It is currently Sun Jul 20, 2025 2:12 am
Post new topic Reply to topic  [ 148 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sun Oct 07, 2012 5:39 pm
More shop time today. I'm almost ready to shoot some clear lacquer, which better happen soon if these are to be done in time.
First up are the necks.
Used a bit of amber dye on the uke neck and sealed it with a couple of coats of lacquer. Used a water slide decal for the headstock logo. The mando neck got some black lacquer and some clear for sealer. The logo is on this one now also. I better order up those tuners soon. I hate drilling through the finish.
PostPosted: Sun Oct 07, 2012 5:46 pm
Then it was transparent black on the Jazz Mando body.
1 Coat.
2 Coats.
3 Coats.
Stopped at 4 coats.
PostPosted: Sun Oct 07, 2012 6:51 pm
That black looks good [:Y:]
PostPosted: Sun Oct 07, 2012 7:19 pm
First name: Big
Last Name: Jim
+1 Where did you get that spray ?
PostPosted: Sun Oct 07, 2012 7:36 pm
Thanks Steve, I think this is going to look cool when all done.
Jim,
Thats the same black as on the neck and top. I had some left over from a batch I mixed up for a hutch I built for a client. I mixed that with some clear, about 5 or 6:1 clear to black. I added black until the mixing stick started to show the color once the excess had run off, then I added a little more.
PostPosted: Sun Oct 07, 2012 8:39 pm
First name: Big
Last Name: Jim
Jim,
Gotcha !! [:Y:]
PostPosted: Sat Oct 13, 2012 5:39 pm
Spent some time spraying lacquer today.
This neck is for a dread. The body is ready but I had to fix an unfortunate miscalculation on the headstock.
PostPosted: Sat Oct 13, 2012 5:42 pm
The baritone uke.
PostPosted: Sat Oct 13, 2012 6:03 pm
And the jazz mando.
I really like the Jatoba with the black top, I'm not sold on it's combo with the silver maple yet. My shop lights are a bit harsh so I'll have a look out in natural light tomorrow and decide then.
The neck won't get any more lacquer until I fix the logo and drill the tuner holes.
PostPosted: Sun Oct 14, 2012 9:11 am
First name: Big
Last Name: Jim
On the other hand I am sold. Looks awesome.
Filippo
Im with Fillippo on this , I like the look ! [:Y:]
PostPosted: Sun Oct 14, 2012 7:32 pm
Filippo
Thanks guys,
I'm better now, I saw it in daylight and the lacquer buzz had worn off.
Sanding and spraying again today. Drilled the tuner holes and deleted the waterslide logo on the mando neck. It peeled right off, must not have soaked it long enough.
Nothing says fun like watching paint dry.
PostPosted: Mon Oct 15, 2012 9:14 am
First name: Patrick
Last Name: Hanna
State: Missouri
Steve,
Thanks for the additional fret jig pics. I didn't see them until this morning. Glad I checked back. Very cool instruments you've got there!
Patrick
PostPosted: Mon Oct 15, 2012 7:12 pm
Not a problem Patrick. Thanks for the compliment. I'm having fun building these, a nice departure from what I usually build and gives the brain a little excercise.
Finished spraying the lacquer today. Now I can tackle the mute for the uke and the bridge for the mando.
PostPosted: Wed Oct 17, 2012 5:08 pm
My version of a mandolin bridge.
Start with a block o' wood 2 1/2" x 1"
Cut some slots on the table saw to establish rough intonation.
Spindel sander to make a nice radius to seperate the feet.
Cut off the wedges with a small backsaw.
Taper the sides above the feet.
PostPosted: Wed Oct 17, 2012 5:17 pm
Mark the string positions.
Drill some holes.
A little work with the fret saw and Voila! A violin inspired mandolin bridge. Final shaping will be done once it can be fitted to the insturment.
PostPosted: Wed Oct 17, 2012 5:31 pm
Wacky contraption time.
I don't know if it would be fair to blame this on Todd Stock, but the fact of the matter is that the Greenridge Guitars finish curing accelerator unit was the inspiration for this.
Yes, that is my downdraft table with a cardboard chimney attached. I rewired the fan for low speed and made a rack to hold the bodys and necks.
In two days I'll block sand everything out and two weeks later I'll wet sand and buff.
PostPosted: Wed Oct 17, 2012 7:47 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Jeez Steve, I wish you weren't so lazy. Couldn't you have built just one or two more things? Everything looks awesome.
PostPosted: Wed Oct 17, 2012 9:22 pm
Thanks Beth.
I'm considering trying to meet Filippo's challenge to get one more in by the end of November and the end of the $150 budget. It might have to be something ugly...
PostPosted: Thu Oct 18, 2012 11:52 pm
First name: Tony
Last Name: C
City: Brooklyn
Whatever you do, don't build a uke and then kick the top in like someone else we know ...
Filippo
You totally don't want to do that. First you need to route a quarter inch wide channel in the wrong place then waste weeks coming to the conclusion that you need to retop it. That's what a true pro would do anyway. laughing6-hehe
http://www.CostaGuitars.com
PMoMC
PostPosted: Fri Oct 19, 2012 6:14 am
If you look closely at the pictures you'll notice the jazz mando has had it's top, neck and sides replaced. The mistakes that caused replacement were arguably more rookie than Tony's but no pics, no proof, no doofus of the month award.
PostPosted: Fri Oct 19, 2012 7:35 am
First name: Tony
Last Name: C
City: Brooklyn
Without pics, it didn't happen. But then, why did you rat yourself out? And now I am curious as to what kind of mistake could have wrecked everything except the back plate. Did you sit on it?
PMoMC
PostPosted: Fri Oct 19, 2012 6:01 pm
Maybe I'm needling you a bit for taking two weeks to come to the conclusion to follow suit.
The headstock design wouldn't work with the tuners, I'm happy to report that the Gorrilla Glue works on steel as claimed.
The top was glued to the sides when I realized I hadn't leveled the linings on the back side. I had the brilliant idea to send the assembly through the Performax 16/32. The Performax thought that was a stupid idea and proceeded to show me why. Binding those f-holes twice really drove home the lesson.
PostPosted: Fri Oct 19, 2012 6:19 pm
Alright I knocked off another $2.30 from the budget.
My friend Ron the painter called Wednesday, he was working on a job and the carpenters had left behind a bunch of 1'4", 1/2" and 3/4" B2 maple plywood. So for the cost of driving 5 miles and hauling some of Rons equipment I scored 4 sheets of plywood in various sized pieces.
I finished up work around 1:30 today and decided to build a Cajon. I stopped a the store and bought a 3/8" dowel rod and some of those sliders for chair legs.
Here are some of the pieces of plywood.
Here they are cut into parts.
PostPosted: Fri Oct 19, 2012 6:26 pm
Glue and nail some supports to the top and bottom.
Glue the top and bottom and sides together.
My rosette and soundhole cutter came in handy to cut the soundhole in the back panel.
PostPosted: Fri Oct 19, 2012 6:38 pm
Lately people have been adding snares to these box drums. I don't really like the sound but what do I know? I'm building a cheap box drum in the build challenge for a luthiers forum...
So you take a bunch of those E,A and D strings that are laying around from opening sets to replace broken B and e strings and cut them to around 10" long.
Wrestle with these for a while untill you can get the all to line up nicely on a block of plywood covered with Gorrilla glue. Cap with another piece of plywood the same size and clamp the living .... out of the assembly with your biggest antique clamps.
