It is currently Fri Aug 22, 2025 10:55 pm
 Post subject: Lute questions
PostPosted: Mon May 16, 2011 11:07 pm
I just got a couple of lutes in for repair and need some advice. One is an Elizabethan lute and the other is a Baroque archlute by David Rubio. The Rubio is the one I have questions about. Does anyone here have a good source for fret gut? Also, it had a parchment binding that someone decided to remove. I need to know what kind of parchment to use and what's the best way to apply it.
 Post subject: Re: Lute questions
PostPosted: Tue May 17, 2011 9:55 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
I haven't used their product myself, but I've ordered fret gut for a friend in Paracho from these folks:http://www.aquilausa.com/luteguitar.html#Fret-Gut, and he was satisfied with the quality.
PostPosted: Tue May 17, 2011 11:19 am
Send a PM to Colin Symonds. Colin S, username. Colin is the museum instrument restorer for the university where he works, in London, and he restores lutes of all types, as well as being an accomplished lute builder.
PostPosted: Tue May 17, 2011 4:13 pm
You could check with Daniel Larson at Gamut Strings.
PostPosted: Tue May 17, 2011 8:25 pm
Jason, you are working on a Lute?
You may be the first actual Luthier that I've ever seen here.
PostPosted: Wed May 18, 2011 2:39 am
Aquila make very nice strings. Many think the best available. I have both their strings and Fret gut.
No doubt the lace was removed to remove/repair the soundboard and was never replaced.
I can't be certain but it's likely to be sheepskin. Around 0.2 mm is the thickness used for Parchment rosettes. It is difficult to glue, you need to 'size' the parchment before the actual gluing. I can't help on the procedure for doing it on a Lute because I've never used that particular 'lace' method. I've only done the wood half edge. in his CD course David Van Edwards states that he dislikes the use of Parchment for the edge work.
You also come across cloth being used, in the same manner as Parchment. I've seen it on both original and reproduction instruments. Probably easier (and cheaper) to use, unless it has silver thread woven into it.
PostPosted: Thu May 19, 2011 10:13 am
Yes Aquila are the best generally available gut strings, they also do fret gut in various thicknesses. To answer your PM question, yes you will need a variety of sizes of fret gut, and don't forget that you add the frets after stringing the lute up to tension, you should then be able to gauge the fret sizes that you need to use.
I have only replaced the parchment banding on three lutes that I have restored and each time I used skin that was originally destined to be a timpani top, but you could also get the skin from a banjo suppliers. As has been said it will need to be sized to soften it first, and will need to be glued with a collagen glue, hide or fish. I have also used silk, as tended to be used on Italian lutes.
As a matter of interest, many moons ago I played Julian Bream's 8-course Rubio lute, with metal frets!
As we don't get enough music on this forum, here's me (when I could) playing some Dowland on one of my 10 course Venere lutes.
My Lady Hunsdon's Puffe
PostPosted: Thu May 19, 2011 11:55 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Beautiful music beautifully played. Thank you Colin.
PostPosted: Fri May 20, 2011 4:09 am
Indeed. That is very accomplished playing.
PostPosted: Fri May 20, 2011 5:33 am
Colin, that is simply beautiful, no real way of describing it to do it justice!
The tone of that instrument is amazing and rather lovely playing to... more clips like in the locker?
[:Y:] [:Y:]
PostPosted: Fri May 20, 2011 12:16 pm
I don't want to hijack the thread, but yes Frank I have a lot more recordings. I recorded the whole cannon of Dowland, and a lot of Weiss for the RCM archives on the lute, as well as a fair bit of Tarrega on the guitar. If you'd like a CD, Frank PM me.
PostPosted: Mon May 23, 2011 9:21 am
Thanks everyone. Thanks Colin for the heads up on the value. I knew it was a nice instrument. Luckily I'm not doing anything major to it. The lace is the worst of it. I'll let you know how it turns out.
PostPosted: Mon May 23, 2011 12:25 pm
That was a pleasure to listen to Mr S, thank you.
