It is currently Sat Sep 13, 2025 8:47 pm
 Post subject: Reso plans
PostPosted: Sat Apr 23, 2011 2:01 pm
First name: Raymond
Last Name: Phillips
City: BENONI
Zip/Postal Code: 1501
Country: South Africa
Hello all, I'm pretty keen to have a bash at building a metal bodied resonator guitar. Is ther eany documentation available. I always feel better if I've done a bit of research. Quite honestly, I wouldnt knopw where to start here.
 Post subject: Re: Reso plans
PostPosted: Sat Apr 23, 2011 3:32 pm
Welcome Raymond...not sure I've ever seen plans for a metal resonator. Hopefully some of our Reso experts will chime in.
PostPosted: Sat Apr 23, 2011 3:49 pm
First name: Kenneth
Last Name: Jeffs
City: Chesterfield
Zip/Postal Code: 63017
Have you checked the archives on
the MIMF? This forum has some information on metal body builds.
PostPosted: Sat Apr 23, 2011 3:52 pm
First name: Kenneth
Last Name: Jeffs
City: Chesterfield
Look up Mike Dotson. I know he has some experience.
PostPosted: Sat Apr 23, 2011 9:09 pm
MIMF.com library has the most extensive discussions on the subject. I have a 100 photo tut on how I build the body for a the tricone that's in my avatar. It also list where to get german silver brass if you want to build it from that. My bodies were built with GS. So I can't say exactly how steel and yellow brass will bend and press. There are also links in that discussion that will so how I bent the sides and some other discussions on the build of the first one where I was led by my friend Mike Dotson and Mike Simpson. You can also find a template drawing of a tricone in their library and get a plan of a single cone from Resophonic outfitters which you can modify as I did to include a cutaway. Mike will probably chime in here too. If you bone up on all that material and have any questions I'm sure Mike or myself will help you out if we can.
PostPosted: Sun Apr 24, 2011 9:55 am
First name: Raymond
Last Name: Phillips
City: BENONI
Thanks Chris, really enjoyed your phot essay and a bunch of the other posts there as well.
PostPosted: Sun Apr 24, 2011 10:39 am
Do you think you'll be able to do it with that info? When are you starting? :)
PostPosted: Tue May 31, 2011 11:40 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
Moo
Paul Beard at Resophonic Outfitters has plans for a round neck metal body.
https://www.beardguitars.com/Merchant2/ ... ry_Code=BB
PostPosted: Tue May 31, 2011 4:41 pm
First name: Freeman
Last Name: Keller
And I have an Autocad drawing of the top of a tricone that is in the public domain. I can e-mail it either as a dwg or a pdf.
PostPosted: Tue May 31, 2011 4:49 pm
Freeman, I'll take one of those just to have it on file.
PostPosted: Tue May 31, 2011 7:44 pm
Last Name: Shanklin
City: Windsor
State: ON
Freeman, I would love a copy of that Tricone top plan in either format.
Bob
PostPosted: Wed Jun 01, 2011 10:03 am
First name: Freeman
Last Name: Keller
Bob
If anyone wants the plans please PM me your e-mail address and I'll send them out. I can do it in dwg (older A-cad, I think it is release 10) or full scale pdf (which Kinko or an engineering office should be able to print). I could even make a (shudder) paper copy and snail mail it. Obviously the dwg could be modified if you want to change scale length or anything, the pdf can not.
I built a wooden tricone from these plans (there is a thread on this subforum) and made the grills from stainless steel. Also used it to make a routing template for the top.
PostPosted: Fri Jun 03, 2011 3:24 pm
Last Name: Shanklin
City: Windsor
State: ON
Plans received.
Thank you Freeman.
Bob
PostPosted: Fri Jun 03, 2011 4:17 pm
Ditto!
PostPosted: Fri Jun 03, 2011 9:31 pm
First name: Raymond
Last Name: Phillips
City: BENONI
Got 'em - Thanks Freeman
cron
