It is currently Sun Aug 03, 2025 8:27 am
PostPosted: Mon Jan 02, 2006 12:24 am
Probably pretty simple but planning on painting a guitar and wondering how the rosette gets done on a painted soundboard??
Paint it and then install the rosette? Or do you simply tape off the rosette during the painting process? (Seems like build up of paint would show)
PostPosted: Mon Jan 02, 2006 12:40 am
Hi Rich
    This is a tricky operation for the first timer. You will install the rosette , seal , then mask off the rosette . once the paint is cured you pull the masking off and finish with a clear coat over the paint to fill the void of the masking.
     I hit the first coat and then drop fill the rosette , hit another coat or 2 then level sand. That way I have a cusion and don't sand into the paint.
   If you try and install the rosette after paint you will allmost be garanteed chip out.
john hall
PostPosted: Mon Jan 02, 2006 12:57 am
Geeeez, when you get such a simple answer to something that seemed so complex it is almost an embarrasement.
Especially when my first 15 years of work life was as a body man and painter!!!!
Thanks John
PostPosted: Mon Jan 02, 2006 8:12 am
yeah, but this ain't your mom's buick!
cron
