It is currently Sat Jun 21, 2025 12:23 am
PostPosted: Mon Oct 17, 2011 1:27 pm
First name: Virgil
Last Name: Mandanici
State: FL
Like to thank JimO for this thread: http://www.luthiersforum.com/forum/viewtopic.php?f=10123&t=31478&start=25 , where he had a very simple, yet effective fingerboard radius jig - I HAD to pimp mine out though to save time and money on double-sided tape - I made mine with a build-in vacuum press - I gotta go, so here's some pics for now:
BTW - I timed myself and it took under 4 minutes to rout it out - used a 3/4" router bit and made about 6 passes - barely seeing any lines - will take under a minute to sand down now - WOOT WOOT!
PostPosted: Mon Oct 17, 2011 1:46 pm
Last Name: Livermore
State: Minnesota
Fantastic!
Thanks for Sharing
PostPosted: Mon Oct 17, 2011 2:26 pm
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
Very nice work. Like the vacuum press idea. I hate double stick tape anyway. Also like the wingnuts on the end plates. I was thinking about something like that.
Way to go! [clap]
PostPosted: Mon Oct 17, 2011 3:02 pm
Had enough of the sanding beam I take it? :D
Old growth, shmold growth!
PostPosted: Mon Oct 17, 2011 3:28 pm
First name: Virgil
State: FL
Way to go! [clap]
Ha! There you are Jim! Thanks for the inspiration - been looking at a few of these over the past 6 months or so, but liked yours the best - seemed simple enough and effective and now all I have to do is make some endplates for different radii. Did ya see the thumbscrews on the underside of the conduit? I used brass inserts in the wood and they lock it in place pretty good as well. On my test board, I did notice that it went a slight bit deeper than the other end of the board, so i figured I could just slip a thin piece of veneer under the endplate. The router marks are really really REALLY faint by using a Whiteside 3/4" bit and are hard to see with the naked eye, so I am imagining that when I get my aluminum sanding beam from StewMac, it will just take a few passes to fine tune - thanks again for posting pics of your contraption - you just added some more productive hours to my life! BTW - love the purpleheart skunk stripes on that neck!
Thanks, V
PostPosted: Mon Oct 17, 2011 4:02 pm
First name: Jim
Last Name: Hansen
Nice Virgil. You build really nice jigs!
Now when are you going build a work bench ? :P :P
Jim Hansen
PostPosted: Mon Oct 17, 2011 5:25 pm
First name: Virgil
State: FL
I got 2 of them so far - one is mainly for my inlay and little stuff and the other has my drill press/bandsaw - was thinking of a 3rd! ;)
PostPosted: Wed Oct 19, 2011 5:17 pm
First name: shad
Last Name: peters
That is an interesting jig, I would never have thought of doing it that way. I have been contemplating a fretboard radius jib for a while, but was planning to make some sort of swing arm for my belt sander, I like the vacum press idea and I might have to steal it for my eventual jib :)
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Wed Oct 19, 2011 6:01 pm
First name: Virgil
State: FL
Thanks Shad - After running a couple of test pieces I noticed it went approx. 1/32" or so deeper on one side. Solution: Slipped some veneer strips under the radius board on one end and problem solved!
PostPosted: Wed Oct 19, 2011 6:23 pm
First name: Erik
Last Name: Hauri
State: Maryland
Nice jig!
For the end pieces, make a single thick radius template and then slice it in half on the bandsaw.
The member formerly known as erikbojerik....
PostPosted: Wed Oct 19, 2011 6:49 pm
First name: Virgil
State: FL
Erik Hauri wrote:
Nice jig!
Hmmmm, I cut a board in half, laid them side by side and routed out the half circle together - I don't have a good enough bandsaw for that ;)
Users browsing this forum: Bing [Bot] and 7 guests
