It is currently Fri Jul 18, 2025 10:47 am
Post new topic Reply to topic  [ 180 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
PostPosted: Sun Dec 23, 2012 11:04 am
First name: Marcus
Last Name: Bailie
City: Kirkland
I hope you make it in time, wud. This is a cool build.
-Marcus
http://www.bailieguitars.com
Instagram | YouTube
PostPosted: Sun Dec 23, 2012 11:51 am
First name: Dan
Last Name: Pennington
City: Brooklyn Park
State: MN
Zip/Postal Code: 55428
Wud
Replace the side walls of your banjo resonator with a block rim and bolt the neck to it either with furniture knock down bolts
or lag screws and nuts.
(shameless self promotion here!) I make block rims for banjos and I could make what you need inexpensively.
PostPosted: Sun Dec 23, 2012 11:59 am
In the meantime (since that would probably not get done in the next week) what about just sandwiching the rim between the neck and a block and bolting it together that way? And then if there is too much flex the stick between the neck and tail blocks could fix that - or a trunnion bolt could be used that would allow some adjustment?
PostPosted: Sun Dec 23, 2012 12:07 pm
First name: Big
Last Name: Jim
The next one I build will be a solid wood rim min 3/16" probably stop at 1/4" , when the top and back are in place there is no give , you have two solid circles and as everyone knows a circle can hold great loads .
Had I done this with a Mandolin neck and strings I believe it would have held fine . However the .054 " mandola set apply a huge amount of tension.
Minor set back ..... I will be re-gluing and bolting most of it back together today .
PostPosted: Sun Dec 23, 2012 2:45 pm
WudWerkr wrote:
...Minor set back ..... I will be re-gluing and bolting most of it back together today .
[:Y:] [:Y:]
PostPosted: Mon Dec 24, 2012 2:08 pm
First name: Big
Last Name: Jim
Neck Re Bolted and Re-Glued . :Letting the glue dry . I have Carbon Fiber rod installed . If necessary I can run a threaded rod into the neck in place of the bolt and run it all the way into the tail block .
I may not finish on time , or be in same league with the winner , but this sucker is gonna play !!! :twisted: laughing6-hehe
PostPosted: Mon Dec 24, 2012 2:24 pm
Awright [:Y:]
PostPosted: Mon Dec 24, 2012 7:39 pm
First name: Big
Last Name: Jim
Going back with reversed kerf linings for a guitar . I think tis will help a little on the side stiffness over Mandolin Linings .. I can already feel a difference in the weight of the Mandola
PostPosted: Tue Dec 25, 2012 3:33 pm
First name: Big
Last Name: Jim
Top Back On ...... I hate doing stuff twice ! :evil:
Im gonna leave the finish undone and string it up . If all holds and she plays I will have finish work to do after the first .
PostPosted: Wed Dec 26, 2012 5:58 pm
First name: Big
Last Name: Jim
Out for sure now , Strung the second time and got closer to tuned but the neck started cantilevering over , I checked the joint and it was holding . Started checking the shape of the body and the entire body is deforming going egg shaped . This resonater just doesn't have the strength to hold together under that stress . I will be constructing a new body from solid wood for this one .
Even though I didn't get it fully tuned , it did have some great ring and sustain . I do believe there is merit to this Idea ... Just some "back to the drawing board " time .
I look forward to seeing and hearing all the finished entries [clap]
PostPosted: Thu Dec 27, 2012 12:42 pm
First name: Marcus
Last Name: Bailie
City: Kirkland
Sorry to hear, Wud. Be sure to follow up with your new plans.
-Marcus
Instagram | YouTube
PostPosted: Thu Dec 27, 2012 2:37 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Sad face!
Bryan Bear PMoMC
PostPosted: Thu Dec 27, 2012 2:57 pm
Sorry to hear that Wud. Sometimes R&D just doesn't work out. idunno
PostPosted: Thu Dec 27, 2012 4:02 pm
First name: Big
Last Name: Jim
Kinda look at it this way Guys ..... If this is worst that Happens over the next year , its gonna be awsome ! laughing6-hehe
PostPosted: Sun Dec 30, 2012 6:20 pm
First name: Big
Last Name: Jim
Still Plugging along here guys . Ordered 2 sets of tenor guitar strings . That will make the 4th set .040 instead of .054 , With additional bracing I should be in Business .
I had to spray the top to blend in . After having that sucker off twice , there are areas I need to hide laughing6-hehe
This sucker is gonna play if I have to send it to Tony for another beatin ! laughing6-hehe
PostPosted: Sun Dec 30, 2012 9:44 pm
Way to go Wud!
PostPosted: Tue Jan 01, 2013 4:11 pm
First name: Big
Last Name: Jim
Got it finished and re-strung and tuned . I went with tenor guitar strings that helped a bunch . The 4th wet from .054 to .040 , reduced the stress alot . It is tuned and the neck is holding , I am at .120 at 12th fret , I will work it down to .090 . ( requires sanding the bridge down a little , saddle is as far as I can go ) Needs some drop fill laq and a bit more satin finishing in spots but all in all its good.
PostPosted: Tue Jan 01, 2013 4:14 pm
First name: Tony
Last Name: C
City: Brooklyn
Hooray! Congrats Wud!
Posted using letters to form words, sentences and thoughts.
http://www.CostaGuitars.com
PMoMC
PostPosted: Tue Jan 01, 2013 4:57 pm
Awright!!!
PostPosted: Tue Jan 01, 2013 5:54 pm
First name: Phillip
Last Name: Patton
City: Yoder
Zip/Postal Code: 46798
Hey Wud,
I still haven't heard from Lance (and I did email him too), so you can still get in at the vote. :)
Regards,
Phillip Patton
http://www.pattonblades.com
The bitterness of poor quality lingers long after the sweetness of low price has faded.
https://hoosierbladesmith.wordpress.com
PostPosted: Tue Jan 01, 2013 6:06 pm
First name: Big
Last Name: Jim
Phillip Patton wrote:
Hey Wud,
I appreciate that Phillip , But I dont have a vid yet and I hate to take a vote away from the excellent builds I've seen so far . Let me see what comes of the vid possibilities , but dont wait up for me.
PostPosted: Tue Jan 01, 2013 6:13 pm
First name: Tony
Last Name: C
City: Brooklyn
Did you see my video? You can certainly do better than that pile of garbage!
PMoMC
PostPosted: Tue Jan 01, 2013 6:32 pm
First name: Big
Last Name: Jim
Tony , I think yours turned out great ! I like the sound and the build. OK so I DO CARE laughing6-hehe
PostPosted: Tue Jan 01, 2013 6:56 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Good on ya Wud! I hope you get a video up in time, but if not, at least I know our challenge entries will meet each other in a few months. . .
Bryan Bear PMoMC
PostPosted: Tue Jan 01, 2013 7:06 pm
First name: Tony
Last Name: C
City: Brooklyn
Thanks Wud, but the production value was WAY down! iPhone video was not my first choice but I had no other options. Can't seem to find the video camera. I am beginning to think that it left with my old cleaning lady who suddenly vanished. But, at least I got the video up. Thanks for the compliments on the sound of the little uke. The secret is in the big sound hole. It is NOT the sound hole itself, but what is IN it!
PMoMC
