It is currently Fri Aug 01, 2025 9:55 am
PostPosted: Fri Dec 09, 2005 7:02 am
I do this. Glue up all the braces in the dish with the exception of the trasverse brace and the popsicle stick brace (neither of these braces are radiused... they are flat).
Then glue those top two braces up from a flat surface.
This is how I learned to do it from Frank Finocchio. It works like a charm.
PostPosted: Fri Dec 09, 2005 7:08 am
Like Brock. This makes the upper bout area decend into a flat plane for the fretboard with little or no sanding required to mate up
PostPosted: Fri Dec 09, 2005 10:28 am
SO then, how do you transition the rim from the arch to the flat area? Especially over the headblock.
cron
