It is currently Sun Aug 03, 2025 4:47 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Sat Jan 21, 2006 2:51 pm
PostPosted: Sat Jan 21, 2006 2:54 pm
Well, I'm not sure this is that helpful-however, I did learn to convert for one whole lot of $ less than the $ estimated before.Hope the size is within the rules.Wow, my workbench is a mess.
PostPosted: Sat Jan 21, 2006 2:57 pm
Thanks Mike,That was an excellant explanation. Oh yeah,you're not the only stubborn ol fart around here! I like using hand tools too
PostPosted: Sat Jan 21, 2006 3:31 pm
Maybe the better perspective.
PostPosted: Sun Jan 22, 2006 3:40 am
ok. where can i get a longer block plane? i checked ebay but all they have is "antique" junk. and thanks to everybody for all the help.
PostPosted: Sun Jan 22, 2006 4:44 am
I wouldn't be so quick to discount that antique "junk"
search for a Stanley #7 Plane. You can get them usually at a pretty fair price. They will probably require a bit of tuning, but it is an afternoon that will pay dividends long into the future.
If you want to bypass that, just buy a Lie Nielsen. They are mucho expensive, but very very nice.
PostPosted: Sun Jan 22, 2006 6:20 am
I have a piece of old ebay 'Junk'; a Stanley Baily #5 from the 1915-1930 era (I believe), BRW handles, but a great tool (Far better than any modern Stanley). Works just fine for jointing tops, IMO, although I wouldn't say no to a #7...Mattia Valente38739.597974537
PostPosted: Sun Jan 22, 2006 7:38 pm
i use a no 5 in preference to a no 6 or 7 as the bigger versions are just too cunbersome. and of my 12 or so planes all came from garage and estate sales, flea markets and auctions, the most expensive being a no 7 at $25. unless you spend the very big bucks for a l-n or similar you have to tune the new ones anyhow.
PostPosted: Mon Jan 23, 2006 5:14 am
The first top I joined I used the sanding method. My sander was a precision milled 4' level with 3M sticky back 80 grit applied. I used a basic shooting board configuration to hold the wood. I could not figure out why it was taking so many attempts to get it right till I double checked the level. Sure enough there was a bow in the level.
I switched several years ago to using a jointing plane on the shooting board. But recently I bought one of those StewMac precision milled aluminum tubing fret levelers, So I thought for kicks I would give it a try on the shooting board. First try dead on.
My guess is if you are having spots not meet, then the problem is either the material is moving or the sanding vehicle is not perfectly flat.
