It is currently Tue Jul 08, 2025 12:37 am
Post new topic Reply to topic  [ 102 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Nov 27, 2012 12:55 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Here's a few more photos...
The fingerboard after the Proulx bend, as flat as it was before fretting.
I probably should have come up with some clever jig for this, but I just went ahead and drilled the holes freehand!
Here's the birdseye headplate with the tuners installed.
And the back of the headstock. I nearly went too far south with the tuners.
PostPosted: Tue Nov 27, 2012 1:11 pm
Nice work! I almost made a tuner mistake on the headstock by leaving the curved area for the volute too close to the tuners so they wouldn't lay flat. Fortunately I did a test fit to check to see if the headstock thickness was correct and caught the other problem - whew.
PostPosted: Tue Nov 27, 2012 2:15 pm
First name: Rodger
Last Name: Knox
City: Baltimore
I shifted the tuners a bit to make room for my "Logo". laughing6-hehe
I had a few scraps of shell left over from another project, so I cut this out.
Scribed around the shell...
And inlayed it!
PostPosted: Tue Nov 27, 2012 2:19 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I did just that on my challenge mando. I lucked out and was able to put a very slight bend in the tail end of the baseplate to make it fit without affecting the tuners. . .
Bryan Bear PMoMC
PostPosted: Tue Nov 27, 2012 4:13 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Here's my high-tech precision tooling for cutting binding/purfling channels.
That's it, the StewMac bit and bushings and a Dewalt laminate trimmer, no jig!
I really should build a jig, but cutting them freehand is quick and easy. It does require a couple of hours of handwork with a file and scraper to get it ready.
Here's the binding/purfling glued on to the back.
PostPosted: Tue Nov 27, 2012 6:20 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Rodger, I have really enjoyed watching you work on this. I have begun to notice here and in other threads that you and I use very similar processes for most of the operations. The only real difference is you get much nicer results. Don’t worry, I’ll get there; I’m still pretty green.
Bryan Bear PMoMC
PostPosted: Wed Nov 28, 2012 3:30 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Thanks, but that's not entirely true. I spent last night taking off about a third of the binding/purfling, some of the purfling slipped off it's ledge during glue-up and was below the level of the top, plus the binding didn't fit because the purfling was in the way. It was glued with Titebond, so it wasn't terrible getting it off, but it remains to be seen how it will look when I'm finished.
PostPosted: Tue Dec 04, 2012 1:25 pm
First name: Rodger
Last Name: Knox
City: Baltimore
I really should remove the binding & purfling and do it over, the glue ups went really poorly. It doesn't fit nearly as good as it did for the dry fit, and when I scrape it flush with the sides the thickness will probably vary radically. I've almost sanded through the binding in one place already. oops_sign
It will be good enough though, because I ain't doin it over! bliss
The top & back are sanded and preped for final finish, I just have to scrape the binding flush with the sides and seal the pores on the sides with a few coats of shellac. I'll complete filling the pores with my TruOil finish, it only takes 6 or 8 coats to fill the pores if they're adequately sealed. I do at least 12 coats of TruOil, sometimes as many as 30, so filling the pores is not really a separate operation for me.
I've also cut out the soundhole and glued the fingerboard to the neck. Photos to follow...
PostPosted: Tue Dec 18, 2012 6:32 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Here's gluing the fingerboard to the neck:
And the top with a couple of coats of oil.
I made that bloodwood bridge because the ebony one is 41 grams, and that seemed heavy for this size guitar. The bloodwood bridge turned out to be 41 grams also, but with a little higher pitch in the taptone. I think I'll use the ebony, mostly for appearance.
Here's the back.
PostPosted: Tue Dec 18, 2012 7:09 pm
Last Name: Kincheloe
:lol: Yeah, I think bloodwood is usually even heavier than ebony. Why not rosewood, if you want lower density with darker color? 41 grams does sound quite high to me, especially with the added damping of ebony.
That redwood is gorgeous :) And the maple fingerboard against it is quite striking. I like the dark inlays on the fingerboard too. Tough competition!
PostPosted: Wed Dec 19, 2012 9:58 pm
That is an absolutely stunning guitar, IMHO. The woods chosen really make it stand out. Delicious is the right word, as far as I'm concerned. And from the Grellier plans, which I intend to build from soon.
