It is currently Tue Sep 16, 2025 1:53 pm
PostPosted: Mon Jun 06, 2011 9:35 am
First name: Chad
Last Name: Smith
City: Farmington
State: UT
Zip/Postal Code: 84025
I have an HSH pickguard that I want to configure as follows ...
Bridge: Gibson 498T
Middle: DiMarzio Injector Bridge
Neck: Gibson Burstbucker Pro
I'd like to have a standard strat 5 way switch operation, however, I'd like to have both the humbuckers split-able. Is this do-able and how would you go about it? Ideally I'd like to have a single push-pull tone pot that acts as the splitter, however, I'd be fine to have the rear tone pot split the bridge and the forward tone pot split the neck.
If someone could point me to a wiring diagram or talk me through it it would be much appreciated.
TIA.
PostPosted: Mon Jun 06, 2011 10:14 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Dig through these.
Maybe you'll find something.
http://www.seymourduncan.com/support/wiring-diagrams/
PostPosted: Mon Jun 06, 2011 12:46 pm
First name: Chad
Last Name: Smith
City: Farmington
State: UT
alan stassforth wrote:
Dig through these.
... can't seem to find one suitable for my particular need. I'm new to this so that's probably my biggest problem :)
PostPosted: Mon Jun 06, 2011 5:36 pm
Last Name: D
State: CT
Now i didn't take the time to go through the diagram to see if it does what it says it will but if it does.... you can do it without the push pulls. but as it says it will auto split in certain positions of the 5 way. So I'm assuming this was your plan for the split anyway... If not you have some research on wiring to do and some diagram drawing to do seeing how i don't think you will find a diagram for your specific needs but 1 push pull can split both pick ups if you need it to.
http://www.guitarelectronics.com/produc ... 11-01.html
PostPosted: Wed Jun 08, 2011 7:16 pm
First name: Brett
Last Name: Faust
City: Puyallup
Zip/Postal Code: 98373
Think a bit more out of the box. The usual 5 way has 2 circuits, one on each side with 3 tabs + a tab for the common.
Try this, on your 5 way put the full coil HB outputs on one side of the switch and the series links on the other. This way you can separate the commons and turn down the HB full coil side with a pot( I use the extra tone pot ), leaving the split sounds from the other side of the switch. No push pull pots needed.
Hope that helps.
How long is that in luthyears?
PostPosted: Mon Jun 20, 2011 2:51 pm
Last Name: Smith
I just wired an HSH ax and ran into some serious problems due to the wiring diagrams, so beware. Since it was a 90`S Yamaha Pacifica with Dimarzio pups I figured that the Dimarzio diagrams would work. Here are the diagrams http://www.dimarzio.com/support/wiring- ... s#1-5-11-4
The problem is that the 5 way switch, 4 pole, 24 tabs (really cool) called EP1112 by Dimarzio was actually some Yamaha switch instead of Dimarzio. This made all the EP 1112 diagrams on the Dimarzio page wrong, all of them! Which ever diagram you use must be akin to the switch, and no Yamaha diagrams could be found!
I used this diagram, after spending hours figuring out the Yamaha switch, to pretty cool effects. All humcancelling with coil tap included. http://www.dimarzio.com/sites/default/f ... 1v1t_f.pdf
