It is currently Sat Aug 23, 2025 12:14 am
PostPosted: Thu Jun 09, 2011 10:57 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Has anybody ever used vacuum techniques to attach bindings? I realize one must reinforce the body to avoid collapse, but I am wondering if it is effective.
PostPosted: Fri Jun 10, 2011 6:44 pm
There was post a while back or an article in a journal showing a fellow who built a cut out much larger than the guitar body and he positioned it like a go bar deck above the guitar so that go bars contacted the binding area at about a 45 degree angle. This was used to clamp the bindings into place. It seems that there are many methods that work if the builder uses them correctly. It's really hard for me to imagine a safe and effective way to use a vacuum bag.
PostPosted: Fri Jun 10, 2011 7:14 pm
Mike, do you any ideas on how to keep the guitar from imploding from the press? If a gutar top was 240 sq inches or so, a quick guess on my part, the top alone would have over 3000 pounds on it inside a bag.
I'm interested to hear what your thinking though.
PostPosted: Fri Jun 10, 2011 10:09 pm
I agree with Jim, I think implosion is the biggest concern. My press is kind of unusual. It's a ring with a rubber membrane that fits over my radius dish and seals to my shop floor. I also use my press for gluing mdf parts for jigs and cauls. I had been flipping over my radius dish (1.5" thick) to get a nice flat work surface until one day I noticed that all my larger glue-ups were slightly warped. I wasn't sure what the problem was until I ran a panel through a drum sander and saw the contour of a radius dish. The vacuum was compressing the inverted radius dish flat to the floor and transferring that radius to my parts. Hmm, that might be a quick way to make radius dishes...
Bob
PostPosted: Fri Jun 10, 2011 11:04 pm
First name: jim
Last Name: mccarthy
City: ojai
State: ca
Zip/Postal Code: 93023
I fill my guitars right to the brim with water just before vacuum pressing the binding on.
In the past I had used sand instead, but it's just too messy.
PostPosted: Sat Jun 11, 2011 12:40 am
First name: Eric
Last Name: Reid
City: Ben Lomond
Zip/Postal Code: 95005
Many builders glue bridges with vacuum pressure. They don't put the whole guitar in a bag. Sealing around the edges of a purfling-binding operation would be more complicated, but I'm sure it could be done. I'd be surprised if some of the bigger companies hadn't worked on this.
PostPosted: Sat Jun 11, 2011 6:34 am
You would crush the guitar with a probability of 1
PostPosted: Sat Jun 11, 2011 9:49 am
I suppose you could put a bladder inside and inflate it . Then place in a bag and vacuum it. But you would need to increase the bladder presure to balance out the external pressure to 15 PSI. But how would you attach the binding with glue in the first place? If you were building the same guitar I'm sure an rimm clamp could be made but you still need to set the binding and apply glue. In this case I don't see the need to re invent the the wheel when so many ways work that are cheap as rope or tape.
PostPosted: Sat Jun 11, 2011 12:45 pm
First name: Eric
Last Name: Reid
City: Ben Lomond
If the bladder was vented to the outside, it would equalize automatically. But I agree, why bother?
PostPosted: Sun Jun 12, 2011 2:28 am
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
I think it's a grand idea. Please be sure to video tape your procedure and post to the tutorial section when you've got this nutted out. laughing6-hehe
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Sun Jun 12, 2011 2:52 am
Eat Drink
Nick Oliver
http://www.oliver-guitars.com
