It is currently Sun Aug 03, 2025 10:21 am
PostPosted: Tue Jan 10, 2006 7:59 am
I need a couple of thicker saddle blanks...say, 3/16" or a touch over...any takers? Thanks!
PostPosted: Tue Jan 10, 2006 10:19 am
This post just FELL down the list!
PostPosted: Tue Jan 10, 2006 10:41 am
   Try LMI, they have some at 7/32... You'll need a pretty specialized bit to cut a channel, though. Unless you want to try to excavate a la Cumpiano/Nathelson.... (I tried it and hated it)...
   Ridge Carbide tools have some solid shear face solid carbide bits (7/32) for 20$. Check it out:
http://www.ridgecarbidetool.com/html/spiral_shearface.htm
   If you don't find what you want, they'll custom make some for you.
   I ordered some bits form them and they were at my door within a week (although customs through UPS stole me blind...) A shout out to Ridge Carbide Tools for the quality and expediency of their service!!!
PostPosted: Tue Jan 10, 2006 10:55 am
Larry, how many do you need? I've got some 1/4" inch and could spare a few. Drop me a pm or email. Paul
PostPosted: Tue Jan 10, 2006 10:59 am
You could try to cut some yourself if you have a bandsaw.
Sterilized bone is available at pet supply stores in the 'doggy' department. $3 to $5 depending on size. Has anyone else tried these for guitar saddles/nuts?
CrowDuck
Chris Nielsen
Soquel, CA.
PostPosted: Tue Jan 10, 2006 11:35 am
Alain, well that's the thing...This particular saddle slot was cut wider by someone a little Dremel-happy...I suspect it was a 1/8" bit, and by the time the depth was reached it was wider than that...so the slot's there, I just need a tight saddle...
Paul, I'll PM you...
Crow, never thought of that...mebbe I'll pick up a pet store bone and try it out sometime and see how it goes...thanks!
PostPosted: Tue Jan 10, 2006 12:01 pm
Hi Larry..
I have some that are just a hair thicker than 3/16"
If you can use them let me know.
walter
PostPosted: Wed Jan 11, 2006 4:17 am
thicker saddle blanks are normally available from euphonon.
i have some if you haven't got one yet.
PostPosted: Wed Jan 11, 2006 5:35 pm
LMII part S3 at
http://www.lmii.com/CartTwo/thirdproducts.asp?searchtext=sad dles&NameProdHeader=Bone+Nuts+%26+Saddles
