It is currently Mon Sep 15, 2025 2:26 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: 4 sided setup
PostPosted: Sat Feb 18, 2012 7:49 pm
Zlurgh wrote:
The vaccum will have varied effectivness with different species....and the holding power is based upon species permeability, surface area, and vacuum cfm. Could be that you're getting marginal on several of those factors. .
As a little follow up, a buddy brought over a bigger pump, either 3 or 5 cfm (I still need to look it up) and thought it's not as good a vacuum as the other sides, it's much better and strong enough to machine with.
I'm not going to run out and buy another pump though as I'm pretty sure I'm going to do the 4th axis thing.
PostPosted: Mon Feb 20, 2012 1:16 pm
First name: Nelson
Last Name: Palen
Andy, I'm curious how you would clamp a neck for machining on all four sides on a rotary 4th axis.
I'm surprised that you wouldn't use vacumn.
Nelson
PostPosted: Mon Feb 20, 2012 3:52 pm
So, my thought is to have a nub type thing on the top and the bottom of the neck. Bottom would go into a 4 jaw chuck and the top into a live center in a tail stock.
Once all 4 sides are machined, I'd do one last operation face down in a vacuum fixture or, just clean up by hand.
The problem is that maintaining alignment on all sides is difficult. With a 4th, so long as I do a good job aligning it to begin with I should be ok. Instead of 2 to 4 tool changes per side, I'll have 4 tools grand total.
