: Jorge
City: Madrid
State: Spain
Country: Spain
Yes ..
This guitar was for a friend. He asked me to build it with abalone binding .. solid peghead (he doesn't like classical ones) .. fishman "on-board" .. ;) and curved fingerboard .. he is very happy with the results.
regards!
PostPosted: Sat Apr 30, 2011 9:49 am
First name: Logan
Last Name: Sarchfield
State: AB
Here is my current build. It's a red spruce/ african mahogany 12 fret L-00 with a slotted headstock. It is the second guitar I've built and it is also my second sunburst, I previously did a burst on an F style mandolin.
PostPosted: Sat Apr 30, 2011 11:02 am
First name: George
City: Seattle
At first I didn't notice this was a revived thread. Laughed my head off at the top. Anyway... great looking new stuff on display. I should have a couple finished pretty soon. Will post a pic or two when all is said and done.
Hey, Logan, would you mind sharing your process for getting that sunburst? I love the look of it!
George :-)
PostPosted: Sat Apr 30, 2011 1:28 pm
First name: Logan
State: AB
I used alcohol soluble aniline dyes from lmii, I mixed up a little bit of each colour in mason jars with an ethanol rubbing alcohol that I get from the local pharmacy. I also had one jar of straight alcohol with no colour. I made little pads so that I could rub it on, one for each colour and lots of extras. I also have a cheap air brush and compressor set up, I use the air brush for even application more than blending the colours.
I'll try to explain my process the best I can. In hopes to avoid any blotches I first applied a thin coat of shellac and then sanded back to the wood. It seems to have helped. I first applied yellow all over the top by hand, then some red on the outside edge then blended that in towards the centre, then amber on the outside edge and did the same. I didn't want the dark colours to be blotchy so I sprayed the brown on to the outside edge and I would then start with yellow with a pad in the centre and work my way out to blend the colours together. I would add more red or amber as required then blend them together starting in the centre with yellow or plain alcohol. I did spray some black on the very outside edge and then rubbed it in by hand being careful not to drag it towards the centre.
I hope this helps. Its hard to explain, you will get a feel for it. I suggest you try it on a top that is either scrap or not sanded down to final thickness. This burst ended up much darker than I had in mind but I like the look of it and so does my customer.
PostPosted: Sat Apr 30, 2011 2:03 pm
First name: maarten
Last Name: van guyse
City: heusden-zolder
Zip/Postal Code: 3550
Country: belgium
ok, I'll bite. I guess I'm a lurker, since I haven't posted here much. Though I have learned a lot, so thanks to everyone. bliss
lots of pics, I hope you don't mind. After all, you asked for them. laughing6-hehe
anyway, this was acoustic number 1:
and the back:
a pic of number 2, before closing the box. The same as number one, but with a cutaway. This time in EIR instead of padauk:
number 3: a baritone, 29 inch scale. Walnut body.a pic before the bridge was glued on:
then there was a Torres FE19 I built in the class I'm taking. I don't have pictures of that one, even though it's finished, and it is by far the best guitar I've made to date. :s Many thanks to my teachers Karel Dedain and Walter Verreydt. Check out their website if you like! They build amazing guitars!
Currently working on an Enrique garcia classical, and a Fleta classical, This is the headstock design I settled on for the Fleta:
Courtesy to Stijn Kenens, who came up with the design, but with some modifications in dimensions.
some 'under construction pics' of the Garcia: (sorry, phone pics)
today I attached the neck, and installed the sides:
the rozette for the Garcia:
sides for the Garcia bent:
the rozette for the Fleta under construction:
A couple of weeks ago I started working on a 12-string Santa Cruz, including the flying butress bracing (that will be a challenge!), and in between stuff I'm also working on a telecaster.
I have way more on my plate than I can chew! :)
cheers!
PostPosted: Sat Apr 30, 2011 2:07 pm
First name: maarten
Country: belgium
hm, that didn't quite work as planned. oops_sign
edit: better now.
PostPosted: Sat Apr 30, 2011 6:30 pm
First name: Bruno
Last Name: Piancatelli
Country: Argentina
well this is small thing compared to what you guys are posting, but im working on my second and today y started cutting the back and sides.
from a Peteribí (Cordia trichotoma) log i´ve had for a long time.
tomorrow ill try to finish the job and to post the pictures of the sets so you can see how they look.
its a nice looking wood somewhat similar to walnut in colour and propeties, grain not too fancy though.
Users browsing this forum: Ken Lewis and 30 guests
