It is currently Sat Aug 02, 2025 8:51 pm
PostPosted: Mon Dec 19, 2005 12:37 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
Have seen 3/32, 1/8 and some others discussed here.Would you please discuss different widths and the pros and cons for each?
Thanks Much,
PostPosted: Mon Dec 19, 2005 1:04 am
Pros being that you can intonate each note more accurately. Cons being that a fat saddle looks kind of funny. That's all I can think of.
PostPosted: Mon Dec 19, 2005 3:14 am
[QUOTE=Hesh1956] Mike Doolin seems to use the fattest saddles I have seen so far.
Hesh[/QUOTE]
Look at the size of Ervin Somogyi's saddles. Those things are huge.
PostPosted: Mon Dec 19, 2005 3:33 am
Another advantage of fat saddels (aslong as enough material is left in front of the slot on the bridge) is the extra bearing surface helps carry the forward pull load cause by the strings by distributing the load over a larger footprint.
PostPosted: Mon Dec 19, 2005 5:02 am
The only downside to using a wide saddle (IMHO) is that it complicates the installation of an undersaddle pick up.
I like having the extra wiggle room the wider saddle gives when setting the intonation.
PostPosted: Mon Dec 19, 2005 5:13 am
M Greenfield uses a very wide black horn saddle as well, at least I think its black horn, but definitely wide, like about a 1/4 inch.
PostPosted: Tue Dec 20, 2005 12:43 am
Last Name: Johnson
State: CO.
Thanks much
Users browsing this forum: No registered users and 48 guests
