It is currently Sat Jul 19, 2025 10:08 pm
Post new topic Reply to topic  [ 122 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Sat Nov 17, 2012 9:36 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Very classy and mellow-looking. Do you wipe the Tru-Oil on and then right off again? What kind of pattern do you use in applying (with grain, against, circular?)?
Can't wait to see it finished.
PostPosted: Sat Nov 17, 2012 9:45 am
First name: Jay
Last Name: Swann
City: Austin
Zip/Postal Code: 78739
Beth,
What I've found to work best for me is to apply the Tru-Oil with the grain, using a big cotton ball. I like to put it on kind of medium-thin, and do not wipe it afterwards. I will usually scuff it with micromesh between coats, and level a little with 600 grit every three coats or so. It seems to work for me. I've tried the coffee filter method, the paper towel method, the finger method, and this works the best for me.
PostPosted: Mon Nov 26, 2012 11:22 am
First name: Jay
Last Name: Swann
City: Austin
Can't let the thread fall too far down--I lose motivation. Pics here are of the finish starting to come up on the body, and the neck roughed out. The neck is almost complete now, I actually am just doing some touchup sanding on the neck to make sure there are no flat spots. I should drill for tuners and rough the headstock out tonight. I'll then re-flatten the fretboard prior to fretting, and do the final flossing of the neck joint. I'm getting close!!
PostPosted: Mon Nov 26, 2012 5:25 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
You're at my least favorite stage...finishing and setup can take as long as the building did! Looking really pretty!
PostPosted: Mon Nov 26, 2012 5:43 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Now why did you have to say that?? duh eek
Pablo Picasso
PostPosted: Mon Nov 26, 2012 8:40 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Beautiful! What are the dimensions of that box? What is the scale length?
Bryan Bear PMoMC
PostPosted: Mon Nov 26, 2012 9:31 pm
First name: Jay
Last Name: Swann
City: Austin
Bryan, please forgive the crappy picture. The guitar is modeled off the Bruno/Martin size 2 plan drawn by Scott Antes in 1974--I did mod it very slightly. I had a friend who played a Takamine Bruno commemorative in the early 90's and I thought it was the sexiest guitar I had ever seen--I still believe it is. As for dimensions, the upper bout is 8.5", waist is 7", and the lower bout is 12" wide. The scale is 24.5" and I repositioned the bridge in this photo to show it's actual location relative to scale. I hope it finishes out as nice as it has started. It will definitely be a conversation piece. --Jay
PostPosted: Mon Nov 26, 2012 9:53 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I really love that bearclaw top. Are you putting a pyramid bridge on?
PostPosted: Mon Nov 26, 2012 10:03 pm
First name: Jay
Last Name: Swann
City: Austin
Yes, pyramid bridge done in mesquite.... :mrgreen:
PostPosted: Mon Nov 26, 2012 10:09 pm
That is a sweet looking little guitar. Just looking at it makes me want to build one for myself.
PostPosted: Mon Nov 26, 2012 10:26 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Sa....weet!!!! bliss
PostPosted: Tue Nov 27, 2012 9:51 am
First name: Tony
Last Name: C
City: Brooklyn
That's very nice.
http://www.CostaGuitars.com
PMoMC
PostPosted: Wed Nov 28, 2012 7:11 am
First name: Jay
Last Name: Swann
City: Austin
A little more work last night and this morning. No jig for drilling the tuner holes, so grab the starrett square and line her up....
And after drilling the pilot holes for the slots.....
It's beginning to resemble a guitar!
PostPosted: Wed Nov 28, 2012 8:21 am
I really like it whey they start looking like a guitar [:Y:]
PostPosted: Wed Nov 28, 2012 8:37 am
First name: Tony
Last Name: C
City: Brooklyn
Looking gooood!
PMoMC
PostPosted: Wed Nov 28, 2012 9:22 am
First name: Jay
Last Name: Swann
City: Austin
Thanks for the encouragement, guys (and gal!). I feel like I'm in the home stretch now...
PostPosted: Wed Nov 28, 2012 9:39 am
First name: Big
Last Name: Jim
Love the shop smith BTW ... great tools for a limited space builder !
PostPosted: Sun Dec 02, 2012 10:05 pm
First name: Jay
Last Name: Swann
City: Austin
Inch by inch.... The neck is now set and flossed (finally!!!) I HATE neck setting (because it is so critical, I guess), but I have the neck set where I want it now. The headstock is done, string ramps filed (98% anyways), neck profile and heel are 97% done (still hunting a tiny flat spot). I've begun fretting as well--no fancy equipment there either, I bent the wire at a local repair guys shop, and cut the tangs off with a dremel and cutoff wheel, and then file smooth. I tap them in with an engraver's chasing hammer (I don't have a dead-blow hammer yet, and it worked out OK on my first build). Now that the neck is set, and ready for final install, I can see the end in sight. I may be strung up by the end of next weekend, which would be nice to have a few weeks of settle in and filming before the end!
PostPosted: Tue Dec 11, 2012 7:14 am
First name: Jay
Last Name: Swann
City: Austin
Almost home. Just doing some final finishing work on both the body and neck, and I'll be ready for final assembly and setup. I got the mesquite pyramid bridges back from Andy Birko who does absolutely FABULOUS CNC work. I swapped him some wood for a couple of pyramid bridges, and this is what came back... Thanks Andy!!
PostPosted: Tue Dec 11, 2012 8:05 am
That bridge looks really good on there.
PostPosted: Tue Dec 11, 2012 8:48 am
First name: Tony
Last Name: C
City: Brooklyn
Yup. That sure is nice!
PMoMC
PostPosted: Tue Dec 11, 2012 9:08 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
This is really starting to look nice. You are making me want to head town to Texas and get some mesquite.
Bryan Bear PMoMC
PostPosted: Tue Dec 11, 2012 10:31 am
Last Name: A
looks like it's going to be a beauty !! I really like your pictures too.
PostPosted: Thu Dec 13, 2012 6:30 am
First name: Jay
Last Name: Swann
City: Austin
The Mesquite-O will be sporting Grover Sta-tites @ $30 courtesy of eBay.... With free wood, you don't even have to cheap out on the tuners!!
PostPosted: Thu Dec 13, 2012 12:40 pm
I got two sets of those tuners for flat pegheads - a bargain for sure.
