It is currently Fri Aug 22, 2025 4:57 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Jun 30, 2011 10:53 am
Last Name: Burner
City: Lincoln
State: Nebraska
Zip/Postal Code: 68506
Tangent topic continued...
It's sort of like spending lots of money to get a really light weight bicycle.... when the cheaper issue would be for me to lose 20 or 30 (or more) pounds that I'm carrying around.
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Jun 30, 2011 10:58 am
Last Name: Burner
City: Lincoln
State: Nebraska
Semi back on topic...
So what radius do YOU use on your tops?
We are currently using 25', but I see that 28' and 30' are standard dish sizes that are available.
P A U L B U R N E R
Burner Guitars
PostPosted: Thu Jun 30, 2011 11:21 am
I use 30" Never saw a reason to change except you have to sand a little angle into the upper bout of the rimset to match the neck angle. I feather the ends of the lower X and face braces, use fairly traditional Martin type scalloping, and thin the edges of the top in the lower bout. Bass has not been a big problem, actually on dreds I work harder on trying to get good highs all the way up the neck. Dana's articles have been a big help to me.
PostPosted: Thu Jun 30, 2011 12:05 pm
I use a drastic 5' arch on my tops and never had a problem getting good bass response even on single 0's and smaller. I don't feather the lower x-braces either, but tuck them in the linings 1/16" high. Before using a 5' arch I used a 20' radius on my tops and had no issue with bass response either.
I fear the answer is somewhere else, and is not a simple one either.
If you have trouble getting the bass response you want on a 16" guitar, I can think of 5 main things: top too thick, top braces too high, bridgeplate too big, bridge too heavy and back too stiff (too thick, and/or overbraced). Either one of those, or an infinite combination of them in any number.
I do a bit of perimeter sanding sometimes -and I think of it as a remedial solution-, but I know a few other builders who do not and still get tremendous bass response.
OTOH, good bass response compared to what? Other guitars?
Laurent Brondel
West Paris, Maine - USA
PostPosted: Thu Jun 30, 2011 12:07 pm
I use a 28' radius. I used to glue that onto a flat rim. These days I sand a 50' radius into just the UTB area.
PostPosted: Fri Jul 08, 2011 7:20 am
Last Name: Burner
City: Lincoln
State: Nebraska
So....
Have many of you done work to braces after the guitar is done???
Do you hire really skinny armed people to do this?
P A U L B U R N E R
Burner Guitars
PostPosted: Fri Jul 08, 2011 8:44 am
Last Name: Haney
City: Sugar Land (Houston)
Zip/Postal Code: 77479
Darryl Young wrote:
Tony_in_NYC wrote:
You could try getting the guitar to have a baby. That certainly gave my wife more bottom end! :lol:
I about fell out of my chair when I read this one laughing6-hehe
Wives have been know to "check" computer postings. Living dangerously here? wow7-eyes
PostPosted: Fri Jul 08, 2011 8:50 am
First name: Kyle
Last Name: Burner
City: Lincoln
State: Nebraska
laughing6-hehe we definitely do not fit into the "skinny armed people" category
--Kyle Burner--
PostPosted: Fri Jul 08, 2011 12:02 pm
Filippo Morelli wrote:
Bass also tends to be mostly there when a guitar is strung up, where as other attributes can take years to mature (especially with spruce) and arguably with greater top thickness.
Filippo
In my experience, bass develops over time; as least as much as other components of a guitar's sound. Usually more so.
PostPosted: Fri Jul 08, 2011 12:21 pm
Online
I'm pretty beefy so my apprentices got to stick their arms in the soundhole.
PostPosted: Fri Jul 08, 2011 1:24 pm
Filippo
I agree with Howard here. As a matter of fact, I do not take it as good sign if a guitar has lots of bass when it is very young, in my experience that can mean it is built a bit on the light side, and can become somewhat muddy sounding as it ages.
I agree with most of what Laurent is saying, but I'm not sure if a heavier bridge always means less bass. In fact, I have seen improvement in bass response by adding weight to the bridge area. At least is sounds that way; I've read some knowledgeable folks who say that a heavier bridge means the balance between the frequencies may shift so that it sounds like there is more bass, but in fact there is less overall sound output. Maybe so.
