It is currently Sat Aug 23, 2025 12:52 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2
PostPosted: Mon May 16, 2011 9:10 pm
Steve_E wrote:
John, what are you using to cut out the sound hole area of the medallion? Are you using a jewelers saw or some other fancy jig? Also, that is a very small circle radius. Did you have to build a separate circle cutter for it? The min mine goes is ~3".
I'm using your design concept for a new sound hole idea. You'll get all the credit!
Here are a few pics of cutting out the soundhole. I just use a Ryobi lam trimmer. This lam trimmers only use in life.. it's a crappy lam trimmer otherwise... well I suppose it still runs so that's a positive, but the height adjustment is a joke. It's the first lam trimmer I ever bought... about 14 years ago.
No fancy jigs here!! The medallion pocket was cut with a forstner bit. The pilot does go through the top, so keep that in mind. I put a soundhole brace over the 1/16th hole (give or take depending on how far you sand on the back), and then I use a small half plug backer on the part that extends into the soundhole.
After I cut this initial pass I break out another lam trimmer and freehand the area around the medallion. I leave it rough and slightly oversize for now and clean it up later by hand with sandpaper and files.
I don't mind if people borrow the idea. I think you would be best served using a rough idea and morphing it into something different and unique, but if you are resolved on copying it straight away I would appreciate credit for the inspiration/design.
Heck my original inspiration for it was a mosaic in NYC subway combined with a Somogyi rosette. Of course it looks nothing like either really, but they got the juices flowing and I used that to create something unique. I suggest the same for anyone inspired by the idea.
And as it so happens I took pictures of the mosaic in the subway. Like I said the two don't look anything alike, but they served inspiration to get my own creativity going.
And this rosette of Ervins gave further inspiration. Combine them both and throw in a big part of my style and there you have it.
PostPosted: Wed May 18, 2011 8:34 pm
First name: Phil
Last Name: Brodersen
City: Chandler
Zip/Postal Code: 74834
bliss
Hi all. I just wanted to chime in and say I'm the "client" for this guitar and I'm ecstatic about the job that John has been doing.
Thanks for your comments and appreciation!
Cheers,
Phil
PostPosted: Sat May 28, 2011 12:30 am
I suppose a cool rosette needs a matching endgraft yeah?
PostPosted: Sat May 28, 2011 8:21 am
John, the medallion rosettes on your guitars are such a simple, wonderful idea! I envy you for this idea and enjoy the beauty of your instruments at the same time! [clap] [clap] [clap]
Well done! [:Y:]
florian
PostPosted: Sat May 28, 2011 8:49 am
Nice, John!
PostPosted: Sat May 28, 2011 9:21 am
Thanks for showing the process, John. Seeing the process makes it look a lot less intimidating.
And VERY nice work!
Ken Mitchell
Durham, NC
PostPosted: Sat May 28, 2011 10:42 am
Very, very cool, John! Thanks for sharing that. [:Y:]
PostPosted: Sat May 28, 2011 11:10 am
First name: Florian
Last Name: THOMAS
City: Bernieulles
Country: France
Nice rosette John !
I like the idea and the job is clean and elegant.
Well done !
PostPosted: Sat May 28, 2011 11:03 pm
First name: William
Last Name: Rieselbach
City: Milwaukee
State: WI
Zip/Postal Code: 53211
both of them very, very nice!
PostPosted: Sun May 29, 2011 2:22 am
First name: jeremy
Last Name: budgen
City: delmas
State: mp
Zip/Postal Code: 2210
Country: South Africa
Hey John
Very nice work there, i`ve never seen rosettes done this way before, just one question, i see you seal your tops before starting to glue the parts in is this clear laquer that you use, as i see in the pictures it has a colour to it, is there a reason for the coloring or was it just left overs from another job.
Do you use veneers for the tiles and the maple lines.
Jeremy
South Africa
PostPosted: Sun May 29, 2011 3:18 am
jeremy budgen wrote:
Hey John
Jeremy
South Africa
Thanks everyone.
I shellacked the rosette area to prevent CA bleed.
The tiles were offcuts from headplates, sides, backs, ect. The maple lines are just .020 purfling.
Users browsing this forum: Bing [Bot] and 45 guests
