It is currently Tue Jul 15, 2025 1:03 am
 Post subject: My 1st Stupid Question
PostPosted: Wed Jan 04, 2012 2:53 pm
First name: Rick
Last Name: R
Hey all,
So I picked up some Honduran Mahogany today in 7 inch wide boards. I plan to centre join the wood and make a few solid body blanks for future builds topped with figured Maple.
Question - When you are joining wood for guitar building do you use dowel plugs or biscuit joints?
Sorry for the embarrassingly stupid question, but I would rather get started in the right direction.
Rick
PostPosted: Wed Jan 04, 2012 3:53 pm
I dont use dowels or biscuit joints. I just flatten the sides of both boards, put some glue on there, and glue them together between some bar clamps. Never had a problem doing it that way.
PostPosted: Wed Jan 04, 2012 4:15 pm
Biscuits can help strengthen a weak join and dowels can help in aligning difficult to align pieces for gluing. Neither should be necessary for the type of joint you are making.
Old growth, shmold growth!
PostPosted: Wed Jan 04, 2012 5:25 pm
First name: Stuart
Last Name: Gort
No reason to reinforce a body joint like that. Get the surfaces straight and clean, apply Titebond regular or extend to both edges, and use adequate clamping pressure. Leave it sit overnight in the clamps at indoor temperature. I routinely glue sapele body blanks this way.
StuMusic
PostPosted: Wed Jan 04, 2012 5:28 pm
Leave the biscuits and dowels to the cabinet makers....
Reminds me of the pinheads who used to come in my shop and say, "Oh, you're a wood worker. Can you make me a shelf?". We're not carpenters.... we're luthiers.
PostPosted: Wed Jan 04, 2012 5:45 pm
First name: Jim
Last Name: Hansen
My Sister recently ended a conversation with me with the following phrase...
"If you can build a Guitar, surely you can re-build a DECK!".... eek
Jim Hansen
PostPosted: Wed Jan 04, 2012 7:31 pm
First name: Patrick
Last Name: Hanna
State: Missouri
Okay, all jokes aside, let's don't confuse our first time correspondent.
No dowels or biscuits are needed nor desired. A straight, perfect joining edge on each joining piece is desired. Hold the two surfaces together and then hold them up to a strong light. If you can see light through them, they aren't ready for gluing yet. This is so frustrating to most of us. I still struggle with it every single time. It makes me crazy, but I press on until the joint is light-tight.
Google up the term "shooting board". You will soon see how a shooting board works with a plane. If all else fails, you can glue sandpaper to a 36" carpenter's level and use that after the plane. I admit I do that most of the time. If you do sand, then you must meticulously get all the sanding dust off the joining surfaces before you glue. I am talking about sweeping with a brush and then wiping with a paper towel soaked in naphtha. You'll be amazed how much sanding dust you see on that last paper towel.
When your towel comes away clean and your joint is finally light-tight, it's ready for glue. Be patient, and you can do it.
PostPosted: Thu Jan 05, 2012 5:46 pm
First name: Rick
Last Name: R
Thanks everyone,
Very helpful.
Rick
PostPosted: Fri Jan 06, 2012 3:23 am
First name: Patrick
Last Name: Hufschmid
City: Montreux
Country: Swizterland
I always build one piece bodies...
However when I fall on a very rare piece of wood which is too small for building a one piece, I use a shark joint...
(but there is no need too do this, a simple joint is perfect)
(watch the end grain)
http://hufschmidguitars.com
PostPosted: Fri Jan 06, 2012 11:29 am
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
I give.
What's a "shark joint"?
PostPosted: Fri Jan 06, 2012 11:42 am
First name: Patrick
City: Montreux
alan stassforth wrote:
I give.
I dont know how you guys call it...
Taylor Guitars has been using it for many many many years for their headstock joint, nothing new at all :)
Do you call it a Finger joint by any chance?
whatever laughing6-hehe
PostPosted: Fri Jan 06, 2012 12:03 pm
First name: alan
City: Santa Rosa
State: ca
I would call that a fingerjoint,
but it's slightly different.
The v's are symmetrical.
I like the sound of a shark joint better!
Do you have a cutter that does that?
Oh, nice git by the way!
PostPosted: Fri Jan 06, 2012 12:07 pm
First name: Patrick
City: Montreux
I dont, my workshop is too small for big power tools so I have to go and see a carpenter friend of mine to use his tools...
Its a simple set up on the jointer, you can order a blade which is configured to cut that way as oposed of cutting a flat surface, nothing new... :)
PostPosted: Fri Jan 06, 2012 3:31 pm
First name: Stuart
Last Name: Gort
That "shark" joint has a purpose on that Taylor neck/headstock transitional area where stress accumulates. A finger joint like that adds many times the surface area to that joint, which spreads out the load, reducing any focused point load on the glue, making it work a fraction as hard as it would in a simpler joint.
Joined body panels have no stress to speak of. Without stress the only consideration is the aesthetic aspect of the joint. Joined edges are as beautiful as your craftmanship dictates. Make the edges flat, clamp them up well......viola.....a beautiful joint that will never fail unless you clamped stressed parts together. So don't do that. Don't forced them flat and glue them....work each piece flat THEN glue them.
StuMusic
PostPosted: Fri Jan 06, 2012 4:02 pm
Speaking of shelves and finger joints (isn't that what this thread was about? :D ) I bought some scrap oak shelves in the cheapo bin to make guitar hangers from and they were finger jointed with what looked like a random pattern rather than the even ones you usually see. Worked too, very tough to notice unless you really look hard.
On topic, I don't own a biscuit jointer but I can see where one might come in handy for glue ups on solid bodies. Not for strength or to take the place of good jointery, but for alignment.
I like Patrick's method actually, might have to look into that since I almost always do 2-piece bodies.
