It is currently Wed Sep 17, 2025 2:40 pm
PostPosted: Fri Dec 23, 2011 8:57 am
First name: Patrick
Last Name: Hufschmid
City: Montreux
Country: Swizterland
http://hufschmidguitars.com
PostPosted: Fri Dec 23, 2011 9:14 am
First name: Patrick
City: Montreux
PostPosted: Fri Dec 23, 2011 9:19 am
First name: Patrick
City: Montreux
PostPosted: Fri Dec 23, 2011 9:20 am
You know, I am sick and tired of you having all the cool wood. gaah :D
PostPosted: Fri Dec 23, 2011 9:24 am
First name: Patrick
City: Montreux
pizza laughing6-hehe
PostPosted: Fri Dec 23, 2011 9:32 am
First name: Patrick
City: Montreux
PostPosted: Fri Dec 23, 2011 10:05 am
First name: Mark
Last Name: Sorrentino
You were more impressed than I.
PostPosted: Fri Dec 23, 2011 11:10 am
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
Beautiful work.
How difficult is the Afzelia to work? Is it similar to any other woods in terms of workability?
Kevin Looker
I'm not a luthier.
PostPosted: Fri Dec 23, 2011 12:20 pm
First name: Patrick
City: Montreux
klooker wrote:
Beautiful work.
Kevin Looker
thanks man :)
Afzelia is a wood which turns into powder-like, just like Padauk does...
Its not very easy to file and work with because of the interlocking grains however it is very easy to sand, also you must always use very sharp router bits because otherwise it has a tendency to chip...
The worst part: It stinks so bad, very hard to describe the smell, however if you do not wear a respiratory mask, your in trouble... [xx(]
The great part is that for some reason it stays totally non-reactive to moisture exchange, I've done several tests and I must say that I am extremely impressed, the timber does indeed stand up to it's reputation!
check this out, its in french but I am sure you can use google translator...
http://www.pallisco-cifm.com/download/Fiche_Doussie_v1.pdf
PostPosted: Fri Dec 23, 2011 5:10 pm
State: AR
Superb craftsmanship and just a beautiful guitar.
Not only a pleasure to see your art in progress but the
additional information you provide makes it even more special. (not only
this build but the others I've read too)
As a beginner I appreciate your offerings very much.
Thank you Patrick.
PostPosted: Fri Dec 23, 2011 10:48 pm
First name: Virgil
Last Name: Mandanici
State: FL
Nice grainage there Patrick! [:Y:]
PostPosted: Sat Dec 24, 2011 5:31 am
First name: Patrick
City: Montreux
Thank you Patrick.
aw, thank you for your kind words man, this made my day, thank you! :)
Todd Stock wrote:
Got lots of ipe scrap if anyone wants to pay shipping...do a couple decks with the stuff and you'll have a lifetime supply. Dulls HSS worse than anigre...lots of silica...crosscut the ends and see some serious glitter...
haha if you have Ipelia decking, then you have a life time supply! [:Y:]
The pace where I buy my sapelli is the main ipellia distributor in switzerland...
that's a lot of string blocks right there! laughing6-hehe
PostPosted: Sat Dec 24, 2011 8:31 am
First name: Patrick
City: Montreux
got some new updated...
PostPosted: Thu Dec 29, 2011 1:22 pm
First name: Patrick
City: Montreux
guitar is finally completed and here are the final pictures, enjoy! :)
PostPosted: Thu Dec 29, 2011 8:01 pm
First name: Virgil
State: FL
How does one say "spectacular" in Swiss? [:Y:]
PostPosted: Thu Dec 29, 2011 9:53 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Swiss-tacular!
Great job Patrick!
Nice thing about a top cap like that one is,
you don't need bindings!
PostPosted: Mon Jan 02, 2012 11:30 am
First name: Shawn
Last Name: Smith
City: Indianapolis
Patrick what do you use to bolt your necks on? it really is a nice clean look.
"All of us contain Music & Truth, but most of us can't get it out."
- Mark Twain
PostPosted: Mon Jan 02, 2012 6:44 pm
I really like that industrial look. Also I like the vintage effect you achieved without resorting to the cheesy beat up look that so many relics have.
PostPosted: Tue Jan 03, 2012 4:26 pm
First name: Patrick
City: Montreux
thanks guys :)
Took some more pics before delivering the guitar to its new owner :)
I either use special screws which are pretty much indestructible (designed for concrete) which go directly into the wood of the neck (I just grind off that part you see on the tips)
Or I also use a t-nuts inserts design which I've been doing since 1998, I epoxy them in place like on this picture...
the hole being bigger than the actual t-nut gives room for the epoxy to go arround it...
The screws are stainless steel and are also indestructible...
In both cases, I use a brass surround so that the top of the screw looks nice and cleanely fitted to the body... :)
PostPosted: Tue Jan 03, 2012 4:37 pm
First name: Virgil
State: FL
At first I was excited that it had some really cool scenery, then it turned into a nasty, dirty porn!
First name: Virgil
State: FL
Oh, sorry, that's adhesive!
First name: Patrick
City: Montreux
laughing6-hehe pizza
PostPosted: Tue Jan 03, 2012 5:00 pm
First name: Patrick
City: Montreux
Filippo Morelli wrote:
I like the wheel end option on the Hot Rod truss rods from StewMac and have used them. On the other hand, the fattest truss rod in the business is the same thing and I've had issues with the depth required for the truss rod when carving necks. Not enough meat behind the brass block at the 1st fret. One can actually feel the depression being caused by the truss rod when pushing back. I've switched to the Allied Lutherie truss rods which Mark Blanchard designed.
What we really need is for someone to design a pinwheel (like on the Hot Rod) which has a hex stub on the other end. Then one can stick that on any truss rod and get body side adjustments.
Filippo
my necks are 22mm (fingerboard included) at the first fret so there is plenty meat....
But I see what you mean, especially when you want to carve thinner necks, it then becomes a problem...
LMII actually offers spoke nuts on their double way truss rod which is thinner then the stewmac rod but they only do that on order, you must contact Chris for that...
On the other side, the stewmac rod is perfect because the threads are inserted inside the brass, there is no welding which makes them extremely tough and durable... [:Y:]
PostPosted: Tue Jan 03, 2012 7:22 pm
First name: Shawn
Last Name: Smith
City: Indianapolis
wow. thanks for the detailed and informative response patrick. I am looking at a threaded insert/machine screw solution for my current project. I like the idea of counter sunk ferrules.
- Mark Twain
