It is currently Sat Sep 13, 2025 11:06 pm
Post new topic Reply to topic  [ 148 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Oct 19, 2012 6:43 pm
While the glue was drying I took the front piece to the thickness sander.
Ran it through until it was about .100 thick. I was thinking about using this for the face, but I did'n't.
PostPosted: Fri Oct 19, 2012 6:52 pm
Next up was gluing and nailing the snare supports to the box.
Screws attach the snare in the upper left corner.
Another block of plywood to mount the dowel rod and a J-slot. When the dowel is moved to the catch of the slot, it pulls the snare off the skin.
Last for today, glue the face and back on.
PostPosted: Fri Oct 19, 2012 11:34 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Steve, I really want to build a Cajone sometime! You make it look easy, but I doubt it is.
PostPosted: Sat Oct 20, 2012 6:33 am
Here is a site with a tutorial for you Beth. http://www.thecajondrumshop.com/index.php?page=How-To-Build-A-Cajon
PostPosted: Sat Oct 20, 2012 8:44 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Thanks Steven!
PostPosted: Sat Oct 20, 2012 2:00 pm
I forgot the camera today. The drum is now all routed, sanded and the first coat of poly applied.
PostPosted: Wed Oct 31, 2012 8:39 pm
I finally remembered to charge the camera. Here is the Cajon all finished.
I blocked out the finish on the jazz mando and the bari uke with 800 grit last week. I'll be finishing up wet sanding those tomorrow or Friday and then off to my friend Johns this weekend to use his buffer. The mando bridge was fitted to the top on Monday. I should have the time to have both of these playable by next weekend.
PostPosted: Thu Nov 01, 2012 9:49 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
You're kind of an overachiever laughing6-hehe
Seriously, that Cajon is really cool! Can't wait to see the entire band all together.
PostPosted: Tue Nov 06, 2012 9:32 pm
This afternoons rain canceled my income producing plans, so I got in some shop time. Nothing exciting, just the wet sanding that I was going to do last week. All blocked out with 1000 grit now, tomorrow is 1200 grit then reschedule that date with John's buffer.
PostPosted: Tue Nov 06, 2012 10:18 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I'm really looking forward to seeing all of them together and completed. Your prolific production humbles me.
Bryan Bear PMoMC
PostPosted: Tue Nov 06, 2012 10:23 pm
First name: Tony
Last Name: C
City: Brooklyn
If you make a multi-track recording of all of the instruments together, you win my vote.
http://www.CostaGuitars.com
PMoMC
PostPosted: Wed Nov 07, 2012 3:21 pm
Just keeping myself busy. The devil makes work for idle hands, and I'm trying to stay off his payroll.
How about a live jam session?
PostPosted: Wed Nov 07, 2012 3:31 pm
These tuners were cheap and the white pearloid buttons really accentuate the look. A chunk of ebony that was left over from making fret boards, bridge blanks and head plates is going to help us out here.
Cut some suitably sized pieces on the table saw.
A 3/4" hole saw will work as a plug cutter to net some 5/8" slugs.
I use a piece of drywall to mark the grain direction.
PostPosted: Wed Nov 07, 2012 3:49 pm
I used my cheap but useful Harbor Freight cross vise to line up the slugs and drill a 1/8" hole for the shaft. The tuner shaft requires a 9/64" hole but this is the closest size brad point that I own. I open up the hole to final size after shaping.
A 2 1/4" #6 wood screw lightly started into the tuner shaft hole makes a good enough handle to hold the button for shaping on the edge sander.
Only lost one to the screw. Perhaps drilling the hole cross grain would have been more prudent.
PostPosted: Wed Nov 07, 2012 4:02 pm
A soldering gun heats up the shaft to soften the plastic buttons which are pulled off with pliers.
No pics of sanding, enlarging the shaft holes in the buttons or pressing them on to the shafts using the vice. Even more non pics of super gluing a crack in one button, replacing the other more severly cracked button or wiping on a coat of thin CA with a smoking paper towel. We do however have a final picture of the much more attractive re-buttoned tuners fit for a Jazz Mandolin.
PostPosted: Wed Nov 07, 2012 4:28 pm
The ebony tuner buttons are a huge improvement [:Y:]
PostPosted: Wed Nov 07, 2012 4:29 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Loved the detail on the tuner buttons! If they're just pressed on, what keeps them from slipping when bringing strings up to pitch?
PostPosted: Wed Nov 07, 2012 9:00 pm
Thanks Beth
The buttons are secured to the shafts with a prodigious amount of medium CA.
PostPosted: Wed Nov 07, 2012 9:04 pm
Thanks Steve, I was quite happy they were such a simple shape, easier to duplicate than most.
PostPosted: Wed Nov 07, 2012 10:26 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Great job on the buttons. I'm glad I saw this, it contributed to one of those "well duh" moments. For a long time I have been wanting to set up to be able to make tuner buttons that matched my fretboards. I have not gotten around to it, mostly because I have not figured out how to shape the buttons. Just last night I was noticing how crappy the plastic buttons on my economy mandolin tuners looked. It never occurred to me that mando buttons can be little circles. I have scraps of my fretboard wood and an extra month to work with, I may have to try this.
Bryan Bear PMoMC
PostPosted: Sun Nov 11, 2012 7:17 pm
Shiney time.
This is why I go to John's shop to buff. A nice Stew Mac buffer set up with plenty of natural light for checking your progress.
Pull 1 buff off each side to get into those tight cutaways and waists.
A picture of John's back yard.
This is his fire extinguisher.
I really like the trans red on the previously crappy looking hemlock.
PostPosted: Mon Nov 12, 2012 6:55 am
First name: Tony
Last Name: C
City: Brooklyn
Mmmmm...shiny.
Posted using two tin cans and some string.
PMoMC
PostPosted: Wed Nov 14, 2012 10:08 pm
A bit of assembly this afternoon.
PostPosted: Wed Nov 14, 2012 10:20 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Okay Steve, I want to buy that black beauty!!!! LOVE IT [clap]
cron