PostPosted: Fri Jul 08, 2011 5:25 pm
First name: Darryl
Last Name: Young
State: AR
I believe Somogyi said in his book that it's easy to get bass out of a classical and easy to get treble out of a steel string........and difficult to get good treble out of a classical and difficult to get good bass out of a steel string.
PostPosted: Fri Jul 08, 2011 8:42 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Tony,
I can only assume your wife doesn't read your posts! laughing6-hehe
PostPosted: Sat Jul 09, 2011 6:25 am
You are correct, except I would characterise added mass on the bridge with more focus in the bass registers, not necessarily more bass per se. In other words the bass has to be there to start with IMHO. In any case I was thinking of some "modern" bridge designs I have seen which are pretty massive and certainly limit both volume and bass.
Then it must be true…
What is difficult is to achieve good balance between the registers, a large dynamic range and power. That's where the art is. But that is true of every instrument, even a flute. It is easy to get good bass from a large body guitar, especially a dreadnought. It is so easy that it is most often at the detriment of other qualities in the guitar (i.e. balance, and power in the treble registers, especially high up the neck).
While it is true that the tone of guitars become smoother with time, for lack of a better term, an instrument lacking in bass, for example, will not magically develop a good response in the low registers within a few years. The guitar's character is all there a few days after being strung up for the first time, often just a few hours.
A 16" guitar should put out quite a bit of rumbling. OTOH some players (and builders perhaps?) have unrealistic expectations from an acoustic instrument. IMHO this comes from a few generations of people listening exclusively to amplified and processed recorded acoustic music. But that is another subject…
Laurent Brondel
PostPosted: Sat Jul 09, 2011 8:55 am
Sorry for going off topic, but Laurent, you said five foot arch? Is that a typo? I've trolled around your site before and would have thought I'd notice something like that.
If you haven't checked out his site, you should. He does beautiful work.
Mike Lindstrom
PostPosted: Sat Jul 09, 2011 9:23 am
First name: Darryl
Last Name: Young
State: AR
Thanks for commenting on the Somogyi comment Laurent........I was hoping an experienced person would.
PostPosted: Sat Jul 09, 2011 10:20 am
What this discussion also demonstrates, is that different builders (and players) have very different goals, and I suppose ideals, when it comes to stuff like this. What Laurent and finds as missing qualities in a dread, can be just the thing others are looking for. An early poster in this thread even said that he'd played several D-28's that were lacking bass, while D-35's in his opinion usually had good bass. To me, D-35's often have huge bass all right, but they also often sound muddy and otherwise uninteresting. But, some folks obviously love them. Different strokes, and all that...
PostPosted: Sat Jul 09, 2011 11:26 am
Not sure I am experienced, but my comment was ironic Darryl…
Laurent Brondel
PostPosted: Sat Jul 09, 2011 1:40 pm
First name: nick
Last Name: fullerton
City: Vallejo
State: ca
Zip/Postal Code: 94590
You could try recording it, burning one, and turning up the bass on your amplifier. :mrgreen:
PostPosted: Sat Jul 09, 2011 3:05 pm
This worked for me:
PostPosted: Sat Jul 09, 2011 3:23 pm
First name: Chuck
Last Name: Hutchison
City: Houston
Ok, Ima gonna get smashed for this but here goes.......Why not just put bass strings on the E and A stings and be done with it............lol
Hutch
PostPosted: Sat Jul 09, 2011 3:42 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Howard, more pics of that, pleeeze!
PostPosted: Sat Jul 09, 2011 4:26 pm
Last Name: Itzkin
State: NY/Granada
Country: USA/Spain
Looks like the Nakyd Ladie, here is a link to Howard's website with pix of that guitar
http://www.klepperguitars.com/nakydlaydie.html#
PostPosted: Sat Jul 09, 2011 6:56 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Howard... laughing6-hehe
PostPosted: Sat Jul 09, 2011 8:22 pm
First name: Chuck
City: Houston
Dagnabit Howard.............you sure do have a knack for slappin' together some wood and out comes a work of art. You've always inspired me, thanks for sharing.
Hutch