By the way, you wouldn't happen to have a blueprint of your bending rig?
Also, what kind of bulbs and fixtures? That's a really cool solution.
PostPosted: Thu Dec 20, 2012 9:06 am
First name: Tony
Last Name: C
City: Brooklyn
That is beautiful Rodger. That soundboard....so nice.
http://www.CostaGuitars.com
PMoMC
PostPosted: Thu Dec 20, 2012 3:40 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Thanks for all the comments. From what you guys have said, I have extreame skill in selecting pretty wood. laughing6-hehe
Sorry, but no plans for my bender. I made it up as I went along, the base is 1x6s and the fixtures are the cheapest I could get at HD. The bending forms for each shape just slip over the base, I can get more pictures if anybody wants them.
PostPosted: Thu Dec 20, 2012 6:31 pm
If you can, I'd appreciate them.
I'm pretty sure I could handle building the forms and base. I'm more interested in what type/wattage the bulbs are, whether the fixtures for them need to be a certain type, and what you used for the steel slat on the form, and how it's attached.
I ask these questions because unlike most guys, I know absolutely nothing about lighting, home electrical wiring, etc. I'm sure it's simple, but I can be kind of thick, lol.
And by the way, my build, when I get around to being able to build it, will be using more standard woods(EIR and Sitka or Engelman), but I hope it turns out half as good as yours. Again, a gorgeous guitar.
PostPosted: Tue Jan 01, 2013 1:59 pm
First name: Rodger
Last Name: Knox
City: Baltimore
I'm out, but here's a few shots of my bender. Let me know if you need any more.
PostPosted: Tue Jan 01, 2013 2:39 pm
Rodger, that's great. Thanks.
PostPosted: Wed Jan 23, 2013 10:20 am
First name: Rodger
Last Name: Knox
City: Baltimore
No progress pics, but I'm still putting oil on. It's got 20+ coats now, as soon as I get one to go on nicely, I'll be done. Well, I'll be done putting on oil. Then another couple of weeks for it to cure enough to buff. Everything else is ready, the bridge is carved and roughly fitted to the top, the nut is slotted & installed, and the neck is ready for final attachment.
PostPosted: Mon Mar 18, 2013 4:10 pm
First name: Rodger
Last Name: Knox
City: Baltimore
It's finished! bliss
Well, it's got strings on it. I still have to work the saddle down some, the action is a little high, and there's a lot of saddle sticking out of the slot. Final photos soon. Maybe even a video.
PostPosted: Mon Mar 18, 2013 8:16 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Can't wait to see the pictures!!!!
PostPosted: Tue Mar 19, 2013 4:07 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Oh you gotta' post a video; it's in the rules!
Bryan Bear PMoMC
PostPosted: Sun Sep 15, 2013 4:58 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Zip/Postal Code: 30308
Any pictures of the completed guitar?
"I'm not going to say that perfection has never been achieved. However, if it has, it probably went unnoticed due to it's lack of character."
PostPosted: Sun Sep 15, 2013 7:08 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
Give us a peak, Rodger pizza
PostPosted: Tue Sep 17, 2013 11:06 am
First name: Rodger
Last Name: Knox
City: Baltimore
Here's a couple of shots as it is now. It's not done, the bridge is lifting in the back and I've decided I don't like the pinless bridge anyway.
PostPosted: Tue Sep 17, 2013 11:14 am
I was planning a pinless bridge and I've been wondering about how to stop them lifting. The pinless design certainly seems to put a lot more strain on that joint than when the strings are anchored under the top.
(The guitar looks great by the way, love the three piece back and that top is gorgeous!)
PostPosted: Tue Sep 17, 2013 11:31 am
First name: Rodger
Last Name: Knox
City: Baltimore
There's nothing wrong with the pinless design I used, I just didn't do a very good job of clamping when I glued it down.
I've glued a pinless bridge on a tipple, (that's the traditional type) which is basicly a uke with 10 steel strings. The bridge is about 4 1/2" x 7/8", which is much less glue area than a guitar bridge. It didn't stay on the first try, but after careful fitting and clamping, it's holding fine.
These users thanked the author Rodger Knox for the post: Nick Royle (Tue Sep 17, 2013 1:18 pm)
